thinkgeo.mapsuite.routing.routingengine
Table of Contents
ThinkGeo.MapSuite.Routing.RoutingEngine
<!– Class –> This class is for finding a route.
The RoutingEngine class is a high level object that supports finding route functions. We only support two-point routes; multi-point routes are not supported at this time. You can also define service ranges based on limits of speed and time.
Public MethodRoutingEngine This is a constructor for the class.
Public MethodRoutingEngine RoutingSource This is a constructor for the class.
Public MethodRoutingEngine RoutingSource, FeatureSource This is a constructor for the class.
Public MethodRoutingEngine RoutingSource, RoutingAlgorithm This is a constructor for the class.
Public MethodRoutingEngine RoutingSource, RoutingAlgorithm, FeatureSource This is a constructor for the class.
Public MethodRoutingEngine RoutingSource, RoutingAlgorithm, FeatureSource, GeographyUnit This is a constructor for the class.
Public MethodRoutingEngine RoutingSource, RoutingAlgorithm, FeatureSource, GeographyUnit, DistanceUnit This is a constructor for the class.
Public MethodGenerateServiceArea String, TimeSpan, Single, SpeedUnit, Double, GeographyUnit
Public MethodGenerateServiceArea String, TimeSpan, Single, SpeedUnit This method returns a polygon that represents the service area around any location on a map.
Public MethodGenerateServiceArea PointShape, TimeSpan, Single, SpeedUnit, Double, GeographyUnit
Public MethodGenerateServiceArea PointShape, TimeSpan, Single, SpeedUnit This method returns a polygon that represents the service area around any location on a map.
Public MethodGenerateServiceArea String, TimeSpan, Double, GeographyUnit
Public MethodGenerateServiceArea PointShape, TimeSpan, Double, GeographyUnit
Public MethodGenerateServiceArea Double, Double, TimeSpan, Single, SpeedUnit This method returns a polygon that represents the service area around any location on a map.
Public MethodStatic MemberGetAngleBetweenTwoLines LineShape, LineShape This method returns the angle between two lines.
Public MethodStatic MemberGetDrivingDirection LineShape, LineShape This method returns the DrivingDirection based on the from line shape.
Public MethodGetRoute String, String, IEnumerable<String>, Int32
Public MethodGetRoute String, String This method returns the routing path based on two feature IDs that represent two routeSegments.
Public MethodGetRoute String, IEnumerable<String>, Int32
Public MethodGetRoute PointShape, PointShape, IEnumerable<PointShape>, Int32
Public MethodGetRoute PointShape, IEnumerable<PointShape>, Int32
Public MethodGetRoute PointShape, PointShape This method returns the routing path based on two points.
Public MethodGetRouteSegments String, String This method returns a sequential routeSegments collection consisting of the route based on RoutingSource and does not use a FeatureSource.
Public MethodGetType Object
Public MethodToString Object
Protected MethodGetRouteCore String, String, IEnumerable<String>, Int32
Protected MethodGetRouteCoreWithPoints PointShape, PointShape, IEnumerable<PointShape>, Int32
Protected MethodOnGeneratingServiceArea GeneratingServiceAreaRoutingEngineEventArgs This method allows you to raise the GeneratingServiceArea event from a derived class.
Protected MethodOnGettingRouteViaVisitStops GettingRouteViaVisitStopsRoutingEngineEventArgs This method allows you to raise the GetRouteViaVisitStops event from a derived class.
Public PropertyDistanceUnit DistanceUnit Gets or sets a value that represents the distance unit of the route.
Public PropertyFeatureSource FeatureSource Gets or sets a value that represents the FeatureSource used for finding the route.
Public PropertyGeographyUnit GeographyUnit Gets or sets a value that represents the geography unit of the FeatureSource.
Public PropertyRoutingAlgorithm RoutingAlgorithm Gets or sets a value that represents the routingAlgorithm used for finding the route.
Public PropertyRoutingResultsType RoutingResultsType Gets or sets a value that represents how much data is returned in the routing results.
Public PropertyRoutingSource RoutingSource Gets or sets a routingSource object for finding the route.
Public EventGeneratingServiceArea GeneratingServiceAreaRoutingEngineEventArgs This event is called during the generating service area.
