thinkgeo.mapsuite.mvcedition.overlay
ThinkGeo.MapSuite.MvcEdition.Overlay
<!– Class –> Serves as the base class that defines the properties and methods shared by all types of overlays.
The <strong>Overlay</strong> has as similar concept to the Layer. Different types of overlays stack over each other to form a map. An overlay object is responsible for getting the configuration information from the user and serializing it to a JSON string to control the client Javascript library, which creates the appropriate client layer.
Usually, an overlay represents an image with a transparent background that is laid upon other overlay, such as a <strong>LayerOverlay</strong> or <strong>WmsOverlay</strong>. While the <strong>MarkerOverlay</strong> will not be rendered as an image, it actually represents a <strong>div</strong> that holds several marker images at the client side.
There are basically two kinds of overlays: base overlays and non-base overlays.
A base overlay has its <strong>IsBaseOverlay</strong> property set to true. It is displayed as the background image of the map. In an <strong>OverlaySwitcher</strong>, there is a radio button beside its name. There can be only one base overlay displayed at a time. You can click the radio button to switch the base overlay that is displayed.
A non-base overlay has a false <strong>IsBaseOverlay</strong> property. These overlays can overlap the base overlay and/or each other. They are displayed in the <strong>OverlaySwitcher</strong> with a check box beside their name. You can click the check box to show or hide a specific overlay.
Protected MethodOverlay Initialize an instance of the Overlay class.
Protected MethodOverlay String Initialize an instance of the Overlay class.
Protected MethodOverlay String, Boolean Initialize an instance of the Overlay class.
Public MethodFromJson String Load this object from a json string.
Public MethodGetType Object
Public MethodToJson Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodRegisterJavaScriptLibraryCore Page Registers a Javascript library URL string to the client HTML page.
Public PropertyAttribution String
Public PropertyAutoRefreshInterval TimeSpan Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyId String Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyName String Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOnClientAutoRefreshTick String Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed.
Public PropertyOpacity Single Gets or sets the opacity level of the overlay.
Protected PropertyOverlayType String Gets a string that indicates which type the overlay is.
Overlay()
Overloads
Name Type Description
Go Back
Overlay(String)
Overloads
id String<!– System.String –>
Go Back
Overlay(String, Boolean)
Overloads
isBaseOverlay Boolean<!– System.Boolean –>
Go Back
Return Type Description
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page Page<!– System.Web.UI.Page –> The page object that is used for registering the javascript library.
Attribution
Return Type
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
Return Type
Return Type
Opacity
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
OverlayType
Return Type
thinkgeo.mapsuite.mvcedition.overlay.1440040131.txt.gz · Last modified: 2015/09/21 03:35 (external edit)
