<!– Class –> This class represents a GeoPen, which is used to draw lines on a GeoCanvas.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.GeoPen
SetLineCap | GeoDashCap, GeoDashCap, GeoDashCap | This method allows you to set the start, end and dash caps at one time. | |
Brush | GeoBrush | This property gets and sets the brush for this GeoPen. | |
Color | GeoColor | This property gets and sets the GeoColor for this GeoPen. | |
DashCap | GeoDashCap | This property gets and sets the dash cap for this GeoPen. | |
DashPattern | Collection<Double> | This property gets and sets the dash pattern for this GeoPen. | |
EndCap | GeoDashCap | This property gets and sets the end cap for this GeoPen. | |
Id | Int64 | The id of the GeoBrush. This is always used as a key when in the cached brushes. | |
LineDashStyle | LineDashStyle | This property gets and sets the dash style for this GeoPen. | |
LineJoin | DrawingLineJoin | This property gets and sets the line join for this GeoPen. | |
MiterLimit | Double | This property gets and sets the miter limit for this GeoPen. | |
StartCap | GeoDashCap | This property gets and sets the start cap for this GeoPen. | |
Width | Double | This property gets and sets the width for this GeoPen. |
This constructor creates a GeoPen.
This overload creates a GeoPen with its default values.
Name | Type | Description |
This overload creates a GeoPen by specifying a GeoBrush.
brush | GeoBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> | This parameter represents the brush that will be used to draw the line. |
This overload creates a GeoPen by specifying a GeoColor.
color | GeoColor<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoColor –> | This parameter represents the color that will be used to draw the line. |
This overload creates a GeoPen by specifying a GeoColor and a line width.
width | Double<!– System.Double –> | This parameter represents the width of the line. |
This overload creates a GeoPen by specifying a GeoBrush and a line width.
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Void<!– System.Void –> |
startCap | GeoDashCap<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoDashCap –> | This parameter specifies the start cap to be used. |
endCap | GeoDashCap<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoDashCap –> | This parameter specifies the end cap to be used. |
dashCap | GeoDashCap<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoDashCap –> | This parameter specifies the dash cap to be used. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoPen –> Go Back
String<!– System.String –> |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<Double><!– System.Collections.ObjectModel.Collection{System.Double} –> |
Return Type |
Return Type |
Int64<!– System.Int64 –> |
Return Type |
LineDashStyle<!– ThinkGeo.MapSuite.WindowsPhoneCore.LineDashStyle –> |
Return Type |
DrawingLineJoin<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingLineJoin –> |
Return Type |
Return Type |
Return Type |