Public EventGettingRouteViaVisitStops GettingRouteViaVisitStopsRoutingEngineEventArgs This event is called during the calculating best visit sequence
RoutingEngine()
The default settings are: RoutingSource is null, routingAlgorithm is Dijkstra, FeatureSource is null, GeographyUnit is DecimalDegree, DistanceUnit is Kilometer.
Name Type Description
Go Back
RoutingEngine(RoutingSource)
routingSource RoutingSource<!– ThinkGeo.MapSuite.Routing.RoutingSource –>
Go Back
RoutingEngine(RoutingSource, FeatureSource)
featureSource FeatureSource<!– ThinkGeo.MapSuite.Core.FeatureSource –>
Go Back
RoutingEngine(RoutingSource, RoutingAlgorithm)
routingAlgorithm RoutingAlgorithm<!– ThinkGeo.MapSuite.Routing.RoutingAlgorithm –>
Go Back
RoutingEngine(RoutingSource, RoutingAlgorithm, FeatureSource)
Go Back
RoutingEngine(RoutingSource, RoutingAlgorithm, FeatureSource, GeographyUnit)
geographyUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –>
Go Back
RoutingEngine(RoutingSource, RoutingAlgorithm, FeatureSource, GeographyUnit, DistanceUnit)
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GenerateServiceArea(String, TimeSpan, Single, SpeedUnit, Double, GeographyUnit)
PolygonShape<!– ThinkGeo.MapSuite.Core.PolygonShape –>
centerFeatureId String<!– System.String –>
drivingTime TimeSpan<!– System.TimeSpan –>
averageSpeed Single<!– System.Single –>
speedUnit SpeedUnit<!– ThinkGeo.MapSuite.Routing.SpeedUnit –>
gridSize Double<!– System.Double –>
gridSizeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –>
<!– ThinkGeo.MapSuite.Routing.RoutingEngine –> Go Back
GenerateServiceArea(String, TimeSpan, Single, SpeedUnit)
You can define service ranges based on limits of speed and time. A service area is a region that encompasses all accessible routes (such as streets). The default geography unit for a feature source is decimal degrees. The default distance unit for the average speed is kilometers. For example, the 5-minute service area for a point includes all the streets that can be reached within five minutes from that point.
PolygonShape<!– ThinkGeo.MapSuite.Core.PolygonShape –> A polygon that represents the service area.
centerFeatureId String<!– System.String –> This parameter is the feature ID that represents the center of the service area.
drivingTime TimeSpan<!– System.TimeSpan –> This parameter represents the time interval used to find the boundaries of the service area.
averageSpeed Single<!– System.Single –> This parameter represents the average speed traveled inside the service area.
speedUnit SpeedUnit<!– ThinkGeo.MapSuite.Routing.SpeedUnit –> This parameter represents the unit of average speed traveled inside the service area.
GenerateServiceArea(PointShape, TimeSpan, Single, SpeedUnit, Double, GeographyUnit)
centerPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
GenerateServiceArea(PointShape, TimeSpan, Single, SpeedUnit)
centerPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the point that represents the center of the service area.
GenerateServiceArea(String, TimeSpan, Double, GeographyUnit)
GenerateServiceArea(String, TimeSpan)
GenerateServiceArea(PointShape, TimeSpan)
GenerateServiceArea(PointShape, TimeSpan, Double, GeographyUnit)
GenerateServiceArea(Double, Double, TimeSpan, Single, SpeedUnit)
centerX Double<!– System.Double –> This parameter is the x coordinate of center point that represents the center of the service area.
centerY Double<!– System.Double –> This parameter is the y coordinate of center point that represents the center of the service area.
GetAngleBetweenTwoLines(LineShape, LineShape)
<!– static –> This method returns the angle between two lines.
Double<!– System.Double –> The angle from first to the end line shape
fromLine LineShape<!– ThinkGeo.MapSuite.Core.LineShape –> This parameter is the line that the angle is caucluated from
toLine LineShape<!– ThinkGeo.MapSuite.Core.LineShape –> The parameter is the other line used to calculate the angle besed on the from line
GetDrivingDirection(LineShape, LineShape)
<!– static –> This method returns the DrivingDirection based on the from line shape.
