<!– Class –>
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoImageBrush
GeoImageBrush | Uri |
GeoAlignmentX | GeoAlignmentX | ||
GeoAlignmentY | GeoAlignmentY | ||
GeoStretch | GeoStretch | ||
Id | Int64 | GeoBrush | The id of the GeoBrush. This is always used as a key when in the cached brushes. |
ImageUri | Uri | ||
Opacity | Double | GeoBrush |
| imageUri | Uri<!– System.Uri –> |
| GeoAlignmentX<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoAlignmentX –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoImageBrush –> Go Back
| GeoAlignmentY<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoAlignmentY –> |
| GeoStretch<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoStretch –> |
| Int64<!– System.Int64 –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
