thinkgeo.mapsuite.windowsphonecore.geoimage
ThinkGeo.MapSuite.WindowsPhoneCore.GeoImage
<!– Class –> This class represents an image you want to use on the GeoCanvas.
This class was designed so that it can be used for any type of stream while still being easy to use. For example, you can specify a path and filename in the constructor and the class will hold this. When the GeoCanvas needs the image, it will get its stream and then pass it off for drawing. After drawing, it disposes of the stream so there are no wasted resources.
You can also pass in a path and filename that does not actually exist on disk. In that case we will raise an event where you can provide a stream on demand. With this function, you can use compressed streams, isolated storage and many other stream-related storage machanisms.
Public MethodGeoImage This is the constructor used to create a new GeoImage.
Public MethodGeoImage Uri
Public MethodGeoImage Uri, Double, Double
Public MethodDispose This is the Dispose for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyCanvasImageFormat Guid This property returns the image format.
Public PropertyHeight Double
Public PropertyImageUri Uri
Public PropertySourceStream Stream
Public PropertyWidth Double
GeoImage()
Overloads
This constructor allows you to create a drawing image without specifying a PathFileName.
You need to set the imageUri if you intend to use this constructor.
Name Type Description
Go Back
GeoImage(Uri)
Overloads
This constructor allows you to create a drawing image by specifying a PathFileName.
imageUri Uri<!– System.Uri –>
Go Back
GeoImage(Uri, Double, Double)
width Double<!– System.Double –>
height Double<!– System.Double –>
Go Back
Dispose()
Overloads
This overload will dispose of the stream in the GeoImage and release its resources.
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoImage –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
CanvasImageFormat
Return Type
Guid<!– System.Guid –>
Height
Return Type
ImageUri
Return Type
SourceStream
Return Type
Stream<!– System.IO.Stream –>
Width
Return Type
thinkgeo.mapsuite.windowsphonecore.geoimage.txt · Last modified: 2017/03/16 21:59 (external edit)
