thinkgeo.mapsuite.iosedition.trackinteractiveoverlay
Table of Contents
ThinkGeo.MapSuite.iOSEdition.TrackInteractiveOverlay
<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
Public MethodTrackInteractiveOverlay Default constructor of the class. If you use this constructor, please set the properties correctly or it will use their default values.
Public MethodClose Overlay Closes this instance.
Public MethodDispose Overlay Disposes this instance.
Public MethodDoubleTap InteractionArguments InteractiveOverlay Doubles the tap.
Public MethodDraw MapArguments, OverlayRefreshType Overlay This method draws the overlay by the specified arguments.
Public MethodGetBoundingBox Overlay Gets the bounding box.
Public MethodGetTrackingShape This method gets the current Tracking shape.
Public MethodGetType Object
Public MethodInitialize MapArguments Overlay Initializes the specified map arguments.
Public MethodLongPress InteractionArguments InteractiveOverlay Longs the press.
Public MethodPostTransform TransformArguments, MapArguments Overlay Posts the transform for the overlay.
Public MethodRefresh Overlay Refreshes this instance.
Public MethodSingleTap InteractionArguments InteractiveOverlay Singles the tap.
Public MethodToString Object
Public MethodTouchDown InteractionArguments InteractiveOverlay Touches down.
Public MethodTouchMove InteractionArguments InteractiveOverlay Touches the move.
Public MethodTouchPointerDown InteractionArguments InteractiveOverlay Touches the pointer down.
Public MethodTouchUp InteractionArguments InteractiveOverlay Touches up.
Protected MethodCloseCore Overlay Closes the core.
Protected MethodDispose Boolean Overlay(overriden)
Protected MethodDoubleTapCore InteractionArguments InteractiveOverlay Doubles the tap core.
Protected MethodDrawCore MapArguments, OverlayRefreshType Overlay(overriden) This method draws the TrackInterativeOverlay.
Protected MethodDrawException GeoCanvas, Exception Overlay Draws the exception.
Protected MethodDrawExceptionCore GeoCanvas, Exception Overlay Draws the exception core.
Protected MethodEndTracking This method ends the tracking shape by initialize some variables.
Protected MethodFinalize Object(overriden)
Protected MethodGetBoundingBoxCore Overlay Gets the bounding box core.
Protected MethodGetTrackingShapeCore This is the Core method of GetTrackingShape.You could overrides this method to have your own logic. This method gets the current Tracking shape.
Protected MethodInitializeCore MapArguments Overlay(overriden)
Protected MethodLongPressCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseDoubleClick logic in its base class InterativeOverlay.
Protected MethodOnDrawingException DrawingExceptionOverlayEventArgs Overlay Handles the event.
Protected MethodOnDrawnException DrawnExceptionOverlayEventArgs Overlay Handles the event.
Protected MethodOnTouchMoved TouchMovedTrackInteractiveOverlayEventArgs This event will be fired when mouse moved a vertex to the Tracking shape.
Protected MethodOnTrackEnded TrackEndedTrackInteractiveOverlayEventArgs This event will be fired after the end of Tracking a shape.
Protected MethodOnTrackEnding TrackEndingTrackInteractiveOverlayEventArgs This event will be fired before the end of Tracking a shape.
Protected MethodOnTrackStarted TrackStartedTrackInteractiveOverlayEventArgs This event will be fired after the start of Tracking a shape.
Protected MethodOnTrackStarting TrackStartingTrackInteractiveOverlayEventArgs This event will be fired before the start of Tracking a shape.
Protected MethodOnVertexAdded VertexAddedTrackInteractiveOverlayEventArgs This event will be fired after adding a vertex to the Tracking shape.
Protected MethodOnVertexAdding VertexAddingTrackInteractiveOverlayEventArgs This event will be fired before adding a vertex to the Tracking shape.
Protected MethodPostTransformCore TransformArguments, MapArguments Overlay(overriden)
Protected MethodRefreshCore Overlay Refreshes the core.
Protected MethodSingleTapCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseClick logic in its base class.
Protected MethodTouchDownCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseDown logic in its base class InterativeOverlay.
Protected MethodTouchMoveCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseMove logic in its base class InterativeOverlay.
Protected MethodTouchPointerDownCore InteractionArguments InteractiveOverlay Touches the pointer down core.
Protected MethodTouchUpCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseUp logic in its base class InterativeOverlay.
Public PropertyAttribution String Overlay Gets or sets the attribution.
Public PropertyDrawingExceptionMode DrawingExceptionMode Overlay This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
Public PropertyDrawingQuality DrawingQuality Overlay Gets or sets the drawing quality.
