map_suite_desktop_for_winforms_interactiveoverlays_samples
WinForms Samples
Custom Track Polygon Sample for WinForms
Learn how to extend the TrackInteractiveOverlay to add behaviors, like deleting the last added vertex when right-clicking the track line.
Screenshot
View this sample on Github
Drag Point Sample for WinForms
In this project, we focus our attention on how to control the style of the control points. You will see how to override the DrawCore function of EditInteractiveOverlay.
Screenshot
Snapping To Vertex Sample for WinForms
Screenshot
Drag Vertex Sample for WinForms
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
Screenshot
Drag Icon Sample for WinForms
Screenshot
Track Overlay With Esc Sample for WinForms
Screenshot
Snap To Layer Sample for WinForms
Screenshot
Select And Drag Feature Sample for Wpf
Screenshot
Edit Rectangles Sample for WinForms
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes, rather than polygon shapes, by setting special column values. For features (both *Well Known Text* and *Well Known Binary*), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
Screenshot
Select At Track Shape Sample for WinForms
Screenshot
Drag Point Advanced Sample for WinForms
This project is an example of how extensible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key, and how to have the vertex snap to any feature.
Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can easily be implemented by inheriting from EditInteractiveOverlay.
Screenshot
Drag Point With Label Sample for WinForms
In this project, dedicated to EditInteractiveOverlay, you will see how easy it is to add some labeling to your dragged control point, showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the user experience, the closest point of the reference shape is also shown varying as the control point is dragged around.
Screenshot
Custom Track Line Sample for WinForms
Screenshot
Dynamic Track Shapes Sample for WinForms
This Desktop project shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
Screenshot
Track Zoom In Without Shift Key Sample for WinForms
Screenshot
Preset Vertex To Tracked Polygon Sample for WinForms
Screenshot
Dragging Icon Advanced Sample for WinForms
Screenshot
map_suite_desktop_for_winforms_interactiveoverlays_samples.txt · Last modified: 2020/03/08 06:37 (external edit)
