map_suite_desktop_for_winforms_features_bug_fixes_change_log
Map Suite Desktop For WinForms Features & Bug Fixes Change Log
Version 10.6.0
Release date: 11/28/2019
ThinkGeo.MapSuite.WinForms Namespace:
ThinkGeo.MapSuite Namespace:
  • Enhanced to support reprojection for Wmts.
  • Enhanced to support high resolution screen for ThinkGeoCloudRasterMapsLayer.
  • Enhanced to support high resolution screen for GoogleMapsLayer.
  • Fixed a bug that GoogleMapsLayer renders incorrect tiles when map extent is out of max extent of Google.
  • Fixed a bug that WmtsLayer can't serialize.
  • Fixed a bug that the projection don't works when FeatureSource is editing and IsTransactionLive of ShapeFileFeatureLayer is true.
  • Fixed a bug that Fdo doesn't work on the x64 target platform.
  • Fixed a bug that FikeGeoDatabase doesn't work on the x64 target platform.
  • Changed DrawingPointStyleEventArgs to DrawingDirectionPointEventArgs.
  • Added DirectionPointStyle property for LineStyline.
  • Enhanced to support ZoomLevel20 for ThinkGeoCloudMapsZoomLevelSet.
  • Improved render performance for OpenStreetMap.
  • Fixed a bug that the PDF and the Printer get different result with the Map if polygon contains inner rings.
  • Enhanced to support GeoLinearGradientBrush for Printer.
  • Enhanced to support GeoLinearGradientBrush in PDF.
  • Fixed a bug that the Direction convert to incorrect Angle in GeoLinearGradientBrush.
  • Fixed a bug. When parsing tile format tiff image, throws “Array index is out of range” exception.
  • Fixed a bug that cache expired don't works again because we need compare the UTC dateTime.
  • Enhanced to support rotation text for Cad.
  • Fixed a bug that raster layer is unmatched with vector layer when printing.
  • Fixed a bug that the projection '90091' srid can't be found from Esri projectin list.
  • Fixed a bug that GeoTiff will jump when reprojection.
  • Improved S57 index building performance.
  • Fixed a bug. When Setting the IsActive of specified zoomlevel to false, map still draw the shape follow the style of other zoomlevel.
  • Fixed a bug that QueryTool doesn't work.
  • Fixed a bug that the label is rendered at incorrect position under different DPI.
  • Improved render performance for NauticalChartsFeatureLayer.
  • Fixed a bug that RotationAngle of PointStyle doesn't work when printing map.
  • Fixed a bug resouce files of LegendAdornmentLayer can't be found.
  • Fixed a bug that zooming to deeper than level 20 OpenStreetMapsLayer throws a exception.
Version 10.5.0
Release date: 04/01/2019
  • Added support of new class ThinkGeoCloudVectorMapsOverlay to consume Vector Tiles from ThinkGeo Cloud
  • Enhanced to support sending web request event and sent web request event for ThinkGeoCloudMapsOverlay
  • Enhanced to rename ThinkGeoCloudMapsOverlay to ThinkGeoCloudRasterMapsOverlay and ThinkGeoCloudMapsMapType to ThinkGeoCloudRasterMapsMapType
  • Fixed a bug that default ThinkGeo Cloud Maps server URLs need get updated
  • Added support of Skia as the drawing engine to improve the performance.
  • Added support of semantic cartography schema – StyleJSON to design the map.
  • Added support of vector tile based *.MbTiles format.
