<!– Class –>
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoRadialGradientBrush
GeoRadialGradientBrush | Collection<GeoGradientStop> |
GeoRadialGradientBrush | Create a new instance of the GeoLinearGradientBrush with default settings. |
Center | Vertex | ||
GeoGradientSpreadMethod | GeoGradientSpreadMethod | ||
GeoGradientStops | Collection<GeoGradientStop> | ||
GeoMappingMode | GeoBrushMappingMode | ||
GradientOrigin | Vertex | ||
Id | Int64 | GeoBrush | The id of the GeoBrush. This is always used as a key when in the cached brushes. |
Opacity | Double | GeoBrush | |
RadiusX | Double | ||
RadiusY | Double |
| geoGradientStops | Collection<GeoGradientStop><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.GeoGradientStop} –> |
| Vertex<!– ThinkGeo.MapSuite.WindowsPhoneCore.Vertex –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoRadialGradientBrush –> Go Back
| GeoGradientSpreadMethod<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoGradientSpreadMethod –> |
| GeoBrushMappingMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrushMappingMode –> |
| Int64<!– System.Int64 –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
