map_suite_desktop_for_winforms
Map Suite Desktop for WinForms
Map Suite Desktop for WinForms is a .NET native set of GIS software controls that lets .NET developers add rich, interactive maps to their Windows desktop applications. Featuring Winforms controls, running on Linux and Mac through Mono, packed with powerful mapping features and support for the most popular data formats, Map Suite Desktop for WinForms makes GIS accessible to developers of any skill.
Map Suite Desktop for WinForms Quickstart On Windows
Run GitHub Sample on Windows (2'28“)
Map Suite Desktop for WinForms Quickstart on Linux
Run GitHub Sample on Linux (2'13”)
Map Suite Desktop for WinForms Hello World
Hello World on Windows (3'09“)
Product Guides
Helps you get you up to speed with integrating the Map Suite Desktop for WinForms map control into your GIS software.
Introduces the dependencies Map Suite Desktop for WinForms needs with their features, versions and source websites.
Introduces what licenses are needed / how the license would work for debugging/deploying the Map Suite products.
Code Samples
In addition to the samples below, we have dozens of interactive Desktop for WinForms sample applications available
All Samples
All samples about Map Suite Desktop for WinForms.
Project Templates
These projects show various study cases based on Map Suite Desktop for WinForms.
Background Maps
InteractiveOverlays
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
Spatial Functions
Styles
Vehicle Tracking
Zooming Panning Moving
Package
Standard
Compare with Barebone
Barebone
Compare with Standard
API Documentation
  • ThinkGeo.MapSuite.WinForms
    The Desktop for WinForms API documentation covers the ThinkGeo.MapSuite.WinForms namespace which resides in the ThinkGeo.MapSuite.WinForms.dll assembly. It contains all of the Desktop for WinForms specific classes such as the map control itself, Overlays, and supported map classes.
Change Logs
  • API Change Log
    The Desktop for WinForms change log details the changes made to the product for each major release cycle.
Videos
Desktop for WinForms Sample App Walkthrough Video Series
Step through the Desktop for WinForms sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Introduction to the Desktop for WinForms
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The Map Suite Desktop for WinForms screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Map Suite Desktop for WinForms map control.
Add rich aerial imagery
Supports JPEG2000, TIFF, MrSid, ECW and more
Add rich aerial imagery Supports JPEG2000, TIFF, MrSid, ECW and more
SQL query feature layers
Get column data
Visually render SQL data
SQL query feature layers Get column data Visually render SQL data
Uses ZedGraph classes
Automatic color family generation
Group colors by hue or quality
Automatic color family generation Group colors by hue or quality
Draw or exclude features based on conditions
Render based on data points
Draw or exclude features based on conditions Render based on data points
Restrict drawing of features
Fill restricted areas with patterns or bitmaps
Restrict drawing of features Fill restricted areas with patterns or bitmaps
Plots points on your map
Point density represents numeric data
Puts you in control
Useful for points & labels
Render features specifically based on a theme
Colorize map features
Project your spatial data
Real-time rotation
Draw an image at a point
Dozens of interactive sample applications
Source code in C#
Dozens of interactive sample applications Source code in C#
Frequently Asked Questions
  • All Questions
    All the frequently asked questions about Map Suite Desktop for WinForms.
  • General Questions
  • Background Maps
    These frequently asked questions cover showing how to incorporate 3rd part background map with your application.
  • InteractiveOverlays
    These frequently asked questions cover various aspects of how to extend or create InteractiveOverlays. Examples of InteractiveOverlay functions are things such as drawing track shapes, shape editing and track extents.
  • Labeling
    These frequently asked questions cover various aspects of labeling features.
  • Layers & FeatureSources
    These frequently asked questions cover custom layers and feature sources from which you can get inspired to integrate your own data.
  • Miscellaneous
    These frequently asked questions cover various of other technical features of the products that are not included in other categories.
  • Projection
    These frequently asked questions cover various aspects of projection such as how to re-project your data.
  • Spatial Functions
    These frequently asked questions cover various spatial functions such as union, buffer, merging data etc.
  • Styles
    These frequently asked questions cover displaying your GIS data using various styles. Some examples of styles would include using class breaks, clustering points, heat maps, etc.
  • Vehicle Tracking
    These frequently asked questions cover various features related to vehicle and asset tracking.
  • Zooming Panning Moving
    These frequently asked questions cover various ways to move the map.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_desktop_for_winforms.1489643971.txt.gz · Last modified: 2017/03/16 05:59 by kevinlaw