  • Added support of ThinkGeoCloudRasterMapsLayer
  • Added support of high resolution for PlatformGeoCanvas, it mainly works for iOS edition
  • Enhanced to support parse special node in capability XML contains two spaces for WMTSLayer, generally Oracle export this type XML
  • Enhanced to support “ScaleFactor” property, it shows the high resolution value, it mainly works for iOS edition
  • Enhanced to support drawing halo pen dasharray on SkiaGeoCanvas
  • Enhanced to support both meter and decimal degree for NauticalCharts
  • Enhanced to support use ThinkGeoCloudRasterMapsLayer in iOS and Android edition
  • Fixed a bug that print google map to pdf tile unmatch
  • Fixed a bug that BuildingAreaStyle don't works follow design
  • Fixed a bug that OSM Buildings Url need get updated
  • Fixed a bug that some geotiff files looks jump when pan on map after set projection
  • Fixed a bug that text style don't works for wrapping lines in certain scenario
  • Fixed a bug that wrong boundary limit for Proj4Projection in certain scenario
  • Fixed a bug that the width or height value maybe equal zero when calling ToScreenCoordinate for GeoTiff
  • Fixed a bug that projection cannot handle parameter correct in certain scenario
  • Fixed a bug that PlatformGeocanvas throw format exception in certain scenario
  • Fixed a bug that GetDrawingExtent function loss precision in certain scenario
  • Fixed a bug that MapType is invalid when initializing ThinkGeoCloudRasterMapsLayer
  • Fixed bugs that some geotiff files cannot load correct
Version 10.4.0
Release date: 12/10/2018
  • Added new class ThinkGeoCloudMapsOverlay to support new ThinkGeo Cloud Map
  • Enhanced to use more accurate exception information
  • Fixed a bug the ThinkGeoCloudMapsOverlay generate incorrect route in certain scenario
  • Added new overloading method for DrawText in GeoCanvas class
  • Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon
  • Enhanced to support Esri srid input for Proj4Projection
  • Enhanced to support Esri coordinate system when create table for FileGeoDatabase
  • Enhanced to use more accurate exception information and exception type
  • Fixed a bug map throw null reference exception in certain scenario
  • Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux
  • Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation
  • Fixed a bug vector data won't render all shapes if the width is too big
  • Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario
  • Fixed a bug GettingTileCache event won't be fired in correct step
  • Fixed a bug the overlays don't match when print to PDF
  • Fixed a bug white line shows for WMTSlayer
  • Fixed a bug exception is thrown when met invalid tile in WMTSlayer
  • Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario
  • Fixed a bug ECW render distorted image in special zoomlevel
  • Fixed a bug GeoTiff image jump in certain scenario
Version 10.3.0
Release date: 7/26/2018
Version 10.2.0
Release date: 10/27/2017
  • Fixed a bug where SetSelectedControlPoint API can't get the shared dragging vertex.
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Create new product center that is available to run on multi-platforms including Windows, Linux and macOS.
  • Support ECW files on Linux.
  • Support MrSid and JPEG2000 files on Linux.
  • Fixed a out of memory bug caused by the forc cast of bitmap when calling DrawOverlaysForSingelThread and DrawBackgroundBitmap.
  • Added SnapDown and SnapToClosest option to controll the zooming operaction.
  • Fixed a crash issue when the map.ZoomLevelSnapping value is set to None.
  • Fixed an OutOfMemory issue by caching the background brush.
  • Fixed a bug that map flicks when refreshing overlay in multi-thread mode.
  • Added Language property in GoogleMapsLayer and GoogleMapsOverlay.
  • Fixed a bug that the markers is unremovable during panning.
  • Added VerticesRemoving and VerticesRemoved events in EditInteractiveOverlay.
  • Fixed map pause in a flash issue when panning map with MultiTile InMemoryFeatureLayer.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.DesktopEdition Namespace:
  • Added request drawing support on Overlay.
  • Fixed a bug where EditInteractiveOverlay runs into exception when dragging the first vertex of a polygon if VertexDraggingMode is Shared.
  • Fixed a bug where there is a delay of panning the map when working with MultiThread.
  • Cancel adding vertex not works by handling AddingVertex event of TrackInteractiveOverlay.
  • Fixed TrackEnding event don't works follow design.
  • Fixed StartingVertex of TrackStarting function for TrackInteractiveOverlay don't works.
  • Fix the logic for EditInteractiveOverlay, remove additional control point.
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where it runs into exception sometimes when remoing vertex from MultiPolygonShape.
  • Fixed a bug where something wrong with filtering other items, which is not tables, using method “GetTableName” in FileGeoDatabaseFeatureLayer.
  • Fixed a bug where something wrong with StreamLoading event of GdiPlusRasterLayer if the loaded image is in tiff format.
  • Fixed a bug where there are some incorrect format parameters in the request URI in TiledWmsRasterSource.
  • Fixed a bug in ManagedProj4Projection which happened after upgrade to 7.0.
  • Fixed a bug where the addedFeature is unable to get the tag of resshapeControlPoint.
  • Fixed a bug that will cause one shapefile could not be shared by two shapefilelayer.
  • Added support of patially refresh an area in LayerOverlay or map.
  • Improved the performance of EditInteractiveOverlay when working with large data, such as Taxes roads.
  • Added a new class MagneticDeclinationPrinterLayer to support print magnetic declination.
  • Fixed a bug where the featureDragged event is triggered during the mouse moving.
  • Added several Geoprocessing related functionalities to GeometryCollectionShape.
  • Fixed a bug where Feature Tag is missed after calling CalculateVertexControlPoints method.
  • Fixed a bug where srid is empty in oracle table after importing the features.
  • Fixed a bug where the Feature's tag is missed in some events.
  • Fixed a bug that the GraticuleAdornmentLayer numbers always has a white edge.
  • Fixed a bug where it runs into exception when reading a csv file.
  • Fixed a bug where it runs error when using MapThreadingMode.Multithreaded with TileCache.
  • Added the support of moving multiple vertexes when they are in the same place.
