<!– Class –> This class is used to draw area features.
You should use this class to draw area features. You can specify a fill brush to draw the interior and an outline pen to draw the border. You can optionally choose to use only the outline pen or the fill brush, which enables you to generate different effects.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.Style *ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyle ThinkGeo.MapSuite.WindowsPhoneCore.QualityFamilyAreaStyle
AreaStyle | This is the constructor for the class. | ||
AreaStyle | GeoSolidBrush | This is the constructor for the class. | |
AreaStyle | GeoPen | This is the constructor for the class. | |
AreaStyle | GeoPen, GeoSolidBrush | This is the constructor for the class. | |
AreaStyle | GeoPen, GeoSolidBrush, PenBrushDrawingOrder | This is the constructor for the class. |
Draw | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the features on the canvas you provided. |
Draw | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style | This method draws the shapes on the canvas you provided. |
DrawSample | GeoCanvas, DrawingRectangleF | Style | |
GetRequiredColumnNames | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
DrawCore | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | Style(overriden) | This method draws the features on the canvas you provided. |
DrawSampleCore | GeoCanvas, DrawingRectangleF | Style(overriden) | |
GetRequiredColumnNamesCore | Style | This method returns the column data for each feature that is required for the style to properly draw. | |
Advanced | AreaStyleAdvanced | This property lets you access the advanced properties of the style. | |
CustomAreaStyles | Collection<AreaStyle> | This property returns a collection of area styles, allowing you to stack multiple area styles on top of each other. | |
FillSolidBrush | GeoSolidBrush | This property gets and sets the solid brush you want to use to fill in the area features. | |
IsActive | Boolean | Style | This property gets and sets the active status of the style. |
Name | String | Style | This property gets and set the name of the style. |
OutlinePen | GeoPen | This property gets and sets the outline pen you want to use to outline the features. | |
PenBrushDrawingOrder | PenBrushDrawingOrder | This property gets and sets the pen and brush drawing order. | |
RequiredColumnNames | Collection<String> | Style | This property gets the collection of fields that are required for the style. |
XOffsetInPixel | Single | This property gets and sets the X pixel offset for drawing each feature. | |
YOffsetInPixel | Single | This property gets and sets the Y pixel offset for drawing each feature. |
This constructor does not specify an outline pen or fill brush.
If you use this constructor, you will need to set the properties of the fill brush and outline pen manually.
This constructor allows you to specify a fill brush without an outline.
This constructor allows you to specify just a fill brush. In this way, the area you draw will not have an outline.
| fillSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –> | This parameter is the solid brush you want to fill the area with. |
This constructor allows you to specify an outline pen without a filled-in area.
This constructor allows you to specify just an outline pen. In this way, the area you draw will have an outline, but a transparent interior (no fill).
| outlinePen | GeoPen<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoPen –> | This parameter is the outline pen you want to use to outline the area. |
This constructor allows you to specify an outline pen with a filled-in area.
This constructor allows you to specify a fill brush and an outline pen.
| fillSolidBrush | GeoSolidBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –> | This parameter is the solid brush you wish to fill the area with. |
This constructor allows you to specify an outline pen with a filled-in area. It also lets you select whether the pen or brush is used first.
This constructor allows you to specify a fill brush and an outline pen. It also allows you to specify which is drawn first. If the pen is drawn first, the outline will be thinner than if the pen is drawn last. The effect is subtle but noticeable.
| penBrushDrawingOrder | PenBrushDrawingOrder<!– ThinkGeo.MapSuite.WindowsPhoneCore.PenBrushDrawingOrder –> | This parameter allows you to choose whether the outline pen or the fill brush is drawn first. |
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
| labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style –> Go Back
| shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | |
| drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –> |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style(overriden) –> Go Back
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
| AreaStyleAdvanced<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyleAdvanced –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyle –> Go Back
Using this collection, you can stack multiple area styles on top of each other. When we draw the features, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
| Collection<AreaStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyle} –> |
This solid brush is used to fill in the area features that will draw. You can also optionally specify an outline pen to give the area an outline. The default solid brush has a fill color of transparent, which means it will not draw anything.
This outline pen is used to outline the features that will draw. You can also optionally specify a fill brush to give the area a solid fill. The default outline pen color is transparent, which means it will not draw anything.
This property controls whether the outline pen or the fill brush is drawn first. The default is for the fill brush to be drawn first. If you have the outline pen draw first then the thickness of the pen will be smaller, creating a subtle but noticeable effect.
This property allows you to specify an X offset. When combined with a Y offset, it enables you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to align it with raster satellite data.
This property allows you to specify a Y offset. When combined with an X offset, it enables you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to align it with raster satellite data.
