<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.SilverlightEdition.Overlay *ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay ThinkGeo.MapSuite.SilverlightEdition.ExtentInteractiveOverlay
ExtentInteractiveOverlay | Default constructor of the class. If you use thi constructor, please set the properties correctly or it will use their default values. |
Draw | RectangleShape, OverlayDrawType | Overlay | Zooms the overlay only to the extent that you specify. |
Initialize | Map | Overlay | This method initializes the overlay canvas such as width, height and z-index for first time. |
MouseClick | InteractionArguments | InteractiveOverlay | This method will simulate the MouseClick interaction. |
MouseDoubleClick | InteractionArguments | InteractiveOverlay | This method will simulate the MouseDoubleClick interaction. |
MouseDown | InteractionArguments | InteractiveOverlay | This method will simulate the MouseDown interaction. |
MouseMove | InteractionArguments | InteractiveOverlay | This method will simulate the MouseMove interaction. |
MouseUp | InteractionArguments | InteractiveOverlay | This method will simulate the MouseUp interaction. |
MouseWheel | InteractionArguments | InteractiveOverlay | This method will simulate the MouseWheel interaction. |
Refresh | Overlay | This method re-draws this overlay in current extent. | |
ToScreenCoordinate | Point | Overlay | This method returns a screen point from a point shape in world coordinates. |
ToScreenCoordinate | Double, Double | Overlay | This method returns a point shape in screen coordinates from the specified X, Y world coordinates. |
ToScreenCoordinate | PointShape | Overlay | This method returns a screen point from a point shape in world coordinates. |
ToString | Object | ||
ToWorldCoordinate | Double, Double | Overlay | This method returns a point shape in world coordinates from the specified X, Y screen coordinates. |
ToWorldCoordinate | PointShape | Overlay | This method returns a point shape in world coordinates from a ScreenPointF structure. |
ToWorldCoordinate | Point | Overlay | This method returns a point shape in world coordinates from a ScreenPointF structure. |
DrawAttributionCore | GeoCanvas | Overlay | |
DrawCore | RectangleShape | Overlay(overriden) | |
InitializeCore | Overlay(overriden) | This method initializes the overlay canvas such as width, height and z-index for first time. | |
MemberwiseClone | Object | ||
MouseClickCore | InteractionArguments | InteractiveOverlay | This protected virtual method is the Core method of MouseClick API. |
MouseDoubleClickCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseDoubleClick logic in its base class InterativeOverlay. |
MouseDownCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseDown logic in its base class InterativeOverlay. |
MouseMoveCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseMove logic in its base class InterativeOverlay. |
MouseUpCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseUp logic in its base class InterativeOverlay. |
MouseWheelCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseWheel logic in its base class InterativeOverlay. |
OnDrawingAttribution | DrawingAttributionOverlayEventArgs | Overlay | |
OnDrawnAttribution | DrawnAttributionOverlayEventArgs | Overlay | |
OnMapMouseClick | MapMouseClickInteractiveOverlayEventArgs | InteractiveOverlay | This event will be fired when MapMouseClick is called. |
OnMapMouseDoubleClick | MapMouseDoubleClickInteractiveOverlayEventArgs | InteractiveOverlay | This event will be fired when MapMouseDoubleClick is called. |
OnMapMouseDown | MapMouseDownInteractiveOverlayEventArgs | InteractiveOverlay | This event will be fired when MapMouseDown is called. |
OnMapMouseMove | MapMouseMoveInteractiveOverlayEventArgs | InteractiveOverlay | This event will be fired when MapMouseMove is called. |
OnMapMouseUp | MapMouseUpInteractiveOverlayEventArgs | InteractiveOverlay | This event will be fired when MapMouseUp is called. |
OnMapMouseWheel | MapMouseWheelInteractiveOverlayEventArgs | InteractiveOverlay | This event will be fired when MapMouseWheel is called. |
PanAnimationCompletedCore | Overlay | This method raised when Panning animation plays completed. | |
ZoomStoryCompletedCore | Overlay | This method raised when zooming animation plays completed. |
Attribution | String | Overlay | |
MouseMoveInterval | TimeSpan | InteractiveOverlay | |
Name | String | Overlay | Gets or sets the name of an overlay which will display in the OverlaySwitcher. |
Opacity | Double | Overlay | Gets or sets the opacity level of the overlay. |
OverlayElement | FrameworkElement | Overlay | An FrameworkElement that contains the overlay. |
PanFrameX | SplineDoubleKeyFrame | Overlay | Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation. |
PanFrameY | SplineDoubleKeyFrame | Overlay | Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation. |
StoryboardForPanning | Storyboard | Overlay | Gets the Storyboard object for panning. |
StoryboardForZooming | Storyboard | Overlay | Gets the Storyboard object for zooming. |
TransitionEffect | TransitionEffect | Overlay | Gets or Sets the transition effect to use when the map is panned or zoomed. |
Visibility | Visibility | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
ZIndex | Int32 | Overlay | Get or set z-index of overlay, The value is bigger, and the order is higher. |
ZoomFrameX | SplineDoubleKeyFrame | Overlay | Gets the SplineDoubleKeyFrame for zooming. |
ZoomFrameY | SplineDoubleKeyFrame | Overlay | Gets the SplineDoubleKeyFrame for zooming. |
MapInfo | Map | Overlay | Gets or sets current map information. |
ScaleTransform | ScaleTransform | Overlay | Gets the ScaleTransform object of this overlay. |
TransformGroup | TransformGroup | Overlay | Gets the TranslateGroup object for panning and zooming. |
TranslateTransform | TranslateTransform | Overlay | Gets the TranslateTransform object of this overlay. |
The overlay will be panned to the center and zoomlevel of the extent that you specify.