Public PropertyInteractiveView TileView InteractiveOverlay Gets or sets the interactive view.
Public PropertyIsEmpty Boolean Overlay(overriden) This property override the logic in its base class by watching the feature count in trackShapeLayer. If it is empty ,we can skip drawing it for better performance.
Public PropertyIsInTracking Boolean This property gets or sets to sign that if there is any shape being tracking.
Public PropertyIsVisible Boolean Overlay Gets or sets a value indicating whether this instance is visible.
Public PropertyMapArguments MapArguments Overlay Gets or sets the map arguments.
Public PropertyName String Overlay Gets or sets the name.
Public PropertyOpacity Double Overlay Gets or sets the opacity.
Public PropertyOverlayView UIView Overlay Gets or sets the overlay view.
Public PropertyTrackMode TrackMode Gets a mode of TrackOverlay.
Public PropertyTrackShapeLayer InMemoryFeatureLayer This property gets the TrackShape layers which holds the track shapes.
Protected PropertyVertices Collection<Vertex> This property gets the vertices to make up the track shape. This is a protected property which probablly need to be used in its sub classes.
Public EventDrawingException DrawingExceptionOverlayEventArgs Overlay This event raises when exception.
Public EventDrawnException DrawnExceptionOverlayEventArgs Overlay This event raises when exception.
Public EventTouchMoved TouchMovedTrackInteractiveOverlayEventArgs This event will be fired when mouse moved on the vertex of tracking shape.
Public EventTrackEnded TrackEndedTrackInteractiveOverlayEventArgs This event will be fired after the end of tracking shape.
Public EventTrackEnding TrackEndingTrackInteractiveOverlayEventArgs This event will be fired before the end of tracking shape.
Public EventTrackStarted TrackStartedTrackInteractiveOverlayEventArgs This event will be fired after the start of tracking shape.
Public EventTrackStarting TrackStartingTrackInteractiveOverlayEventArgs This event will be fired before the start of tracking shape.
Public EventVertexAdded VertexAddedTrackInteractiveOverlayEventArgs This event will be fired after a vertex added to the tracking shape.
Public EventVertexAdding VertexAddingTrackInteractiveOverlayEventArgs This event will be fired before a vertex added to the tracking shape.
TrackInteractiveOverlay()
Name Type Description
Go Back
Close()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.iOSEdition.Overlay –> Go Back
Dispose()
DoubleTap(InteractionArguments)
Doubles the tap.
InteractiveResult<!– ThinkGeo.MapSuite.iOSEdition.InteractiveResult –> InteractiveResult.
e InteractionArguments<!– ThinkGeo.MapSuite.iOSEdition.InteractionArguments –> The e.
<!– ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay –> Go Back
Draw(MapArguments, OverlayRefreshType)
mapArguments MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> This parameter indicates an mapArguments to draw the overlay.
refreshType OverlayRefreshType<!– ThinkGeo.MapSuite.iOSEdition.OverlayRefreshType –> This parameter indicates whether this overlay needs to be refresh or not.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> A RectangleShape value for the overlay.
Int32<!– System.Int32 –>
GetTrackingShape()
This method is the concrete wrapper for the abstract method GetTrackingShapeCore. This method draws the representation of the overlay based on the extent you provided.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> Returns a shape represents the current status of tracking shape.
<!– ThinkGeo.MapSuite.iOSEdition.TrackInteractiveOverlay –> Go Back
Type<!– System.Type –>
Initialize(MapArguments)
mapArguments MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –> The map arguments.
LongPress(InteractionArguments)
Longs the press.
PostTransform(TransformArguments, MapArguments)
transformInfo TransformArguments<!– ThinkGeo.MapSuite.iOSEdition.TransformArguments –> The transform information.
Refresh()
SingleTap(InteractionArguments)
Singles the tap.
String<!– System.String –>
TouchDown(InteractionArguments)
Touches down.
TouchMove(InteractionArguments)
Touches the move.
TouchPointerDown(InteractionArguments)
TouchUp(InteractionArguments)
Touches up.
CloseCore()
Closes the core.
Dispose(Boolean)
isDisposing Boolean<!– System.Boolean –>
<!– ThinkGeo.MapSuite.iOSEdition.Overlay(overriden) –> Go Back
DoubleTapCore(InteractionArguments)
DrawCore(MapArguments, OverlayRefreshType)
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
DrawException(GeoCanvas, Exception)
geoCanvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> The geo canvas.
exception Exception<!– System.Exception –> The exception.
