thinkgeo.mapsuite.windowsphonecore.labelduplicaterule
ThinkGeo.MapSuite.WindowsPhoneCore.LabelDuplicateRule
<!– Enumeration –> This enumeration defines the different labeling duplicate rules.
Duplicate refers to the condition where a label's text is exactly the same as another label. An example case where this is common is a road where each intersection is its own segment. In such a case, you do not want to label each segment as it would be highly redundant.
Items
Name Summary
OneDuplicateLabelPerQuadrant There may be only one label in each of the four quadrants.
NoDuplicateLabels There may be no duplicate labels.
UnlimitedDuplicateLabels There may be an unlimited number of duplicate labels.
thinkgeo.mapsuite.windowsphonecore.labelduplicaterule.txt · Last modified: 2017/03/16 21:59 (external edit)
