<!– Class –> Serves as the base class that defines the properties and methods shared by all types of overlays.
The <strong>Overlay</strong> has the similar concept as the layer. Different types of overlays stack over each other to form a map. An overlay object is responsible for getting the configuration infomation from the user and serialized to a json string to control the client javascript library to create appropriate client layer.
Usually an overlay represents an image with transparent background that is laid upon other overlay such as <strong>LayerOverlay</strong>, <strong>WmsOverlay</strong>. While the <strong>MarkerOverlay</strong> will not be rendered as an image, it is actually represents a <strong>div</strong> that holds bunch of marker images at client side.
There are basically two kinds of overlay: base overlay and non-base overlay.
The base overlay has its <strong>IsBaseOverlay</strong> property set to true. It is displayed as the background image of the map. In an <strong>OverlaySwither</strong>, there is a radio button beside its name. There can only be one base overlay be displayed at a time. You can click the radio button to switch the base overlay to show.
The non-base overlay has a false <strong>IsBaseOverlay</strong> property. These overlays can overlap on the base overlay or on themselves each other. They are displayed in the <strong>OverlaySwither</strong> with a check box beside their name. You can click the check box to show or hide that overlay.
*System.Object ThinkGeo.MapSuite.SilverlightEdition.Overlay *ThinkGeo.MapSuite.SilverlightEdition.BingMapsOverlay *ThinkGeo.MapSuite.SilverlightEdition.EditInteractiveOverlay *ThinkGeo.MapSuite.SilverlightEdition.ExtentInteractiveOverlay *ThinkGeo.MapSuite.SilverlightEdition.GoogleOverlay *ThinkGeo.MapSuite.SilverlightEdition.InMemoryMarkerOverlay *ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay *ThinkGeo.MapSuite.SilverlightEdition.LayerOverlay *ThinkGeo.MapSuite.SilverlightEdition.MarkerOverlay *ThinkGeo.MapSuite.SilverlightEdition.OpenStreetMapOverlay *ThinkGeo.MapSuite.SilverlightEdition.ServerLayerOverlay *ThinkGeo.MapSuite.SilverlightEdition.SimpleMarkerOverlay *ThinkGeo.MapSuite.SilverlightEdition.TiledWmsOverlay *ThinkGeo.MapSuite.SilverlightEdition.TrackInteractiveOverlay *ThinkGeo.MapSuite.SilverlightEdition.WmsOverlay *ThinkGeo.MapSuite.SilverlightEdition.WmtsOverlay ***ThinkGeo.MapSuite.SilverlightEdition.WorldMapKitWmsSilverlightOverlay
Draw | RectangleShape, OverlayDrawType | Zooms the overlay only to the extent that you specify. | |
Initialize | Map | This method initializes the overlay canvas such as width, height and z-index for first time. | |
Refresh | This method re-draws this overlay in current extent. | ||
ToScreenCoordinate | PointShape | This method returns a screen point from a point shape in world coordinates. | |
ToScreenCoordinate | Double, Double | This method returns a point shape in screen coordinates from the specified X, Y world coordinates. | |
ToScreenCoordinate | Point | This method returns a screen point from a point shape in world coordinates. | |
ToString | Object | ||
ToWorldCoordinate | PointShape | This method returns a point shape in world coordinates from a ScreenPointF structure. | |
ToWorldCoordinate | Double, Double | This method returns a point shape in world coordinates from the specified X, Y screen coordinates. | |
ToWorldCoordinate | Point | This method returns a point shape in world coordinates from a ScreenPointF structure. |
DrawAttributionCore | GeoCanvas | ||
DrawCore | RectangleShape | This method draws the features in the specified extent. | |
InitializeCore | This method initializes the overlay canvas such as width, height and z-index for first time. | ||
MemberwiseClone | Object | ||
OnDrawingAttribution | DrawingAttributionOverlayEventArgs | ||
OnDrawnAttribution | DrawnAttributionOverlayEventArgs | ||
PanAnimationCompletedCore | This method raised when Panning animation plays completed. | ||
ZoomStoryCompletedCore | This method raised when zooming animation plays completed. |
Attribution | String | ||
Name | String | Gets or sets the name of an overlay which will display in the OverlaySwitcher. | |
Opacity | Double | Gets or sets the opacity level of the overlay. | |
OverlayElement | FrameworkElement | An FrameworkElement that contains the overlay. | |
