thinkgeo.mapsuite.windowsphonecore.geovideobrush
ThinkGeo.MapSuite.WindowsPhoneCore.GeoVideoBrush
<!– Class –>
Public MethodGeoVideoBrush
Public MethodGetType Object
Public MethodToString Object
Public PropertyGeoAlignmentX GeoAlignmentX
Public PropertyGeoAlignmentY GeoAlignmentY
Public PropertyGeoStretch GeoStretch
Public PropertyId Int64 GeoBrush The id of the GeoBrush. This is always used as a key when in the cached brushes.
Public PropertyOpacity Double GeoBrush
Public PropertySourceName String
GeoVideoBrush()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
GeoAlignmentX
Return Type
GeoAlignmentX<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoAlignmentX –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoVideoBrush –> Go Back
GeoAlignmentY
Return Type
GeoAlignmentY<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoAlignmentY –>
GeoStretch
Return Type
GeoStretch<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoStretch –>
Id
Return Type
Int64<!– System.Int64 –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
Opacity
Return Type
Double<!– System.Double –>
SourceName
Return Type
thinkgeo.mapsuite.windowsphonecore.geovideobrush.txt · Last modified: 2017/03/16 21:59 (external edit)
