thinkgeo.mapsuite.windowsphonecore.geotexturebrush
ThinkGeo.MapSuite.WindowsPhoneCore.GeoTextureBrush
<!– Class –> This class is used to fill an area with a image texture.
This class is used to fill an area with a image texture. For example, you may have a small bitmap that looks like marble, which you can then use to fill in an area feature.
Public MethodGeoTextureBrush GeoImage This is a constructor for the class.
Public MethodGeoTextureBrush GeoImage, DrawingRectangleF This is a constructor for the class.
Public MethodGeoTextureBrush GeoImage, GeoWrapMode This is a constructor for the class.
Public MethodGeoTextureBrush GeoImage, GeoWrapMode, DrawingRectangleF This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyDrawingRectangleF DrawingRectangleF This property gets and sets the screen rectangle used to fill the texture.
Public PropertyGeoImage GeoImage This property gets and sets the GeoImage used for the texture fill.
Public PropertyGeoWrapMode GeoWrapMode This property gets and sets the wrap mode that is used to determine how an area is filled if the area is larger than the texture.
Public PropertyId Int64 GeoBrush The id of the GeoBrush. This is always used as a key when in the cached brushes.
Public PropertyOpacity Double GeoBrush
GeoTextureBrush(GeoImage)
Overloads
This overload allows you to pass in the image for the texture.
You will use this constructor when you want to use the Tile wrap mode and you want the image fill to encompass the entire shape.
Name Type Description
image GeoImage<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoImage –> This parameter is the image you want to use as the texture.
Go Back
GeoTextureBrush(GeoImage, DrawingRectangleF)
Overloads
This constructor allows you to pass in the image as well as a screen rectangle that determines how much of the area is filled.
This method allows you to pass in a rectangle in screen coordinates to determine how much of the area is textured.
rectangleF DrawingRectangleF<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –> This parameter is a rectangle (in screen coordinates) that specifies the area you want to use for the texture.
Go Back
GeoTextureBrush(GeoImage, GeoWrapMode)
Overloads
This constructor allows you to pass in the image and the wrap mode.
wrapMode GeoWrapMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoWrapMode –> This parameter determines the way the texture wraps when the area to fill is larger than the texture.
Go Back
GeoTextureBrush(GeoImage, GeoWrapMode, DrawingRectangleF)
Overloads
This constructor allows you to pass in the image as well as a screen rectangle that determines how much of the area is filled along with the wrap mode.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
DrawingRectangleF
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoTextureBrush –> Go Back
GeoImage
Return Type
GeoWrapMode
Return Type
Id
Return Type
Int64<!– System.Int64 –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
Opacity
Return Type
Double<!– System.Double –>
thinkgeo.mapsuite.windowsphonecore.geotexturebrush.txt · Last modified: 2017/03/16 21:59 (external edit)