PanFrameX | SplineDoubleKeyFrame | Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation. | |
PanFrameY | SplineDoubleKeyFrame | Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation. | |
StoryboardForPanning | Storyboard | Gets the Storyboard object for panning. | |
StoryboardForZooming | Storyboard | Gets the Storyboard object for zooming. | |
TransitionEffect | TransitionEffect | Gets or Sets the transition effect to use when the map is panned or zoomed. | |
Visibility | Visibility | Gets or sets a value that indicates whether the overlay is visible on the map. | |
ZIndex | Int32 | Get or set z-index of overlay, The value is bigger, and the order is higher. | |
ZoomFrameX | SplineDoubleKeyFrame | Gets the SplineDoubleKeyFrame for zooming. | |
ZoomFrameY | SplineDoubleKeyFrame | Gets the SplineDoubleKeyFrame for zooming. |
MapInfo | Map | Gets or sets current map information. | |
ScaleTransform | ScaleTransform | Gets the ScaleTransform object of this overlay. | |
TransformGroup | TransformGroup | Gets the TranslateGroup object for panning and zooming. | |
TranslateTransform | TranslateTransform | Gets the TranslateTransform object of this overlay. |
This is constructor of Overlay class.
This is constructor of <strong>Overlay</strong> class.
| name | String<!– System.String –> | A string value indicating the name of this overlay. |
Zooms the overlay to the extent that you specify.
The overlay will be panned to the center and zoomlevel of the extent that you specify.
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | The new world extent of the map. |
| overlayDrawType | OverlayDrawType<!– ThinkGeo.MapSuite.SilverlightEdition.OverlayDrawType –> | The enum value indecating that the map draws features or not. |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay –> Go Back
| currentMap | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | Current map information. |
This method returns a screen point that is converted from the specified world coordinates.
This method converts the coordinates of a point shape to a point in screen coordinates.
| PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A screen point in pixels. |
| worldCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A point shape in world coordinates. |
This method converts X, Y world coordinates to a point in screen coordinates.
| worldX | Double<!– System.Double –> | The X world coordinate. |
| worldY | Double<!– System.Double –> | The Y world coordinate. |
| worldCoordinate | Point<!– System.Windows.Point –> | A point in world coordinates. |
This method returns a point shape in world coordinates from screen coordinates.
This method converts a screen point to a point in world coordinates.
| screenCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | The point (in screen coordinates) to convert to world coordinates. |
This method returns a point shape in world coordinates from the specified screen coordinates.
This method converts X, Y screen coordinates to a point shape in world coodinates.
| screenX | Double<!– System.Double –> | The X-value in pixels referenced to the screen origin. |
| screenY | Double<!– System.Double –> | The Y-value in pixels referenced to the screen origin. |
| screenCoordinate | Point<!– System.Windows.Point –> | The point (in screen coordinates) to convert to world coordinates. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.SilverlightCore.GeoCanvas –> |
| args | DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawingAttributionOverlayEventArgs –> |
| args | DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawnAttributionOverlayEventArgs –> |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent(1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
| FrameworkElement<!– System.Windows.FrameworkElement –> |
| SplineDoubleKeyFrame<!– System.Windows.Media.Animation.SplineDoubleKeyFrame –> |
| Storyboard<!– System.Windows.Media.Animation.Storyboard –> |
| TransitionEffect<!– ThinkGeo.MapSuite.SilverlightEdition.TransitionEffect –> |
| Visibility<!– System.Windows.Visibility –> |
| ScaleTransform<!– System.Windows.Media.ScaleTransform –> |
| TransformGroup<!– System.Windows.Media.TransformGroup –> |
| TranslateTransform<!– System.Windows.Media.TranslateTransform –> |
| Event Arguments |
| Event Arguments |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
