thinkgeo.mapsuite.desktopedition.interactiveoverlay
ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay
This class inherits from Overlay abstract class. This specified overlay describes the interative process with the MapControl using the Mouse or Keyboard.
InteractiveOverlay()
Default constructor of this abstract class.
KeyDown(KeyEventInteractionArguments)
This method will simulate the KeyDown interaction.
This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
KeyUp(KeyEventInteractionArguments)
This method will simulate the KeyUp interaction.
MouseDown(InteractionArguments)
This method will simulate the MouseDown interaction.
  • interactionArguments
    • Description:This parameter represents the interaction auguments for the method.
MouseMove(InteractionArguments)
This method will simulate the MouseMove interaction.
MouseUp(InteractionArguments)
This method will simulate the MouseUp interaction.
MouseClick(InteractionArguments)
This method will simulate the MouseClick interaction.
MouseDoubleClick(InteractionArguments)
This method will simulate the MouseDoubleClick interaction.
MouseWheel(InteractionArguments)
This method will simulate the MouseWheel interaction.
Refresh(GeoCanvas,RectangleShape)
DrawPreview(GeoCanvas)
Draw(GeoCanvas)
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
KeyDownCore(KeyEventInteractionArguments)
This protected virtual method is the Core method of KeyDown API.
KeyUpCore(KeyEventInteractionArguments)
MouseDownCore(InteractionArguments)
This protected virtual method is the Core method of MouseDown API.
MouseMoveCore(InteractionArguments)
This protected virtual method is the Core method of the MouseMove API.
MouseUpCore(InteractionArguments)
This protected virtual method is the Core method of the MouseUp API.
MouseClickCore(InteractionArguments)
This protected virtual method is the Core method of the MouseClick API.
MouseDoubleClickCore(InteractionArguments)
This protected virtual method is the Core method of the MouseDoubleClick API.
MouseWheelCore(InteractionArguments)
This protected virtual method is the Core method of the MouseWheel API.
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
This event will be fired when MapMouseDown is called.
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
This event will be fired when MapMouseMove is called.
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
This event will be fired when MapMouseUp is called.
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
This event will be fired when MapMouseClick is called.
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
This event will be fired when MapMouseDoubleClick is called.
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
This event will be fired when MapMouseWheel is called.
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
This event will be fired when MapKeyDown is called.
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
This event will be fired when MapKeyUp is called.
DrawCore(GeoCanvas)
This method draws the InterativeInterativeOverlay abstract class. You must override this API in its sub concrete classes, or it will throw a NotImplementedException.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
OnDrawing(DrawingOverlayEventArgs)
OnDrawn(DrawnOverlayEventArgs)
RefreshCore(GeoCanvas,RectangleShape)
DrawPreviewCore(GeoCanvas)
sBM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • e
    • Type:Exception
  • e
    • Type:Exception
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
Attribution
Lock
IsBase
DrawingExceptionMode
IsVisible
TileCache
PreviewTileCache
IsEmpty
DrawingTime
  • Type:TimeSpan
AutoRefreshInterval
  • Type:TimeSpan
xRM=
rxM=
MapMouseDown This event will be fired when the Mouse button is pressed (down) on the Map.
Event Arguments:MapMouseDownInteractiveOverlayEventArgs
MapMouseMove This event will be fired when the Mouse is moved on the Map.
Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseUp This event will be fired when the Mouse button is released (up) on the Map.
Event Arguments:MapMouseUpInteractiveOverlayEventArgs
MapMouseClick This event will be fired when the Mouse button is clicked (mouse up and mouse down in the same postion) on the Map.
Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseDoubleClick This event will be fired when the Mouse button is double-clicked on the Map.
Event Arguments:MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseWheel This event will be fired when the Mouse wheel is scrolled while the cursor is over the Map.
Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
MapKeyDown This event will be fired when the key is pressed down when focusing on the Map.
Event Arguments:MapKeyDownInteractiveOverlayEventArgs
MapKeyUp This event will be fired when the key is released up when focusing on the Map.
Event Arguments:MapKeyUpInteractiveOverlayEventArgs
Drawing N/A
Event Arguments:DrawingOverlayEventArgs
Drawn N/A
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
Event Arguments:DrawingAttributionOverlayEventArgs
DrawnAttribution N/A
Event Arguments:DrawnAttributionOverlayEventArgs
RequestedDrawing N/A
Event Arguments:RequestedDrawingOverlayEventArgs
RequestingDrawing N/A
Event Arguments:RequestingDrawingOverlayEventArgs
thinkgeo.mapsuite.desktopedition.interactiveoverlay.1442545363.txt.gz · Last modified: 2015/09/18 03:02 by admin
