<!– Class –> This class represents a font that is used to label features on a GeoCanvas.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.GeoFont
GeoFont | This constructor creates a GeoFont to be used for labeling features on a GeoCanvas. | ||
GeoFont | String, Double | This constructor creates a GeoFont to be used for labeling features on a GeoCanvas. | |
GeoFont | String, Double, Boolean | ||
GeoFont | String, Double, DrawingFontStyles | This constructor creates a GeoFont to be used for labeling features on a GeoCanvas. |
FontName | String | This property gets the font name property of the font. | |
FontStretch | GeoFontStretch | ||
FontWeight | GeoFontWeight | This property gets the bold property of the font. | |
IsBold | Boolean | This property gets the bold property of the font. | |
IsItalic | Boolean | This property gets the italic property of the font. | |
IsUnderline | Boolean | This property gets the underline property of the font. | |
Size | Double | This property gets the font size property of the font. | |
Style | DrawingFontStyles | This property gets the font style property of the font. |
This overload creates the GeoFont using its default property values.
This overload creates the GeoFont by specifying the font name and font size.
| fontName | String<!– System.String –> | This parameter represents the name of the font to be used. |
| size | Double<!– System.Double –> | This parameter represents the size of the font to be used. |
| fontName | String<!– System.String –> | |
| size | Double<!– System.Double –> | |
| isItalic | Boolean<!– System.Boolean –> |
This overload creates the GeoFont by specifying the font name, font size and font style.
| style | DrawingFontStyles<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingFontStyles –> | This parameter represents the style of the font to be used. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoFont –> Go Back
| GeoFontStretch<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoFontStretch –> |
| GeoFontWeight<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoFontWeight –> |
