thinkgeo_cloud_maps_wms
ThinkGeo Cloud Maps WMS
ThinkGeo Cloud Maps WMS provides an API with which you can retrieve map images through a standards-compliant WMS (Web Map Service). This can be either a single image of a complete map, or one tile from a multi-tile map.
APIs
ThinkGeo Cloud Maps WMS provides the following RESTful API:
Get WMS Map
Retrieve a map image via WMS.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/wms
URL Parameters
  • Request: Required. The type of WMS request. Supported values are:
    • GetMap: Requests a map image. This will be the request type you use most often.
    • GetCapabilities: Details the capabilities of the WMS service.
  • Service: Required. The service name. Must be "WMS". Default value: WMS
  • Version: Required. The WMS version to use. Supported values are “1.1.1” and "1.3.0". Default value: 1.1.1
  • Layers: Required for "GetMap". The map layers to include in the requested image. Use “,” as the separator for multiple layers. For a list of supported values, please send a “GetCapablities” request.
  • Styles: Required for "GetMap". The styles for the requested image. Use “,” as the separator for multiple styles. For a list of supported values, please send a “GetCapablities” request.
  • Format: Required for "GetMap". The format of the requested image. For a list of supported values, please send a “GetCapablities” request.
  • Width: Required for "GetMap". The width of the requested image in pixels. Default value: 512
  • Height: Required for "GetMap". The height of the requested image in pixels. Default value: 512
  • BBox: Required for "GetMap". The bounding box of the requested image, expressed as the spatial coordinates of a rectangle. The required format is "minX,minY,maxX,maxY".
  • Srs: Required for "GetMap". The spatial reference system in which the BBox is specified. Applies only to version "1.1.1". Default value: EPSG:3857
  • Crs: Required for "GetMap". The coordinate reference system in which the BBox is specified. Applies only to version "1.3.0".
  • Exceptions: The output format to use for exceptions.
  • Transparent: Indicates whether or not the requested image should have an alpha channel (transparent background).
Visit GetWmsMap and click “Try It Out” to explore this API online.
Consume from Client Side
SDK for .NET
SDK for JavaScript
Samples
Online Sample:
Coming soon
Web Sample:
Coming soon
Desktop Sample:
Coming soon
Mobile Sample:
Coming soon
thinkgeo_cloud_maps_wms.txt · Last modified: 2019/03/31 16:38 by brianr
