thinkgeo.mapsuite.portablecore.ringshape
ThinkGeo.MapSuite.Core.RingShape
This class represents a closed ring of points.
    • ThinkGeo.MapSuite.Core.BaseShape
      • ThinkGeo.MapSuite.Core.AreaBaseShape
        • ThinkGeo.MapSuite.Core.RingShape
RingShape()
This constructor creates a RingShape.
RingShape(IEnumerable<Vertex>)
  • points
    • Type:IEnumerable<Vertex>
RingShape(String)
  • wellKnownText
RingShape(Byte[])
  • wellKnownBinary
    • Type:Byte[]
ToPolygon()
This method returns the current shape as a PolygonShape.
This method is mainly used to convert this GIS non-standard shape to a GIS standard shape.
  • Description:This method returns the current shape as a PolygonShape.
RemoveVertex(Vertex)
This method removes the selected vertex from ring shape.
  • Description:If remove sucess it will return true, otherwise return false.
  • selectedVertex
    • Type:Vertex
    • Description:The selected vertex must be a vertex of ring shape, otherwise it will return false and ring shape will keep the same.
ReversePoints()
This method reverses the order of the points in the ring.
GetAccuratePerimeter(Int32,DistanceUnit,DistanceCalculationMode)
  • shapeSrid
GetAccuratePerimeter(String,DistanceUnit,DistanceCalculationMode)
  • shapeProj4ProjectionParameters
GetAccurateArea(Int32,AreaUnit,DistanceCalculationMode)
  • shapeSrid
  • returningUnit
GetAccurateArea(String,AreaUnit,DistanceCalculationMode)
  • returningUnit
  • returningUnit
ScaleUp(Double)
  • percentage
ScaleDown(Double)
  • percentage
GetConvexHull()
GetIntersection(Feature)
  • targetFeature
Union(AreaBaseShape)
Union(Feature)
  • targetFeature
GetDifference(AreaBaseShape)
GetDifference(Feature)
  • targetFeature
GetSymmetricalDifference(AreaBaseShape)
GetSymmetricalDifference(Feature)
  • targetFeature
  • tolerance
  • tolerance
LoadFromWellKnownData(String)
  • wellKnownText
GetWellKnownText()
GetGeoJson()
GetWellKnownText(RingOrder)
  • outerRingOrder
LoadFromWellKnownData(Byte[])
  • wellKnownBinary
    • Type:Byte[]
GetWellKnownBinary()
  • Type:Byte[]
  • Type:Byte[]
GetWellKnownBinary(RingOrder)
  • Type:Byte[]
  • outerRingOrder
GetWellKnownBinary(RingOrder,WkbByteOrder)
  • Type:Byte[]
  • outerRingOrder
GetBoundingBox()
GetWellKnownType()
CloneDeep()
  • xOffsetDistance
  • yOffsetDistance
  • xOffsetDistance
  • yOffsetDistance
  • distance
  • angleInDegrees
  • distance
  • angleInDegrees
Rotate(PointShape,Single)
  • degreeAngle
    • Type:Single
  • targetFeature
  • targetFeature
GetCenterPoint()
  • distance
  • distance
  • quadrantSegments
  • distance
  • quadrantSegments
  • targetFeature
  • fromPoint
  • toPoint
Validate(ShapeValidationMode)
IsDisjointed(BaseShape)
IsDisjointed(Feature)
  • targetFeature
Intersects(BaseShape)
Intersects(Feature)
  • targetFeature
Touches(BaseShape)
Touches(Feature)
  • targetFeature
Crosses(BaseShape)
Crosses(Feature)
  • targetFeature
IsWithin(BaseShape)
IsWithin(Feature)
  • targetFeature
Contains(BaseShape)
Contains(Feature)
  • targetFeature
Overlaps(BaseShape)
Overlaps(Feature)
  • targetFeature
IsTopologicallyEqual(Feature)
  • targetFeature
GetFeature()
  • columnValues
GetCrossing(BaseShape)
ScaleTo(Double)
  • scale
RemoveVertex(Vertex,RingShape)
  • selectedVertex
    • Type:Vertex
  • ringShape
    • Type:RingShape
    • Description:The line shape will be removed one vertex.
GetWellKnownTypeCore()
This method returns the well-known type for the shape.
CloneDeepCore()
This method returns a complete copy of the shape without any references in common.
When you override this method, you need to ensure that there are no references in common between the original and the copy.
  • Type:BaseShape
This method returns the perimeter of the shape, defined as the sum of the lengths of all its sides.
You would use this method to find the distance around the area shape.
  • Description:The return unit is based on the LengthUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
  • shapeUnit
  • returningUnit
    • Description:This is the DistanceUnit you would like to use as the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
This method returns the area of the shape, defined as the size of the region enclosed by the figure.
