thinkgeo.mapsuite.core.linebaseshape
Table of Contents
ThinkGeo.MapSuite.Core.LineBaseShape
<!– Class –> This abstract class is the root of all line-based shapes, such as LineShape and MultilineShape.
This class is used as the base class for line shapes such as:
LineShape MultilineShape
It can be inherited from to create your own specialized line geometry. If you choose to do this, your new class must conform to one of the well-known text standard shapes in order for the base implementations to work properly.
Protected MethodLineBaseShape This is the default constructor for AreaBaseShape.
Public MethodBuffer Double, Int32, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Public MethodBuffer Double, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Public MethodBuffer Double, Int32, BufferCapType, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Public MethodCloneDeep BaseShape This method returns a complete copy of the shape without any references in common.
Public MethodContains BaseShape BaseShape This method returns if the targetShape lies within the interior of the current shape.
Public MethodContains Feature BaseShape This method returns if the targetFeature lies within the interior of the current shape.
Public MethodConvexHull This method returns the convex hull of the shape defined as the smallest convex ring that contains all the points in the shape.
Public MethodStatic MemberCreateShapeFromGeoJson String BaseShape
Public MethodStatic MemberCreateShapeFromWellKnownData String BaseShape This method creates a BaseShape from a string of well-known text.
Public MethodStatic MemberCreateShapeFromWellKnownData Byte[] BaseShape This method creates a BaseShape from a string of well-known binary.
Public MethodCrosses Feature BaseShape This method returns if the current shape and the targetFeature share some but not all interior points.
Public MethodCrosses BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all interior points.
Public MethodGetAccurateLength Int32, DistanceUnit, DistanceCalculationMode
Public MethodGetAccurateLength String, DistanceUnit, DistanceCalculationMode
Public MethodGetBoundingBox BaseShape This method calculates the smallest RectangleShape that encompasses the entire geometry.
Public MethodGetCenterPoint BaseShape This method returns the center point of the current shape's bounding box.
Public MethodGetClosestPointTo BaseShape, GeographyUnit BaseShape This method returns the point of the current shape that is closest to the target shape.
Public MethodGetClosestPointTo Feature, GeographyUnit BaseShape This method returns the point of the current shape that is closest to the target feature.
Public MethodGetCrossing BaseShape BaseShape This method returns the crossing points between the current shape and the passed-in target shape.
Public MethodGetDistanceTo Feature, GeographyUnit, DistanceUnit BaseShape This method computes the distance between the current shape and the targetFeature.
Public MethodGetDistanceTo BaseShape, GeographyUnit, DistanceUnit BaseShape This method computes the distance between the current shape and the targetShape.
Public MethodGetFeature BaseShape Get a corresponding feature which has the same Id and BaseShape as the current shape.
Public MethodGetFeature IDictionary<String, String> BaseShape Get a corresponding feature which has the same Id and BaseShape as the current shape. Additionally, pass the specified columnValues into the returned feature.
Public MethodGetGeoJson BaseShape
Public MethodGetIntersection Feature
Public MethodGetIntersection AreaBaseShape
Public MethodGetLength GeographyUnit, DistanceUnit This method returns the length of the line shape.
Public MethodGetShortestLineTo BaseShape, GeographyUnit BaseShape This method returns the shortest LineShape between this shape and the targetShape parameter.
Public MethodGetShortestLineTo Feature, GeographyUnit BaseShape This method returns the shortest LineShape between this shape and the targetFeature. parameter.
Public MethodGetType Object
Public MethodGetWellKnownBinary WkbByteOrder BaseShape This method returns a byte array that represents the shape in well-known binary.
Public MethodGetWellKnownBinary BaseShape This method returns a byte array that represents the shape in well-known binary.
Public MethodGetWellKnownBinary RingOrder, WkbByteOrder BaseShape
Public MethodGetWellKnownBinary RingOrder BaseShape
Public MethodGetWellKnownText BaseShape This method returns the well-known text representation of this shape.
Public MethodGetWellKnownText RingOrder BaseShape This method returns the well-known text representation of this shape.
Public MethodGetWellKnownType BaseShape This method returns the well-known type for the shape.
Public MethodIntersects BaseShape BaseShape This method returns if the current shape and the targetShape have at least one point in common.
Public MethodIntersects Feature BaseShape This method returns if the current shape and the targetFeature have at least one point in common.
Public MethodIsDisjointed BaseShape BaseShape This method returns if the current shape and the targetShape have no points in common.
Public MethodIsDisjointed Feature BaseShape This method returns if the current shape and the targetFeature have no points in common.
Public MethodIsTopologicallyEqual Feature BaseShape This method returns if the current shape and the targetFeature are topologically equal.
Public MethodIsTopologicallyEqual BaseShape BaseShape This method returns if the current shape and the targetShape are topologically equal.
Public MethodIsWithin Feature BaseShape This method returns if the current shape lies within the interior of the targetFeature.
Public MethodIsWithin BaseShape BaseShape This method returns if the current shape lies within the interior of the targetShape.
Public MethodLoadFromWellKnownData String BaseShape This method hydrates the current shape with its data from well-known text.
Public MethodLoadFromWellKnownData Byte[] BaseShape This method hydrates the current shape with its data from well-known binary.
Public MethodOverlaps BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all points in common.
Public MethodOverlaps Feature BaseShape This method returns if the current shape and the targetFeature share some but not all points in common.
Public MethodRegister PointShape, PointShape, DistanceUnit, GeographyUnit BaseShape This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Public MethodRegister Feature, Feature, DistanceUnit, GeographyUnit BaseShape This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Public MethodStatic MemberRotate BaseShape, PointShape, Single BaseShape This method returns a shape rotated by a number of degrees based on a pivot point.
