<!– Class –> Serves as the base class that defines the properties and methods shared by all types of overlays.
The <strong>Overlay</strong> has as similar concept to the Layer. Different types of overlays stack over each other to form a map. An overlay object is responsible for getting the configuration information from the user and serializing it to a JSON string to control the client Javascript library, which creates the appropriate client layer.Usually, an overlay represents an image with a transparent background that is laid upon other overlay, such as a <strong>LayerOverlay</strong> or <strong>WmsOverlay</strong>. While the <strong>MarkerOverlay</strong> will not be rendered as an image, it actually represents a <strong>div</strong> that holds several marker images at the client side.There are basically two kinds of overlays: base overlays and non-base overlays.A base overlay has its <strong>IsBaseOverlay</strong> property set to true. It is displayed as the background image of the map. In an <strong>OverlaySwitcher</strong>, there is a radio button beside its name. There can be only one base overlay displayed at a time. You can click the radio button to switch the base overlay that is displayed.A non-base overlay has a false <strong>IsBaseOverlay</strong> property. These overlays can overlap the base overlay and/or each other. They are displayed in the <strong>OverlaySwitcher</strong> with a check box beside their name. You can click the check box to show or hide a specific overlay.
*System.Object ThinkGeo.MapSuite.WebEdition.Overlay *ThinkGeo.MapSuite.WebEdition.AdornmentOverlay *ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay *ThinkGeo.MapSuite.WebEdition.BingMapsOverlay *ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay *ThinkGeo.MapSuite.WebEdition.FeatureOverlay *ThinkGeo.MapSuite.WebEdition.FeatureSourceMarkerOverlay *ThinkGeo.MapSuite.WebEdition.GoogleOverlay *ThinkGeo.MapSuite.WebEdition.HighlightFeatureOverlay *ThinkGeo.MapSuite.WebEdition.InMemoryMarkerOverlay *ThinkGeo.MapSuite.WebEdition.LayerOverlay *ThinkGeo.MapSuite.WebEdition.MarkerOverlay *ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay *ThinkGeo.MapSuite.WebEdition.SimpleMarkerOverlay *ThinkGeo.MapSuite.WebEdition.WmsOverlay *ThinkGeo.MapSuite.WebEdition.WmtsOverlay ***ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Returns a JSON string which contains the information for creating an overlay at the client side. | ||
![]() | Object |
![]() | Object | ||
![]() | Object | ||
![]() | EventArgs | Raises the Tick event of the MarkerOverlay. | |
![]() | Page | Registers a Javascript library URL string to the client HTML page. |
![]() | String | ||
![]() | TimeSpan | Gets or sets the time interval in which the MarkerOverlay refreshes itself. | |
![]() | String | Gets the identifier for the overlay to be found. | |
![]() | Boolean | Gets or sets a value that indicates whether the overlay is a base overlay. | |
![]() | Boolean | Gets or sets a value that indicates whether the overlay is visible on the map. | |
![]() | Boolean | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. | |
![]() | String | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. | |
![]() | Single | Gets or sets the opacity level of the overlay. |
![]() | Boolean | Indicates whether the overlay supports tick event. | |
![]() | String | Gets a string that indicates which type the overlay is. |
![]() | EventArgs | Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server. |
Initialize an instance of the Overlay class.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Overlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Overlay.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Overlay.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Overlay.28String.29</a>
id | String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Overlay.28String.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Overlay.28String.2C_Boolean.29</a>
id | String<!– System.String –> | |
isBaseOverlay | Boolean<!– System.Boolean –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#ToJson.28.29</a>
String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#OnTick.28EventArgs.29</a>
e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Attribution</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#AutoRefreshInterval</a>
Return Type |
TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Id</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#IsBaseOverlay</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#IsVisible</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#IsVisibleInOverlaySwitcher</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#Name</a>
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type |
Single<!– System.Single –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#HasTickEvent</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Overlay#OverlayType</a>
Return Type |
Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