DrawExceptionCore(GeoCanvas, Exception)
ex Exception<!– System.Exception –> The ex.
EndTracking()
GetBoundingBoxCore()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> RectangleShape.
GetTrackingShapeCore()
InitializeCore(MapArguments)
mapArgument MapArguments<!– ThinkGeo.MapSuite.iOSEdition.MapArguments –>
LongPressCore(InteractionArguments)
InteractiveResult<!– ThinkGeo.MapSuite.iOSEdition.InteractiveResult –> Interaction results of this method.
interactionArguments InteractionArguments<!– ThinkGeo.MapSuite.iOSEdition.InteractionArguments –> This parameter is the interaction auguments for the method.
<!– ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay(overriden) –> Go Back
OnDrawingException(DrawingExceptionOverlayEventArgs)
Handles the event.
args DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawingExceptionOverlayEventArgs –> The instance containing the event data.
OnDrawnException(DrawnExceptionOverlayEventArgs)
Handles the event.
args DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.DrawnExceptionOverlayEventArgs –> The instance containing the event data.
OnTouchMoved(TouchMovedTrackInteractiveOverlayEventArgs)
e TouchMovedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.TouchMovedTrackInteractiveOverlayEventArgs –> The MouseMovedTrackInteractiveOverlayEventArgs passed for the event raised.
OnTrackEnded(TrackEndedTrackInteractiveOverlayEventArgs)
e TrackEndedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.TrackEndedTrackInteractiveOverlayEventArgs –> The TrackEndedTrackInteractiveOverlayEventArgs passed for the event raised.
OnTrackEnding(TrackEndingTrackInteractiveOverlayEventArgs)
e TrackEndingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.TrackEndingTrackInteractiveOverlayEventArgs –> The TrackEndingTrackInteractiveOverlayEventArgs passed for the event raised.
OnTrackStarted(TrackStartedTrackInteractiveOverlayEventArgs)
e TrackStartedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.TrackStartedTrackInteractiveOverlayEventArgs –> The TrackStartedTrackInteractiveOverlayEventArgs passed for the event raised.
OnTrackStarting(TrackStartingTrackInteractiveOverlayEventArgs)
e TrackStartingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.TrackStartingTrackInteractiveOverlayEventArgs –> The TrackStartingTrackInteractiveOverlayEventArgs passed for the event raised.
OnVertexAdded(VertexAddedTrackInteractiveOverlayEventArgs)
e VertexAddedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.VertexAddedTrackInteractiveOverlayEventArgs –> The VertexAddedTrackInteractiveOverlayEventArgs passed for the event raised.
OnVertexAdding(VertexAddingTrackInteractiveOverlayEventArgs)
e VertexAddingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.iOSEdition.VertexAddingTrackInteractiveOverlayEventArgs –> The VertexAddingTrackInteractiveOverlayEventArgs passed for the event raised.
PostTransformCore(TransformArguments, MapArguments)
RefreshCore()
Refreshes the core.
SingleTapCore(InteractionArguments)
TouchDownCore(InteractionArguments)
TouchMoveCore(InteractionArguments)
TouchPointerDownCore(InteractionArguments)
TouchUpCore(InteractionArguments)
Attribution
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingQuality
Return Type
DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –>
InteractiveView
Return Type
TileView<!– ThinkGeo.MapSuite.iOSEdition.TileView –>
IsEmpty
Return Type
IsInTracking
Return Type
IsVisible
Return Type
MapArguments
Return Type
Return Type
Opacity
Return Type
Double<!– System.Double –>
OverlayView
Return Type
UIView<!– MonoTouch.UIKit.UIView –>
TrackMode
The default mode is TrackMode.None which means you cannot draw or edit features at client. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you could add point, line or polygon to the FeatureOverlay. Setting the mode to TrackMode.Edit, you could edit the shapes at the client side.
Return Type
TrackMode<!– ThinkGeo.MapSuite.iOSEdition.TrackMode –>
TrackShapeLayer
Return Type
InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –>
Vertices
Return Type
Collection<Vertex><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.Vertex} –>
DrawingException
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
TouchMoved
Event Arguments
Event Arguments
TrackEnded
Event Arguments
Event Arguments
TrackEnding
Event Arguments
Event Arguments
TrackStarted
Event Arguments
Event Arguments
TrackStarting
Event Arguments
Event Arguments
VertexAdded
Event Arguments
Event Arguments
VertexAdding
Event Arguments
Event Arguments
NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
thinkgeo.mapsuite.iosedition.trackinteractiveoverlay.1440040131.txt.gz · Last modified: 2015/09/21 08:34 (external edit)
