<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.AndroidEdition.Overlay *ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay ThinkGeo.MapSuite.AndroidEdition.TrackInteractiveOverlay
TrackInteractiveOverlay | Default constructor of the class. If you use this constructor, please set the properties correctly or it will use their default values. |
Close | Overlay | This method will simulate the Close interaction. | |
Dispose | Overlay | This method dispose unmanaged resource used in this class. | |
DoubleTap | InteractionArguments | InteractiveOverlay | This method will simulate the DoubleTap interaction. |
Draw | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay with the provided extent in world coordinate. |
GetBoundingBox | Overlay | This method gets a bounding box of the Overlay. | |
GetTrackingShape | This method gets the current Tracking shape. | ||
Initialize | MapArguments | Overlay | This method initializes overlay object. |
LongPress | InteractionArguments | InteractiveOverlay | This method will simulate the LongPress interaction. |
Open | Overlay | This method will simulate the Open interaction. | |
PostTransform | TransformArguments, MapArguments | Overlay | This method will simulate the PostTransform interaction. |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
SingleTap | InteractionArguments | InteractiveOverlay | This method will simulate the SingleTap interaction. |
ToString | Object | ||
TouchDown | InteractionArguments | InteractiveOverlay | This method will simulate the TouchDown interaction. |
TouchMove | InteractionArguments | InteractiveOverlay | This method will simulate the TouchMove interaction. |
TouchPointerDown | InteractionArguments | InteractiveOverlay | This method will simulate the TouchPointerDown interaction. |
TouchUp | InteractionArguments | InteractiveOverlay | This method will simulate the TouchUp interaction. |
CloseCore | Overlay | This protected virtual method is the Core method of Close API. | |
Dispose | Boolean | Overlay(overriden) | |
DoubleTapCore | InteractionArguments | InteractiveOverlay | This protected virtual method is the Core method of MouseDoubleClick API. |
DrawCore | MapArguments, OverlayRefreshType | Overlay(overriden) | |
DrawException | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
DrawExceptionCore | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
EndTracking | This method ends the tracking shape by initialize some variables. | ||
Finalize | Object(overriden) | ||
GetBoundingBoxCore | Overlay | This method returns the bounding box of the Overlay. | |
GetTrackingShapeCore | This is the Core method of GetTrackingShape.You could overrides this method to have your own logic. This method gets the current Tracking shape. | ||
InitializeCore | MapArguments | Overlay(overriden) | |
LongPressCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseDoubleClick logic in its base class InterativeOverlay. |
MemberwiseClone | Object | ||
OnDrawingException | DrawingExceptionOverlayEventArgs | Overlay | This method raises before the overlay is drawing exception. |
OnDrawnException | DrawnExceptionOverlayEventArgs | Overlay | This method raises after the overlay is drawn exception. |
OnMouseMoved | MouseMovedTrackInteractiveOverlayEventArgs | This event will be fired when mouse moved a vertex to the Tracking shape. | |
OnTrackEnded | TrackEndedTrackInteractiveOverlayEventArgs | This event will be fired after the end of Tracking a shape. | |
OnTrackEnding | TrackEndingTrackInteractiveOverlayEventArgs | This event will be fired before the end of Tracking a shape. | |
OnTrackStarted | TrackStartedTrackInteractiveOverlayEventArgs | This event will be fired after the start of Tracking a shape. | |
OnTrackStarting | TrackStartingTrackInteractiveOverlayEventArgs | This event will be fired before the start of Tracking a shape. | |
OnVertexAdded | VertexAddedTrackInteractiveOverlayEventArgs | This event will be fired after adding a vertex to the Tracking shape. | |
OnVertexAdding | VertexAddingTrackInteractiveOverlayEventArgs | This event will be fired before adding a vertex to the Tracking shape. | |
OpenCore | Overlay | This protected virtual method is the Core method of Open API. | |
PostTransformCore | TransformArguments, MapArguments | Overlay(overriden) | |
RefreshCore | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
SingleTapCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseClick logic in its base class. |
TouchDownCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseDown logic in its base class InterativeOverlay. |
TouchMoveCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseMove logic in its base class InterativeOverlay. |
TouchPointerDownCore | InteractionArguments | InteractiveOverlay | This protected virtual method is the Core method of TouchPointerDown API. |
TouchUpCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseUp logic in its base class InterativeOverlay. |
Attribution | String | Overlay | Gets or sets the attribution for this overlay. |
Bitmap | Bitmap | ||
DrawingExceptionMode | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
DrawingQuality | DrawingQuality | Overlay | Gets or sets the drawingQuality for this overlay. |
InteractiveView | TileView | InteractiveOverlay | Gets or sets Overlay's the interactiveView. |
IsEmpty | Boolean | Overlay(overriden) | This property override the logic in its base class by watching the feature count in trackShapeLayer. If it is empty ,we can skip drawing it for better performance. |
IsVisible | Boolean | Overlay | Gets or sets if this overlay is visible. |
MapArguments | MapArguments | Overlay | Gets or sets the mapArguments for this overlay. |
Name | String | Overlay | Gets or sets the name of this overaly. |
Opacity | Double | Overlay | Gets or sets the opacity for this overlay. |
TrackMode | TrackMode | Gets a mode of TrackOverlay. | |
