map_suite_desktop_for_winforms_labeling_samples
WinForms Samples
Multiple Labels Sample for WinForms
Screenshot
View this sample on Github
Labeling Based On Size Sample for WinForms
This project shows some advanced uses of the ClassBreakStyle to show how to label countries based on the area. You will notice that we also take advantage of the various zoom level sets for labeling purposes. The result is an eye pleasing labeling of the countries, with the size proportionate to the countries’ area, with more countries' labels appearing as you zoom in.
Screenshot
map_suite_desktop_for_winforms_labeling_samples.txt · Last modified: 2020/03/08 06:37 (external edit)