DrivingDirection<!– ThinkGeo.MapSuite.Routing.DrivingDirection –> The driving direction from the first to then end line shape.
fromLine LineShape<!– ThinkGeo.MapSuite.Core.LineShape –> This parameter is the line that DrivingDirection is caucluated from
toLine LineShape<!– ThinkGeo.MapSuite.Core.LineShape –> This parameter is the other line used to calculate the direction based on the from line shape
Int32<!– System.Int32 –>
GetRoute(String, String, IEnumerable<String>, Int32)
RoutingResult<!– ThinkGeo.MapSuite.Routing.RoutingResult –>
startFeatureId String<!– System.String –>
endFeatureId String<!– System.String –>
stopFeatureIds IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –>
iterations Int32<!– System.Int32 –>
GetRoute(String, String)
This method generates turn-by-turn driving directions for any route. It cannot be changed by overriding GetRouteCore.This method is for users who know the feature source. If the user does not know the feature source, they should use GetRouteSegments instead.This method is one of the most common routing requirements for a simple path, wherein a customer inputs two feature IDs that represent routeSegments and gets back a route. The route will be calculated from a specified start routeSegment to a specified end routeSegment.
startFeatureId String<!– System.String –> This parameter is the start feature ID which represents a routeSegment for the start of the route.
endFeatureId String<!– System.String –> This parameter is the end feature ID which represents a routeSegment for the end of the route.
GetRoute(String, IEnumerable<String>, Int32)
GetRoute(String, IEnumerable<String>)
GetRoute(PointShape, PointShape, IEnumerable<PointShape>, Int32)
startPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
endPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
stops IEnumerable<PointShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.PointShape} –>
GetRoute(PointShape, PointShape, IEnumerable<PointShape>)
GetRoute(PointShape, IEnumerable<PointShape>, Int32)
GetRoute(PointShape, IEnumerable<PointShape>)
GetRoute(PointShape, PointShape)
This method generates turn-by-turn driving directions for any route. It cannot be changed by overriding GetRouteCore.This method is for users who know the feature source. If the user does not know the feature source, they should use GetRouteSegments instead.This method is one of the most common routing requirements for a simple path, wherein a customer inputs two points and then finds a route. The route will be calculated from a specified start point to a specified end point.
startPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the start point which represents a routeSegment for the start of the route.
endPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the end point which represents a routeSegment for the end of the route.
GetRoute(String, String, IEnumerable<String>)
GetRouteSegments(String, String)
This method for users who don't know the feature source. If the user knows the feature source, they should use GetRoute to get more information.This method is one of the most common routing requirements for a simple path, wherein a customer inputs two feature IDs that represent routeSegments and then finds a route. The route will be calculated from a specified start routeSegment to a specified end routeSegment.
Collection<RouteSegment><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Routing.RouteSegment} –>
startFeatureId String<!– System.String –> This parameter is the start point of the route.
endFeatureId String<!– System.String –> This parameter is the end point of the route.
Type<!– System.Type –>
Void<!– System.Void –>
GetRouteCore(String, String, IEnumerable<String>, Int32)
GetRouteCoreWithPoints(PointShape, PointShape, IEnumerable<PointShape>, Int32)
OnGeneratingServiceArea(GeneratingServiceAreaRoutingEngineEventArgs)
e GeneratingServiceAreaRoutingEngineEventArgs<!– ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs –>
OnGettingRouteViaVisitStops(GettingRouteViaVisitStopsRoutingEngineEventArgs)
e GettingRouteViaVisitStopsRoutingEngineEventArgs<!– ThinkGeo.MapSuite.Routing.GettingRouteViaVisitStopsRoutingEngineEventArgs –>
DistanceUnit
Return Type
FeatureSource
Return Type
GeographyUnit
Return Type
RoutingAlgorithm
Return Type
RoutingResultsType
Return Type
RoutingResultsType<!– ThinkGeo.MapSuite.Routing.RoutingResultsType –>
RoutingSource
Return Type
This event is called during the generating service area. It wil be called many times during call the GenerateServiceArea method.
Event Arguments
Event Arguments
This event is called during the calculating best visit sequence. It wil be called many times during calling the GetRouteViaVisitStops method.
Event Arguments
Event Arguments
thinkgeo.mapsuite.routing.routingengine.1440040134.txt.gz · Last modified: 2015/09/22 08:32 (external edit)
