thinkgeo.mapsuite.windowsphonecore.geolineargradientbrush
ThinkGeo.MapSuite.WindowsPhoneCore.GeoLinearGradientBrush
<!– Class –> Encapsulates a GeoBrush with a linear gradient.
This class encapsulates both two-color gradients and custom multicolor gradients.
All linear gradients are defined along a line specified either by the width of a rectangle or by two points.
By default, a two-color linear gradient is an even horizontal linear blend from the starting color to the ending color along the specified line.
Public MethodGeoLinearGradientBrush Vertex, Vertex, Collection<GeoGradientStop>
Protected MethodGeoLinearGradientBrush Create a new instance of the GeoLinearGradientBrush with default settings.
Public MethodGetType Object
Public MethodToString Object
Public PropertyEndPoint Vertex
Public PropertyGeoGradientSpreadMethod GeoGradientSpreadMethod
Public PropertyGeoGradientStops Collection<GeoGradientStop>
Public PropertyGeoMappingMode GeoBrushMappingMode
Public PropertyId Int64 GeoBrush The id of the GeoBrush. This is always used as a key when in the cached brushes.
Public PropertyOpacity Double GeoBrush
Public PropertyStartPoint Vertex
GeoLinearGradientBrush(Vertex, Vertex, Collection<GeoGradientStop>)
Name Type Description
startPoint Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –>
endPoint Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –>
geoGradientStops Collection<GeoGradientStop><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.GeoGradientStop} –>
Go Back
GeoLinearGradientBrush()
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
EndPoint
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoLinearGradientBrush –> Go Back
Return Type
GeoGradientSpreadMethod<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoGradientSpreadMethod –>
GeoGradientStops
Return Type
GeoMappingMode
Return Type
GeoBrushMappingMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrushMappingMode –>
Id
Return Type
Int64<!– System.Int64 –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
Opacity
Return Type
Double<!– System.Double –>
StartPoint
Return Type
thinkgeo.mapsuite.windowsphonecore.geolineargradientbrush.txt · Last modified: 2017/03/16 21:59 (external edit)
