<!– Class –> Defines objects used to fill the interiors of AreaBaseShapes, such as MultiPolygonShape, PolygonShape, EllipseShape, and other AreaBaseShapes.
This is an abstract base class and cannot be instantiated. To create a GeoBrush object, use classes derived from GeoBrush, such as GeoSolidBrush.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoImageBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoLinearGradientBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoRadialGradientBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoTextureBrush ***ThinkGeo.MapSuite.WindowsPhoneCore.GeoVideoBrush
GeoBrush | This is the constructor for the GeoBrush |
The id of the GeoBrush. This is always used as a key when in the cached brushes.
| Int64<!– System.Int64 –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
