This constructor creates the MultilineShape.
An ordered Multiline means that we can walk though the MultiLine from the first point to the last point without any branches, and that each line's end points should be within the given tolerance. If using this overload, the unit of the Multiline and the tolerance are both defaulted to meters. Please use the other overload if you want to specify the units yourself.
Reorder(PointShape,Double,GeographyUnit,DistanceUnit)
This API is used to make the lines within the Multiline ordered.
An ordered Multiline means that we can walk though the MultiLine from the first point to the last point without any branches, and that each line's end points should be within the given tolerance. When using this overload, you can specify the unit for the Multiline as well as the unit for the tolerance.
GetPointOnALine(StartingPoint,Single)
This method returns a PointShape on the line, based on a percentage of the length of the line from either its first or last vertex (as defined by the startingPoint parameter).
If you pass 100 or 0 as the percentage of the line, it will return either the first or last vertex, depending on the value of the startingPoint argument.
GetPointOnALine(StartingPoint,Double,GeographyUnit,DistanceUnit)
This method returns a PointShape on the line, based on a distance on the line from the first or last vertex (as defined by the startingPoint parameter).
Passing in a distance of 0 will return either the first or last point on the line, depending on the value of the startingPoint parameter.
GetLineOnALine(StartingPoint,Single,Single)
This method returns a BaseLineShape, based on a starting position and other factors.
GetLineOnALine(StartingPoint,Single)
GetLineOnALine(StartingPoint,Double,Double,GeographyUnit,DistanceUnit)
GetLineOnALine(StartingPoint,PointShape)
GetLineOnALine(PointShape,PointShape)
This method removes the selected vertex from multiline shape.
The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry. Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects. If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
When you override this method, you need to ensure that there are no references in common between the original and the copy.
ReorderCore(PointShape,Double,GeographyUnit,DistanceUnit)
GetLengthCore(GeographyUnit,DistanceUnit)
This method returns the length of the LineShape.
This method is useful when you want to know the total length of a line-based shape. If the shape is a MultilineShape, then the length is the sum of all of its lines. There is also an overload which allows you to specify the returning length in the unit of your choice.
GetPointOnALineCore(StartingPoint,Double,GeographyUnit,DistanceUnit)
GetLineOnALineCore(StartingPoint,Double,Double,GeographyUnit,DistanceUnit)
This method increases the size of the LineShape by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, as you are applying the operation multiple times. There is also a ScaleDown method that will shrink the shape.
This method decreases the size of the LineShape by the percentage given in the percentage parameter.
This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, as you are applying the operation multiple times. There is also a ScaleUp method that will enlarge the shape.
This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
This method moves the base shape from one location to another based on a distance and a direction in degrees.
This method moves the base shape from one location to another, based on an angleInDegrees and distance parameter. With this overload, it is important to note that the distance units are the same GeographicUnit as the shape. For example, if your shape is in decimal degrees and you call this method with a distance of 1, you're going to move this shape 1 decimal degree in direction of the angleInDegrees. In many cases it is more useful to specify the DistanceUnit of movement, such as in miles or yards, so for these scenarios there is another overload you may want to use instead.If you pass a distance of 0, then the operation is ignored.
This method rotates the shape by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape, you can achieve in-place rotation. By moving the pivot point outside of the center of the shape, you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe a geometry as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometric shapes.POINT(5 17)LINESTRING(4 5,10 50,25 80)POLYGON1)MULTIPOINT(3.7 9.7,4.9 11.6)MULTILINESTRING2)MULTIPOLYGON3),4))
This method returns the well-known type for the shape.
This method hydrates the current shape with its data from well-known binary.
This method returns the crossing points between the current shape and the passed-in target shape.
UnionCore(IEnumerable<LineBaseShape>)