TrackShapeLayer | InMemoryFeatureLayer | This property gets the TrackShape layers which holds the track shapes. | |
VertexCountInQuarter | Int32 |
IsInTracking | Boolean | This property gets or sets to sign that if there is any shape being tracking. | |
Vertices | Collection<Vertex> | This property gets the vertices to make up the track shape. This is a protected property which probablly need to be used in its sub classes. |
DrawingException | DrawingExceptionOverlayEventArgs | Overlay | Occurs before exception is drawing on map. |
DrawnException | DrawnExceptionOverlayEventArgs | Overlay | Occurs after exception is drawn on map. |
MouseMoved | MouseMovedTrackInteractiveOverlayEventArgs | This event will be fired when mouse moved on the vertex of tracking shape. | |
TrackEnded | TrackEndedTrackInteractiveOverlayEventArgs | This event will be fired after the end of tracking shape. | |
TrackEnding | TrackEndingTrackInteractiveOverlayEventArgs | This event will be fired before the end of tracking shape. | |
TrackStarted | TrackStartedTrackInteractiveOverlayEventArgs | This event will be fired after the start of tracking shape. | |
TrackStarting | TrackStartingTrackInteractiveOverlayEventArgs | This event will be fired before the start of tracking shape. | |
VertexAdded | VertexAddedTrackInteractiveOverlayEventArgs | This event will be fired after a vertex added to the tracking shape. | |
VertexAdding | VertexAddingTrackInteractiveOverlayEventArgs | This event will be fired before a vertex added to the tracking shape. |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay –> Go Back
This method is the concrete wrapper for its virtual Core method.
| InteractiveResult<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveResult –> | Interaction results of this method. |
| e | InteractionArguments<!– ThinkGeo.MapSuite.AndroidEdition.InteractionArguments –> | This parameter is the interaction auguments for the method. |
<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | This parameter maintains current map information for calculating mechanism. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.AndroidEdition.OverlayRefreshType –> | This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode. |
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicating the bounding box of this overlay. |
This method is the concrete wrapper for the abstract method GetTrackingShapeCore. This method draws the representation of the overlay based on the extent you provided.
| BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | Returns a shape represents the current status of tracking shape. |
<!– ThinkGeo.MapSuite.AndroidEdition.TrackInteractiveOverlay –> Go Back
This is a wrapper method for the virtual method InitializeCore.
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | This parameter maintains the transfrom information for calculating transform. |
| isDisposing | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay(overriden) –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | |
| geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
| exception | Exception<!– System.Exception –> |
| ex | Exception<!– System.Exception –> |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Overlay. |
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.AndroidEdition.InteractionArguments –> | This parameter is the interaction auguments for the method. |
<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay(overriden) –> Go Back
| args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawingExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
| args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawnExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
| e | MouseMovedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.MouseMovedTrackInteractiveOverlayEventArgs –> | The MouseMovedTrackInteractiveOverlayEventArgs passed for the event raised. |
| e | TrackEndedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.TrackEndedTrackInteractiveOverlayEventArgs –> | The TrackEndedTrackInteractiveOverlayEventArgs passed for the event raised. |
| e | TrackEndingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.TrackEndingTrackInteractiveOverlayEventArgs –> | The TrackEndingTrackInteractiveOverlayEventArgs passed for the event raised. |
| e | TrackStartedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.TrackStartedTrackInteractiveOverlayEventArgs –> | The TrackStartedTrackInteractiveOverlayEventArgs passed for the event raised. |
| e | TrackStartingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.TrackStartingTrackInteractiveOverlayEventArgs –> | The TrackStartingTrackInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexAddedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexAddedTrackInteractiveOverlayEventArgs –> | The VertexAddedTrackInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexAddingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexAddingTrackInteractiveOverlayEventArgs –> | The VertexAddingTrackInteractiveOverlayEventArgs passed for the event raised. |
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | |
| Bitmap<!– Android.Graphics.Bitmap –> |
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
| TileView<!– ThinkGeo.MapSuite.AndroidEdition.TileView –> |
The default mode is TrackMode.None which means you cannot draw or edit features at client. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you could add point, line or polygon to the FeatureOverlay. Setting the mode to TrackMode.Edit, you could edit the shapes at the client side.
| TrackMode<!– ThinkGeo.MapSuite.AndroidEdition.TrackMode –> |
| InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –> |
| Collection<Vertex><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Vertex} –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