You would use this method to find the area inside the shape.
  • Description:The return unit is based on the AreaUnit you specify in the returningUnit parameter, regardless of the shape's GeographyUnit.
  • shapeUnit
  • returningUnit
    • Type:AreaUnit
    • Description:This is the AreaUnit you would like to use as the return value. For example, if you select square miles as your returningUnit, then the distance will be returned in square miles.
ScaleUpCore(Double)
This method increases the size of the area shape by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, as you are applying the operation multiple times. There is also a ScaleDown method that will shrink the shape.
  • percentage
ScaleDownCore(Double)
This method decreases the size of the area shape by the percentage given in the percentage parameter.
  • percentage
GetBoundingBoxCore()
The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry. Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects. If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area.
This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
  • Type:BaseShape
  • fromPoint
  • toPoint
  • fromUnit
  • toUnit
This method moves the base shape from one location to another, based on an X and Y offset distance.
This method moves the base shape from one location to another, based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape 1 unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles to on the X axis and 3 miles on the Y axis.
  • xOffsetDistance
    • Description:This is the number of horizontal units of movement in the DistanceUnit specified as the distanceUnit.
  • yOffsetDistance
  • shapeUnit
  • distanceUnit
This method moves the base shape from one location to another, based on a distance and a direction in degrees.
This method moves the base shape from one location to another, based on an angleInDegrees and distance parameter. With this overload, it is important to note that the distance units are the same GeographicUnit as the shape. For example, if your shape is in decimal degrees and you call this method with a distance of 1, you're going to move this shape 1 decimal degree in direction of the angleInDegrees. In many cases it is more useful to specify the DistanceUnit of movement, such as in miles or yards, so for these scenarios there is another overload you may want to use instead.If you pass a distance of 0, then the operation is ignored.
  • distance
  • angleInDegrees
  • shapeUnit
  • distanceUnit
RotateCore(PointShape,Single)
This method rotates the shape a number of degrees based on a pivot point. By placing the pivot point in the center of the shape, you can achieve in-place rotation. By moving the pivot point outside of the center of the shape, you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
  • pivotPoint
  • degreeAngle
    • Type:Single
In this method, we compute the closest distance between the two shapes. The returned unit will be in the unit of distance specified.
  • Description:The return type is the distance between this shape and the targetShape in the GeographyUnit of the shape. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
  • targetShape
    • Type:BaseShape
  • shapeUnit
    • Description:The GeographUnit of the targetShape.
  • distanceUnit
    • Description:The DistanceUnit of the returned value.
  • targetShape
    • Type:BaseShape
  • shapeUnit
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe a geometry as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometric shapes.POINT(5 17)LINESTRING(4 5,10 50,25 80)POLYGON1)MULTIPOINT(3.7 9.7,4.9 11.6)MULTILINESTRING2)MULTIPOLYGON3),4))
  • outerRingOrder
This method returns a byte array that represents the shape in well-known binary.
This method returns a byte array that represents the shape in well-known binary. Well-known binary allows you to describe a geometry as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well-known text as well.
  • Type:Byte[]
  • outerRingOrder
  • byteOrder
    • Description:This parameter specifies whether the byte order is big- or little-endian.
  • Description:None
  • wellKnownText
This method hydrates the current shape with its data from well-known binary.
  • Description:None
  • wellKnownBinary
    • Type:Byte[]
  • validationMode
TUM=()
ReversePointsCore()
TkM=()
GetAccuratePerimeterCore(String,DistanceUnit,DistanceCalculationMode)
GetAccurateAreaCore(String,AreaUnit,DistanceCalculationMode)
  • returningUnit
GetConvexHullCore()
UnionCore(AreaBaseShape)
GetDifferenceCore(AreaBaseShape)
GetSymmetricalDifferenceCore(AreaBaseShape)
  • tolerance
GetGeoJsonCore()
GetCenterPointCore()
  • distance
  • quadrantSegments
IsDisjointedCore(BaseShape)
IntersectsCore(BaseShape)
TouchesCore(BaseShape)
CrossesCore(BaseShape)
IsWithinCore(BaseShape)
ContainsCore(BaseShape)
OverlapsCore(BaseShape)
GetCrossingCore(BaseShape)
ScaleToCore(Double)
  • scale
SEM=(RingShape,Double,Double,Double)
  • targetRingShape
  • multiplicator
  • centerX
  • centerY
Vertices
This property is the collection of points that make up the RingShape.
Id
Tag
CanRotate
4) 4 4,7 3,7 5,4 4
thinkgeo.mapsuite.portablecore.ringshape.1442823456.txt.gz · Last modified: 2015/09/21 08:17 by admin
