ThinkGeo Cloud Raster Tile serves raster map tiles through XYZ. Check out ThinkGeo Cloud Raster Map Online Sample for a quick look.
Get the raster tile at the specified zoom level and X/Y coordinate, using the supplied parameters.
HTTP GET
https://cloud.thinkgeo.com/api/v1/maps/raster/{style}/x{resolution}/{srid}/{tileSize}/{tileZ}/{tileX}/{tileY}.{fileExtension}?apikey={key}
URL Parameters
Here is an example of a raster tile request URL: https://cloud.thinkgeo.com/api/v1/maps/raster/light/x1/3857/512/0/0/0.png. When no API key is specified, the tile will be watermarked with a ThinkGeo logo. To remove the watermark, a valid ThinkGeo Cloud API key is required. Please check out Client Keys Guideline to find out how to get your own API key.
Visit GetMapsRasterTileByXyz and click “Try It Out” to explore this API online.
Map Suite Raster Tile Data is composed of street tiles and aerial images tiles.
The data of streets tiles (light / dark / transparent-background ) mainly come from Open Street Map, and partially from Natural Earth. The tiles cover the entire world. The tiles are scheduled to be updated on a monthly basis.
Our World Map data can be purchased separately. It can be consumed offline by Map Suite SDKs. Check out Maps Streets Offline Data and Maps Imagery Offline Data for detail.
OpenLayers and Leaflet have built-in classes consuming the tiles through XYZ. Here is the code snippet in OpenLayers.
var lightLayer = new ol.layer.Tile({ source: new ol.source.XYZ({ urls: [ "https://cloud.thinkgeo.com/api/v1/maps/raster/light/x1/3857/512/{z}/{x}/{y}.png?apikey=yourkey", ], tileSize: 512 }), name: "lightLayerKey" });
The sample code in LeafLet:
var lightLayer = L.tileLayer("https://cloud.thinkgeo.com/api/v1/maps/raster/light/x1/3857/512/{z}/{x}/{y}.png?apikey=yourkey");
Here is an Online Sample consuming the map tiles using OpenLayers.
All of the MapSuite UI Controls have built-in a straightforward way for consuming the raster tiles.
Sample Code:
using ThinkGeo.Cloud; // Setup the overlay ThinkGeoCloudMapsOverlay thinkGeoMapsOverlay = new ThinkGeoCloudMapsOverlay("Your Client ID", "Your Client Secret"); // or ThinkGeoCloudMapsOverlay thinkGeoMapsOverlay= new ThinkGeoCloudMapsOverlay("Your apiKey"); Map.Overlays.Add(thinkGeoMapsOverlay);
Sample Code:
using ThinkGeo.Cloud; MapsClient client = new MapsClient("Your Client ID", "Your Client Secret"); Stream imageStream = client.GetRasterTile(z, x, y, projection, mapType, tileSize, tileResolution);
Online Sample:
Desktop Sample:
Web Sample:
Mobile Sample:
