<!– Class –> Represents the ordinary marker style.
The <strong>PointMarkerStyle</strong> contains the basic style for creating a marker such as a web image, popup and context menu. Use this style to create a batch of markers that all have the same appearance.
*System.Object ThinkGeo.MapSuite.MvcEdition.MarkerStyle *ThinkGeo.MapSuite.MvcEdition.PointMarkerStyle
PointMarkerStyle | Initialize an instance of the PointMarkerStyle class. | ||
PointMarkerStyle | WebImage | Initialize an instance of the PointMarkerStyle class. | |
PointMarkerStyle | WebImage, CustomPopup | Initialize an instance of the PointMarkerStyle class. | |
PointMarkerStyle | WebImage, CustomPopup, ContextMenu | Initialize an instance of the PointMarkerStyle class. |
GetMarkers | IEnumerable<Feature> | MarkerStyle(overriden) | Returns a collection of markers that are created with specific styles from the features passed in. |
GetContextMenusCore | MarkerStyle(overriden) | Gets a collection of context menus that are associated with the MarkerStyle. | |
ContextMenu | ContextMenu | Gets or sets a context menu object that displays when you right-click on the marker. | |
Opacity | Single | Gets or sets a float value between 0 and 1 that indicates the transparency level of the marker. | |
Popup | CustomPopup | Gets or sets the popup object that displays when the mouse pointer is over a marker. | |
PopupDelay | Int32 | Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays. | |
WebImage | WebImage | Gets or sets the small image that the marker displays as its icon. |
| webImage | WebImage<!– ThinkGeo.MapSuite.MvcEdition.WebImage –> | The small image that the marker displays. |
| popup | CustomPopup<!– ThinkGeo.MapSuite.MvcEdition.CustomPopup –> | The popup window that appears when the mouse pointer is over the marker. |
| contextMenu | ContextMenu<!– ThinkGeo.MapSuite.MvcEdition.ContextMenu –> | The context menu that appears when you right-click on the marker. |
| Collection<Marker><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MvcEdition.Marker} –> |
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | A collection of features that the markers are created from. |
<!– ThinkGeo.MapSuite.MvcEdition.MarkerStyle(overriden) –> Go Back
| GeoKeyedCollection<ContextMenu><!– ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection{ThinkGeo.MapSuite.MvcEdition.ContextMenu} –> | A collection of context menus that are associated with the MarkerStyle. |
<!– ThinkGeo.MapSuite.MvcEdition.PointMarkerStyle –> Go Back
The <strong>Opacity</strong> property enables you to specify a level of transparency for the marker. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the marker completely invisible.
The <strong>PopupDelay</strong> value is counted in milliseconds. If it is set to 500, the popup will display 500ms after the mouse pointer hovers over the marker.