  • Added the support of MagneticDeclinationAdornmentLayer.
  • Fixed a bug where the application crashes if there are not enough vertexes in a line or polygon after delete.
  • Fixed the bug where the Feature's tag is missed after calling Addvertex.
  • Replaced the ECW referenced DLLs from debug version to the release one.
Version 7.0.0.0
Release date: 06/03/2013
  • Added the feature that can generate the polygon result from Isoline
  • Fixed a bug that Map.CurrentScale is not correct after Track Zoom In
  • Fixed a bug that the column value is not correct when using ShapeFileFeatureLayer.SaveToProjection
  • Fixed a bug that it's unable to resize LegendPrinterLayer
  • Fixed a bug that the icon would get trucked when using Markers
  • Fixed a bug that two InMemoryMarkerOverlays couldn't display at the same time
  • Fixed a bug that Bing maps disappears when zoom out to zoomlevel01
  • Fixed a bug that the ShapeFileFeatureLayer.StreamLoading would not be raised when file format is incorrect
  • Fixed a bug that when resizing the ImagePrinterLayer and LegendPrinterLayer the image would disappear
  • Fixed a bug that MapPrinterLayer always rendered as a bitmap
  • Fixed a bug that NullReference Exception would occur when calling TabFeatureSource.CreateTabFile with MultiPolygon
  • Fixed a bug that features draw outside MapPrinterLayer's boundary
  • Fixed a bug that the CustomZoomLevels are cleared when MapUnit is changed
  • Fixed a bug that GetAllFeatures would return incorrect features when using projection
  • Fixed a bug that the label would disappear at a slight change of extent
  • Fixed a bug that MapPrinterLayer not printing to scale
  • Fixed a bug in MarkerOverlay that the markers doesn't refresh when the Overlay.IsVisible was set to false
  • Fixed Layer.IsNegative method to apply proper color to Layer instead of Black
  • Fixed red 'x' issue for OpenStreetMapLayer and Overlay when zooming to very low scales
  • Improved standardize the Caching system across all the products
  • Modified InMemoryMarkerOverlay Features API to make API more uniform across products
Version 6.0.0.0
Release date: 05/14/2012
  • Fixed an issue where GetLineOnLine returns the wrong result.
  • Fixed an issue where the tooltips of marker are duplicated.
  • Fixed an issue where ScaleBar and ScaleLine don't match in PrinterLayer.
  • Added the method ZoomToNextExtent().
  • Fixed an issue where features cannot be selected after editing if the layer is reprojected.
  • Fixed an issue where the application crashes under visual studio 11.
  • Improved serialization of InMemoryFeatureLayer by using the class GeoSerializer.
  • Fixed an issue where System.ArgumentException is thrown when resizing LabelPrinterLayer.
  • Fixed an issue where map is not correctly printer to PDF.
  • Fixed an issue where IconImageScale in IconStyle is not printed correctly.
  • Fixed an issue where “memory access violation” exception is thrown when drawing the overlay after deserializing.
  • Fixed an issue where Manged4Projection cannot be correctly serialized.
  • Fixed an issue where projection won't be opened in GraticuleAdornmentLayer unless it is passed in through constructor.
  • Fixed an issue where Graticule Grid gets smaller when panning out of map boundary if the internal/external projection are both set to 4326.
  • Improved LegendPrinterLayer by rendering Legend using Vector Graphics.
  • Added the support for ThinkGeo's TinyGeo (.tgeo) File Format.
Version 5.5.0.49
Release date: 12/31/2011
  • Fixed an issue where markers shift when panning the map.
  • Fixed an issue where ArgumentOutOfRangeException is thrown when calling GetFeaturesWithinDistanceOf method on a projected Layer.
  • Fixed an issue where the map flashes while panning under multithreading mode with tile cache enabled.
Version 5.5.0.0
Release date: 11/14/2011
  • Fixed an issue where TrackEnded event doesn't work properly in some cases.
  • Fixed an issue where exceptions from BingMapsLayer cannot be caught.
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
  • Enhanced ZoomLevel Setting
  • Fixed a bug where the layer had to be reopen after drawn in version 5.0
  • Fixed a bug where points disappeared while panning
  • Fixed a bug where the marker click event didn't work properly in some cases
  • Fixed a bug where RestrictedExtent didn't work as expected
  • Fixed a bug where WinformsMap.RestrictedExtent didn't work as expected
  • Fixed a bug where an exception was thrown while resizing within the restricted extent
Version 5.0.0.0
Release date: 5/16/2011
  • Fixed a bug where the DrawingTime of Overlays was reported incorrectly.
  • Fixed a bug where an exception was thrown when initializing the area units in multithreaded scenarios..
