<!– Structure –> This structure represents the point at which the sides of an angle intersect.
*System.ValueType **ThinkGeo.MapSuite.WindowsPhoneCore.Vertex
Vertex | Double, Double | This is the constructor used to create a vertex. | |
Vertex | PointShape | This is the constructor used to create a vertex. |
Add | Vertex | This method adds the target vertex to the current vertex. | |
Equals | Object | Object(overriden) | This method is an override of the Equals functionality. |
![]() FindMiddleVertexBetweenTwoVertices | Vertex, Vertex | This method returns the middle Vertex of a straight line which two vertices are passing in. | |
GetHashCode | Object(overriden) | This method is an override of the GetHashCode functionality. | |
ToString | Object(overriden) | This method is an override of the ToString functionality. |
This constructor takes X and Y coordinates.
| x | Double<!– System.Double –> | This parameter represents the horizontal value. |
| y | Double<!– System.Double –> | This parameter represents the vertical value. |
This constructor takes a PointShape.
| point | PointShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointShape –> | This parameter is the PointShape you want to convert to a Vertex. |
| Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> |
| targetVertex | Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> | This parameter represents the vertex you wish to add to the current vertex. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> Go Back
<!– static –> This method returns the middle Vertex of a straight line which two vertices are passing in.
| Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> | This method returns the middle Vertex between the vertices which passing in. |
| vertex1 | Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> | start vertex of a straight line |
| vertex2 | Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> | en vertex of a straight line |
This property returns the horizontal value of the vertex.
This property returns the vertical value of the vertex.
