This constructor creates a PointShape.
This constructor create a PointShape.
x
x
z
This constructor creates the PointShape.
wellKnownText
distance
quadrantSegments
shapeUnit
distanceUnit
distance
quadrantSegments
bufferCapType
shapeUnit
distanceUnit
distance
shapeUnit
distanceUnit
Compare the current PointShape with the target PointShape.
Compare the current PointShape with the target Point Feature.
targetFeature
shapeUnit
distanceUnit
targetShape
shapeUnit
distanceUnit
This method returns a MultilineShape that represents the shortest line between two points on the globe.
This method is useful when you want to display on the map the shortest line between two points in decimal degrees. The line will be curved, and possibly disconnected if it is close to travel from the end of the map.
pointShape
This method returns a MultilineShape which represents the shortest line between the current point and the specified feature on the globe.
pointFeature
fromPoint
toPoint
fromUnit
toUnit
fromPoint
toPoint
fromUnit
toUnit
Override the ToString() API by returning the X, Y , Z
distance
angleInDegrees
shapeUnit
distanceUnit
xOffsetDistance
yOffsetDistance
shapeUnit
distanceUnit
distance
quadrantSegments
bufferCapType
shapeUnit
distanceUnit
This method returns a complete copy of the shape without any references in common.
When you override this method, you need to ensure that there are no references in common between the original and the copy.
targetShape
shapeUnit
This method returns the crossing points between the current shape and the passed-in target shape.
targetShape
shapeUnit
distanceUnit
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe a geometry as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometric shapes.POINT(5 17)LINESTRING(4 5,10 50,25 80)POLYGON1)MULTIPOINT(3.7 9.7,4.9 11.6)MULTILINESTRING2)MULTIPOLYGON3),4))
This method returns the well-known type for the shape.
This method hydrates the current shape with its data from well-known binary.
wellKnownBinary
wellKnownText
This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
fromPoint
toPoint
fromUnit
toUnit
This method rotates the shape by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape, you can achieve in-place rotation. By moving the pivot point outside of the center of the shape, you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
pivotPoint
degreeAngle
This method moves the base shape from one location to another, based on a distance and a direction in degrees.
This method moves the base shape from one location to another, based on an angleInDegrees and distance parameter. With this overload, it is important to note that the distance units are the same GeographicUnit as the shape. For example, if your shape is in decimal degrees and you call this method with a distance of 1, you're going to move this shape 1 decimal degree in direction of the angleInDegrees. In many cases it is more useful to specify the DistanceUnit of movement, such as in miles or yards, so for these scenarios there is another overload you may want to use instead.If you pass a distance of 0, then the operation is ignored.
distance
angleInDegrees
shapeUnit
distanceUnit
This method moves the base shape from one location to another, based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape 1 unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles to on the X axis and 3 miles on the Y axis.
xOffsetDistance
yOffsetDistance
shapeUnit
distanceUnit
validationMode
fromPointX
fromPointY
toPointX
toPointY
fromX
fromY
toX
toY
Return Type:Boolean
Return Type:String
Return Type:Object
This property represents the X (horizontal) axis.
Return Type:Double
This property represents the Y (vertical) axis.
Return Type:Double
This property represents the Z (depth) axis.
Return Type:Double
