ThinkGeo Cloud Maps Query provides RESTful APIs to perform spatial query against each types of data.
* Try it Online: All of the ThinkGeo Cloud RESTful APIs can be tested online by following the instructions below:
ThinkGeo Cloud Maps Query provides the following RESTful APIs:
Get the features that are within the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/within
URL Parameters
Visit GetFeaturesWithin and click “Try It Out” to explore this API online.
Get the features that contain the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/containing
URL Parameters
Visit GetFeaturesContaining and click “Try It Out” to explore this API online.
Get the features that intersect the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/intersecting
URL Parameters
Visit GetFeaturesIntersecting and click “Try It Out” to explore this API online.
Get the features that overlap the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/overlapping
URL Parameters
Visit GetFeaturesOverlapping and click “Try It Out” to explore this API online.
Get the features that touch the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/touching
URL Parameters
Visit GetFeaturesTouching and click “Try It Out” to explore this API online.
Get the features that are nearest the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/nearest
URL Parameters
Visit GetFeaturesNearest and click “Try It Out” to explore this API online.
Get the features that are within a certain distance of the target shape.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/within-distance
URL Parameters
Visit GetFeaturesWithinDistance and click “Try It Out” to explore this API online.
Perform a custom spatial query, using the specified query layer, spatial relationship type, and query feature.
HTTP POST https://cloud.thinkgeo.com/api/v1/maps/query/custom
POST Body (Content-Type: application/json)
{ "queryLayer": "string", //The layer to query. "queryType": "string", //The type of query to perform. Value can be one of: "Within", "Containing", "Intersecting", "Overlapping", "Touching", "Nearest", "Within-Distance". "wkt": "string", //The well-known text of the target geometry. "srid": int, //Optional. The SRID of the input and output feature's coordinate system. Defaults to 4326. "proj4String": "string", //Optional. The Proj4 string of the input and output feature's coordinate system. "distance": double, //Optional. The distance within which to find features. Defaults to 200. "distanceUnit": "string", //Optional. The unit of measure in which the distance is expressed. Defaults to Meter. "searchRadius": double, //Optional. The radius of the search area around the target geometry. If not specified, it's assumed that there is no limit. "searchRadiusUnit": "string", //Optional. The unit of measure in which the searchRadius is expressed. Defaults to Meter. "maxResults": int, //Optional. The maximum number of features to return. Defaults to 100. "returnFeatureAttributes": bool, //Optional. Specify whether the feature attribute names and values will be returned in the response. Defaults to true. "featureAttributesToReturn": [ "string" ] //Optional. If returnFeatureAttributes is true, this specifies which a specific subset of attributes to be returned. Formatted as a comma-delimited list of attribute names that should be returned with each feature in the response. }
Visit GetFeaturesCustom and click “Try It Out” to explore this API online.
List the available query layers.
HTTP GET https://cloud.thinkgeo.com/api/v1/maps/query/layers
Visit GetQueryLayers and click “Try It Out” to explore this API online.
List the feature attributes available on the given query layer.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/query/{queryLayer}/attributes
URL Parameters
Visit GetAttributesOfLayer and click “Try It Out” to explore this API online.
Coming soon
Online Sample:
Coming soon
Desktop Sample:
Coming soon
Web Sample:
Coming soon
Mobile Sample:
Coming soon