  • Fixed a bug in TrackInteractiveOverlay where the start point was offset when tracking a shape.
  • Fixed a bug where the Current Extent gets pretty big when passing in a very small extent.
  • Fixed a bug where the trackzoomin rectangle was still be displayed while holding the shift key even the track zoom key is set to another key.
  • Fixed a bug that threw an exception after calling Refresh when CanReshape was set to false.
  • Added BingMapsOverlay with the new way of authentication.
  • Added method GetBitmap(Single width, Single height) in wpfMap.
  • Added the property TrackZoomInLayer in the ExtentInteractiveOverlay.
  • Added a way to restrict the users extent using the Map.RestrictedExtent property.
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added MarkerOverlay which support SimpleMarkerOverlay, InmemoryMakerOverlay and FeatureSourceMakerOverlay.
  • Added OpenStreetMapOverlay to support Open Street Map.
  • Added ClusterPointStyle
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
  • Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
  • Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
  • Fixed issue when using the UpdateColumnName API in DBF module.
  • Fixed issue involving use of Chinese fonts
  • Fixed a rounding bug in the GetPointOnALine API of LineShape.
  • Some minor API changes. See the API change log for complete details.
Version 4.0.0
Release date: 5/1/2010
  • Many core enhancements and additions as itemized here.
  • Added support and sample applications for Visual Studio 2010.
  • Increased panning performance both for WinformsMap and WpfMaps.
  • Improved WPF performance issues related to screen resolution.
  • Enhanced Overlay.Draw to display the full stack trace if an exception is thrown.
  • Fixed issue for SpatialQuery result without USA.
  • Fixed environment-related issue when using ClassBreakStyle.
  • Fixed issue where WorldMapKitWMsRasterSource would throw a thread exception.
  • Fixed issue where the Scale of InteractionArguments is always 0.
  • Fixed issue where there is no effect when the user sets a different DrawingQuilty for a layer from winforms.DrawingQuity.
  • Fixed issue where an exception is thrown when using multithreading.
  • Fixed issue where a NullReferenceException will be thrown after a CloneDeep operation because the Encoding is null.
  • Fixed issue where a WPF map cannot be zoomed in after hiding the AvalonDock.
  • Fixed issue with inheriting from TrackInterativeOverlay to remove a vertex.
  • Fixed issue where the map will not display when TileWidth is not 256.
  • Fixed issue with exceptions while drawing.
  • Fixed issue where mouseDownCount needed to be set to for TrackOverlay.
  • Fixed issue where an IOException will be thrown when using MultiThreadMode with TileCache.
  • Fixed issue where the worker thread will continue running after you call Dispose in multithreaded mode.
  • Changed the MapUnit property's default value from DecimalDegree to Unknown.
  • Changed the default DrawingExceptionMode to DrawException for WorldMapKitWmsDesktopOverlay.
  • Overall performance improvements.
  • Several API additions. See the API change log for complete details.
  • Updated the API documentation.
  • Added additional helper methods to the GeoCollection class.
  • Added better support for labeling with Asian characters.
  • Added support for Google Static Maps API v2.
  • Added simple support for Yahoo Maps.
  • Added support for heat map layers.
  • Added support for 100% managed proj Projection Library.
  • Added direct support for Map Shapes.
  • Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added new API BuildIndex for MultipleShapeFileFeatureLayer
  • Included GraticuleLineLayer support and a sample application for it.
  • Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
  • Enhanced the distance measuring method to use the Haversine formula.
  • Improved GeoCache performance.
  • Updated the PostgreSQL Assembly versions.
  • Exposed the DBaseFile class library.
  • Exposed the disk-based RTree Spatial Index.
  • Split up the Map Suite MergeModule into smaller and more manageable pieces.
  • Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding GetBoundingBox of GroupLayer.
  • Fixed issue where GetAllColumns also returns the Geometries column.
  • Many API additions. See the API change log for complete details.
Version 3.1.299
Release date: 11/16/2009
  • Concluded public beta and moved to final release.
  • Fixed issue where a null pointer exception is thrown when the network is not available.
  • Fixed issue where the GradientStyle does not work properly.
  • Fixed issue where snapping does not occur in Google & Virtual Earth layers.
  • Fixed issue where the TileCache is not properly cleared when the environment is set to French.
  • Fixed issue where the preview cache folder could not be created when the environment is set to French.
  • Fixed issue where an overlay does not redraw when using lock object in multi-threaded mode.
  • Fixed issue where layers would disappear when the map is set to a certain extent.
  • Several API changes. See the API change log for complete details.
  • Fixed issue where SaveToProjection is incorrect for some data.
  • Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
  • Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
  • Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
map_suite_desktop_for_winforms_features_bug_fixes_change_log.txt · Last modified: 2019/12/06 01:45 by tgwikiupdate
