thinkgeo.mapsuite.windowsphonecore.areastyleadvanced
ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyleAdvanced
<!– Class –> This class represents the advanced drawing options for area styles.
This class allows you to set the FillCustomBrush. This enables you to use custom brushes to achieve effects such as linear gradients and bitmap fills.
Public MethodAreaStyleAdvanced This is the default constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyFillCustomBrush GeoBrush This property allows you to get and set a custom fill brush.
AreaStyleAdvanced()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
FillCustomBrush
This allows you to use custom brushes to achieve effects such as linear gradients and bitmap fills. If you use any brush besides the SolidBrush, you would set it in this property.
Return Type
GeoBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyleAdvanced –> Go Back
thinkgeo.mapsuite.windowsphonecore.areastyleadvanced.txt · Last modified: 2017/03/16 21:59 (external edit)
