The Winforms QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create a Winforms application.
Please refer to Wiki for the details.
OpenStreetMap (OSM) is a collaborative project to create free geographic data for the entire world. It can be thought of as a “Free Wiki World Map”. The latest version of MapSuite now supports this.
The wpf map control supports multi-thread to render map, so it performs better than winforms map control. This sample demonstrates how you can use wpf map control in your winforms applications.
This project shows to create simulated 3D buildings with WinForms Map control and shapefile.
The World Streets Vector Layer Explorer is a tool that enables you to view the SQLite World Streets data using Map Suite WinForms and provides complete performance metrics.
This project requires a full or evaluation version of Map Suite WinForms Edition.
This sample passed on Linux with Mono Runtime. On Windows platform, it is required to replace the ThinkGeo.MapSuite.Layers.SqliteForLinux with ThinkGeo.MapSuite.Layers.Sqlite package.
To run the sample, please unzip the database file at WorldStreetsLayerSample/App_Data/DallasCounty-3857-20170218.zip, and change the connection string in WorldStreetsLayerSample/App.config to connect database that you extracted to.
Working…
This sample demonstrates how you can draw the map with Vector Tiles requested from ThinkGeo Cloud Services in your Map Suite GIS applications, with any style you want from StyleJSON (Mapping Definition Grammar). It will show you how to use the XyzFileBitmapTileCache and XyzFileVectorTileCache to improve the performance of map rendering. It supports have 3 built-in default map styles and more awasome styles from StyleJSON file you passed in, by 'Custom': - Light - Dark - TransparentBackground - Custom
How to use this tool:
1. Load rtg data: Click menu “File→Load” browse to a rtg file. You also require a shapefile for the routing source file in the same folder, otherwise it display message “Could not find shp file in the same folder where you seleted”. 2. Start routing:
1. In Map Suite, a shape (a shape object inherited from the BaseShape class such as PointShape, LineShape, etc) is heavier than a feature. You can treat a feature as a holder of a byte array (Well Known Binary), it’s lightweight and doesn’t have too many methods to manipulate its core data (Well Known Binary). Shape, however, is heavy, it provides all the info as well as methods against the data. You can cast from a feature to a shape and vice versa.
1. To update a feature, usually, we need to convert a feature to a shape, update the shape and then convert it back to a feature. This will create a new shape and a new feature, which is more straightforward but the cost is high. Below is a method updating a point feature by adding 1 to its X and Y.
private void UpdateFeatureThroughShape(Feature feature)
byte[] wkb = feature.GetWellKnownBinary();
PointShape pointShape = new PointShape(wkb);
pointShape.X += 1;
pointShape.Y += 1;
feature = pointShape.GetFeature();
3. You can update a feature by directly updating its WKB. The following method updates a point feature by adding 1 to its X and Y. It’s the most efficient way where we manipulate a byte array without creating any new object. It is not straightforward and you need to have a deep understanding of the format of WKB. That’s what we are doing in this sample. We will add more APIs to Feature to make it straightforward and efficient.
private void UpdateFeatureThroughWKB(Feature feature)
double x = BitConverter.ToDouble(wkb, 5);
double y = BitConverter.ToDouble(wkb, 13);
BitConverter.GetBytes(x + 1).CopyTo(wkb, 5);
BitConverter.GetBytes(y + 1).CopyTo(wkb, 13);
feature.SetWellKnownBinary(wkb);
4. The “Grid size in Pixel” textbox let you set the size of the grid in which up to one point can be displayed, the bigger the grid is, the more sparse the points will be. This is an optimization with which we can avoid showing too many points on the map. Play with it and you can see the performance differences.
This sample shows you how to get started building your first application with the Map Suite Desktop for WinForms 10.0.0.
In this WinForms desktop project, we show how to create a custom LineStyle for showing distance increment at a regular interval (every tenth kilometer). Having this LineStyle can be very handy when dealing with line networks, such as roads or railways.
1. Google Maps 2. Bing Maps 3. World Kit Maps 4. Open street Maps
It can display different styles of maps by setting the map type.
Working…
This WinForms project demonstrates how you can update a grid shape file using a spatial query. The elements in the file are rendered using ClassBreakStyles, and change when the values of the Features are incremented.
