map_suite_desktop_for_winforms_zooming_panning_moving_samples
WinForms Samples
Get Zoom Level Sample for WinForms
This example demonstrates how to get the zoom level of the map each time we change its extent. Using custom zoom levels, you will see how to get the zoom level with its characteristics such as the upper and lower scale defining it. You can read the comments inside the project to better understand the relationship of scales with zoom levels.
Screenshot
View this sample on Github
Centering On Moving Vehicle With Tolerance Sample for WinForms
Screenshot
map_suite_desktop_for_winforms_zooming_panning_moving_samples.txt · Last modified: 2020/03/08 06:38 (external edit)
