<!– Class –> Defines the properties and methods that are shared by all controls on the map.
This is the base class that all of the map controls are derived from.
*System.Object ThinkGeo.MapSuite.MvcEdition.MapTool *ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool *ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool *ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool *ThinkGeo.MapSuite.MvcEdition.LogoMapTool *ThinkGeo.MapSuite.MvcEdition.MeasureMapTool *ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool *ThinkGeo.MapSuite.MvcEdition.MouseCoordinateMapTool *ThinkGeo.MapSuite.MvcEdition.MouseMapTool *ThinkGeo.MapSuite.MvcEdition.OverlaySwitcherMapTool *ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool *ThinkGeo.MapSuite.MvcEdition.PanZoomMapTool *ThinkGeo.MapSuite.MvcEdition.ScaleLineMapTool *ThinkGeo.MapSuite.MvcEdition.TouchMapTool
![]() | Object | ||
![]() | Object |
![]() | Boolean | Gets or sets a value that turns the feature on and off. |
Initialize an instance of the MapTool class.
Name | Type | Description |
Initialize an instance of the MapTool class with a boolean value that indicates whether it is enabled.
enabled | Boolean<!– System.Boolean –> | A boolean value that indicates whether this MapTool is enabled. |
Return Type | Description |
Load this object from a json string.
Void<!– System.Void –> |
jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> | A JSON string that represents the map control. |
Return Type |
