<!– Class –> This abstract class is the root for all styles used for drawing features.
If you need to create your own style in the future, we suggest that you first consider extending an existing style. If you are doing something new, then you can inherit from this class.
The key method to override is DrawCore. If you want to provide a sample for the legend, you will also want to extend the DrawSampleCore.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.Style *ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyle *ThinkGeo.MapSuite.WindowsPhoneCore.ClassBreakStyle *ThinkGeo.MapSuite.WindowsPhoneCore.DotDensityStyle *ThinkGeo.MapSuite.WindowsPhoneCore.GradientStyle *ThinkGeo.MapSuite.WindowsPhoneCore.LineStyle *ThinkGeo.MapSuite.WindowsPhoneCore.PointStyle *ThinkGeo.MapSuite.WindowsPhoneCore.PositionStyle *ThinkGeo.MapSuite.WindowsPhoneCore.QualityFamilyAreaStyle *ThinkGeo.MapSuite.WindowsPhoneCore.RegexStyle *ThinkGeo.MapSuite.WindowsPhoneCore.TextStyle *ThinkGeo.MapSuite.WindowsPhoneCore.ValueStyle
Style | This is the default constructor for the style and should be called by inherited classes. |
Draw | IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | This method draws the shapes on the canvas you provided. | |
Draw | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | This method draws the features on the canvas you provided. | |
DrawSample | GeoCanvas, DrawingRectangleF | ||
GetRequiredColumnNames | This method returns the column data for each feature that is required for the style to properly draw. | ||
DrawCore | IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> | This method draws the features on the canvas you provided. | |
DrawSampleCore | GeoCanvas, DrawingRectangleF | ||
GetRequiredColumnNamesCore | This method returns the column data for each feature that is required for the style to properly draw. | ||
IsActive | Boolean | This property gets and sets the active status of the style. | |
Name | String | This property gets and set the name of the style. | |
RequiredColumnNames | Collection<String> | This property gets the collection of fields that are required for the style. |
Name | Type | Description |
Return Type | Description |
Void<!– System.Void –> |
shapes | IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> | This parameter represents the shapes you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | This parameter represents the canvas you want to draw the shapes on. |
labelsInThisLayer | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> | The labels will be drawn in the current layer only. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> | The labels will be drawn in all layers. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style –> Go Back
features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> | This parameter represents the features you want to draw on the canvas. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | This parameter represents the canvas you want to draw the features on. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> | |
drawingExtent | DrawingRectangleF<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –> |
Int32<!– System.Int32 –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of column names that the style needs. |
Type<!– System.Type –> |
String<!– System.String –> |
This abstract method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Return Type |
Return Type |
Return Type |
