The ThinkGeo Cloud Time Zones service provides a RESTful API to retrieve time zone and UTC offset information for a given spatial coordinate. Check out the online sample for a quick look.
* Try it Online: The ThinkGeo Cloud Time Zones RESTful API can be tested online following the instructions below:
ThinkGeo Cloud Time Zones provides the following Restful APIs:
Returns information about a local time zone for the specified point, including the Olson time zone ID, country code, UTC offset, current local time and more.
HTTP GET
https://cloud.thinkgeo.com/api/v1/timezones/{pointY},{pointX}
URL Parameters
Visit https://cloud.thinkgeo.com/help/#/TimeZone/GetTimeZonesByCoordinateV1 and click “Try It Out” to explore this API online.
Example Output
{ "timezone": "Asia/Bangkok", "countryName": "Thailand", "countryCode": "TH", "comment": "", "currentLocalTime": "2019-03-31T23:16:26.1379980", "currentUtcTime": "2019-03-31T16:16:26.1379980Z", "offsetSeconds": 25200 }
ThinkGeo Cloud Time Zones does not allow anonymous users to access the API. Before working with these APIs, you will need to register with ThinkGeo Cloud and create your own clients. A new account come with two clients: NativeConfidential and JavaScript. See more details at here.
The SDK for JavaScript enables developers to directly access ThinkGeo Cloud services from JavaScript code running in brower. This SDK can be found at thinkgeocloudclient-js.