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | The new world extent of the map. |
| overlayDrawType | OverlayDrawType<!– ThinkGeo.MapSuite.SilverlightEdition.OverlayDrawType –> | The enum value indecating that the map draws features or not. |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay –> Go Back
| currentMap | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | Current map information. |
This method is the concrete wrapper for its virtual Core method.
| InteractiveResult<!– ThinkGeo.MapSuite.SilverlightEdition.InteractiveResult –> | Interaction results of this method. |
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments –> | This parameter is the interaction auguments for the method. |
<!– ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay –> Go Back
This method converts the coordinates of a point shape to a point in screen coordinates.
| PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A screen point in pixels. |
| worldCoordinate | Point<!– System.Windows.Point –> | A point in world coordinates. |
This method converts X, Y world coordinates to a point in screen coordinates.
| worldX | Double<!– System.Double –> | The X world coordinate. |
| worldY | Double<!– System.Double –> | The Y world coordinate. |
| worldCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A point shape in world coordinates. |
This method converts X, Y screen coordinates to a point shape in world coodinates.
| screenX | Double<!– System.Double –> | The X-value in pixels referenced to the screen origin. |
| screenY | Double<!– System.Double –> | The Y-value in pixels referenced to the screen origin. |
This method converts a screen point to a point in world coordinates.
| screenCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | The point (in screen coordinates) to convert to world coordinates. |
| screenCoordinate | Point<!– System.Windows.Point –> | The point (in screen coordinates) to convert to world coordinates. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.SilverlightCore.GeoCanvas –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay(overriden) –> Go Back
<!– ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay(overriden) –> Go Back
| args | DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawingAttributionOverlayEventArgs –> |
| args | DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawnAttributionOverlayEventArgs –> |
| e | MapMouseClickInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseClickInteractiveOverlayEventArgs –> | The MapMouseClickInteractiveOverlayEventArgs passed for the event raised. |
| e | MapMouseDoubleClickInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseDoubleClickInteractiveOverlayEventArgs –> | The MapMouseDoubleClickInteractiveOverlayEventArgs passed for the event raised. |
| e | MapMouseDownInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs –> | The MapMouseDownInteractiveOverlayEventArgs passed for the event raised. |
| e | MapMouseMoveInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs –> | The MapMouseMoveInteractiveOverlayEventArgs passed for the event raised. |
| e | MapMouseUpInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseUpInteractiveOverlayEventArgs –> | The MapMouseUpInteractiveOverlayEventArgs passed for the event raised. |
| e | MapMouseWheelInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs –> | The MapMouseWheelInteractiveOverlayEventArgs passed for the event raised. |
| TimeSpan<!– System.TimeSpan –> |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent(1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
| FrameworkElement<!– System.Windows.FrameworkElement –> |
| SplineDoubleKeyFrame<!– System.Windows.Media.Animation.SplineDoubleKeyFrame –> |
| Storyboard<!– System.Windows.Media.Animation.Storyboard –> |
| TransitionEffect<!– ThinkGeo.MapSuite.SilverlightEdition.TransitionEffect –> |
| Visibility<!– System.Windows.Visibility –> |
| ScaleTransform<!– System.Windows.Media.ScaleTransform –> |
| TransformGroup<!– System.Windows.Media.TransformGroup –> |
| TranslateTransform<!– System.Windows.Media.TranslateTransform –> |
| Event Arguments |
| Event Arguments |
This event will be fired when Mouse clicked(mouse up and mouse down in the same postion) on the Map.
| Event Arguments |
This event will be fired when Mouse double clicked on the Map.
| Event Arguments |
This event will be fired when Mouse pressed Down on the Map.
| Event Arguments |
This event will be fired when Mouse moved on the Map.
| Event Arguments |
This event will be fired when Mouse released up on the Map.
| Event Arguments |
This event will be fired when Mouse wheel on the Map.
| Event Arguments |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