We have dramatically improved the performance for GridFeatureLayer on MapSuite10.0. The performance compare is as below:
| Feature Count | Version | Times(ms) |
| 1164800 | Old | 13105 |
| 1164800 | New | 3735 |
| 11680 | Old | 188 |
| 11680 | New | 175 |
This sample demonstrates how you use HERE Real-time Traffic to render map in your Map Suite GIS applications. Before running this sample, you need to config “AppId” and “AppCode” in App.Config. If you have ESRI or Here developer account, you can generate them on Here's official Web Site.
HERE Real-time Traffic provides the closest thing to a live depiction of the road. It identifies where, when and why traffic congestion occurs, and delivers up-to-the-minute information on the road conditions and incidents that could set a driver back.
This HereRealTimeTrafficLayer is supported in all of the Map Suite controls such as WPF, Web, MVC and WebAPI.
Learn how to extend the TrackInteractiveOverlay to add behaviors, like deleting the last added vertex when right-clicking the track line.
This example demonstrates how to get the zoom level of the map each time we change its extent. Using custom zoom levels, you will see how to get the zoom level with its characteristics such as the upper and lower scale defining it. You can read the comments inside the project to better understand the relationship of scales with zoom levels.
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes, rather than polygon shapes, by setting special column values. For features (both *Well Known Text* and *Well Known Binary*), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
In this Desktop project we create inner rings for a polygon, based on another polygon, using the GetDifference method. We also learn how to perform a Union on a collection of polygons, and how to set up the TrackEnded event.
To use this app, you need to track a polygon, double click to end it, and it will create an inner ring based on the unioned result of the polygons that are completely within the tracked polygon. You can look at the TrackEnded event handler to see all the different operations that are taking place for that task.
The Map Suite Routing Index Generator is a utility that will allow you to generate routing index files (“.rtg” and “.rtx”) from World Streets .sqlite database. These routing index files will be used by the Map Suite Routing Extension in order to calculate routes and driving directions. This utility allows you to specify things that one-way road information, as well as configuring the road speed and type of routes you would like to calculate. It is easily extendable to allow you to add code to deal with other routing situations.
The Jpeg2000 Sample template represents a .JP2 (JPEG2000) image type to be drawn on the map.
This WinForms project demonstrates how you can create a North American Land Data Assimilation System (NLDAS) grid layer. In this sample, you can find what NLDAS grid cells are fully contained in a given Shape file and what cells are partially contained. For each partially contained cell we can calculate what percent of the cell area is contained within the ShapeFile. Please refer to NLDAS grid for details.
This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later.
The Ecw Sample template represents an ECW file for drawing on the map.
ECW: ECW is a wavelet image compression system developed by ER Mapper.It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales. It is very popular in the GIS community.
This project is an example of how extensible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key, and how to have the vertex snap to any feature.
Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can easily be implemented by inheriting from EditInteractiveOverlay.
In this project, dedicated to EditInteractiveOverlay, you will see how easy it is to add some labeling to your dragged control point, showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the user experience, the closest point of the reference shape is also shown varying as the control point is dragged around.
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. In order to run this sample, development build 10.0.0.0 or later is required.
This sample includes a map with MrSID as base overlay, the MrSID shows the image data of the world range.
Known issue: The screenshot is taken under Linux, but it not well tested, maybe sometimes runs to exception.
In this project, we focus our attention on how to control the style of the control points. You will see how to override the DrawCore function of EditInteractiveOverlay.
ClusterPointStyle is integrated into Map Suite's styles. In this project you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have too many features which are stacked on top of each other making the map illegible at higher zoom levels. Clustering is a useful technique as it allows you to group together various features into one labeled symbol with the count of all the features.
This Desktop project shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
This project shows some advanced uses of the ClassBreakStyle to show how to label countries based on the area. You will notice that we also take advantage of the various zoom level sets for labeling purposes. The result is an eye pleasing labeling of the countries, with the size proportionate to the countries’ area, with more countries' labels appearing as you zoom in.
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinates needs to be set so that the feature gets selected within a constant distance in screen coordinates to where the user clicked, regardless of the zoom level.
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples.