Public MethodRotate PointShape, Single BaseShape This method rotates a shape a number of degrees based on a pivot point.
Public MethodStatic MemberRotate Feature, PointShape, Single BaseShape This method returns a feature rotated by a number of degrees based on a pivot point.
Public MethodStatic MemberScaleDown LineBaseShape, Double This method returns a new shape that is decreases by the percentage given in the percentage parameter.
Public MethodStatic MemberScaleDown Feature, Double This method returns a new feature that is decreases by the percentage given in the percentage parameter.
Public MethodScaleDown Double This method decreases the size of the LineShape by the percentage given in the percentage parameter.
Public MethodScaleTo Double BaseShape This method increases or decreases the size of the shape by the specified scale factor given in the parameter.
Public MethodStatic MemberScaleTo BaseShape, Double BaseShape This method increases or decreases the size of the shape by the specified scale factor given in the parameter.
Public MethodStatic MemberScaleUp LineBaseShape, Double This method returns a new shape that is increased by the percentage given in the percentage parameter.
Public MethodStatic MemberScaleUp Feature, Double This method returns a new feature that is increased by the percentage given in the percentage parameter.
Public MethodScaleUp Double This method increases the size of the LineShape by the percentage given in the percentage parameter.
Public MethodStatic MemberSimplify LineBaseShape, Double, SimplificationType Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
Public MethodSimplify GeographyUnit, Double, DistanceUnit, SimplificationType Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
Public MethodSimplify Double, SimplificationType Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
Public MethodStatic MemberSimplify LineBaseShape, GeographyUnit, Double, DistanceUnit, SimplificationType Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
Public MethodToString Object
Public MethodTouches Feature BaseShape This method returns of the current shape and the targetFeature have at least one boundary point in common, but no interior points.
Public MethodTouches BaseShape BaseShape This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points.
Public MethodStatic MemberTranslateByDegree Feature, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
Public MethodStatic MemberTranslateByDegree BaseShape, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
Public MethodTranslateByDegree Double, Double, GeographyUnit, DistanceUnit BaseShape This method moves a base shape from one location to another based on a distance and a direction in degrees.
Public MethodTranslateByDegree Double, Double BaseShape This method moves a base shape from one location to another based on a distance and a direction in degrees.
Public MethodStatic MemberTranslateByOffset Feature, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a feature repositioned from one location to another based on an X and Y offset distance.
Public MethodStatic MemberTranslateByOffset BaseShape, Double, Double, GeographyUnit, DistanceUnit BaseShape This method returns a shape repositioned from one location to another based on an X and Y offset distance.
Public MethodTranslateByOffset Double, Double, GeographyUnit, DistanceUnit BaseShape This method moves a base shape from one location to another based on an X and Y offset distance.
Public MethodTranslateByOffset Double, Double BaseShape This method moves a base shape from one location to another based on an X and Y offset distance.
Public MethodStatic MemberUnion IEnumerable<Feature>
Public MethodUnion LineBaseShape Calculates a new geometry that contains all the points in this LineBaseShape and input LineBaseShape
Public MethodStatic MemberUnion IEnumerable<LineBaseShape> Calculates a new geometry that contains all the points in this LineBaseShape and input LineBaseShape set.
Public MethodUnion Feature
Public MethodValidate ShapeValidationMode BaseShape This method returns a ShapeValidationResult based on a series of tests.
Protected MethodBufferCore Double, Int32, BufferCapType, GeographyUnit, DistanceUnit BaseShape This method computes the area containing all of the points within a given distance from this shape.
Protected MethodCloneDeepCore BaseShape This method returns a complete copy of the shape without any references in common.
Protected MethodContainsCore BaseShape BaseShape This method returns if the targetShape lies within the interior of the current shape.
Protected MethodConvexHullCore This method returns the convex hull of the shape defined as the smallest convex ring that contains all the points in the shape.
Protected MethodCrossesCore BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all interior points.
Protected MethodGetAccurateLengthCore String, DistanceUnit, DistanceCalculationMode
Protected MethodGetBoundingBoxCore BaseShape This method calculates the smallest RectangleShape that encompasses the entire geometry.
Protected MethodGetCenterPointCore BaseShape This method returns the center point of the current shape's bounding box.
Protected MethodGetClosestPointToCore BaseShape, GeographyUnit BaseShape This method returns the point of the current shape that is closest to the target shape.
Protected MethodGetCrossingCore BaseShape BaseShape This method returns the crossing points between the current shape and the passed-in target shape.
Protected MethodGetDistanceToCore BaseShape, GeographyUnit, DistanceUnit BaseShape This method computes the distance between the current shape and the targetShape.
Protected MethodGetGeoJsonCore BaseShape
Protected MethodGetIntersectionCore AreaBaseShape
Protected MethodGetLengthCore GeographyUnit, DistanceUnit This method returns the length of the line shape.
Protected MethodGetShortestLineToCore BaseShape, GeographyUnit BaseShape This method returns the shortest LineShape between this shape and the targetShape parameter.
Protected MethodGetWellKnownBinaryCore RingOrder, WkbByteOrder BaseShape This method returns a byte array that represents the shape in well-known binary.
Protected MethodGetWellKnownTextCore RingOrder BaseShape
Protected MethodGetWellKnownTypeCore BaseShape This method returns the well-known type for the shape.
Protected MethodIntersectsCore BaseShape BaseShape This method returns if the current shape and the targetShape have at least one point in common.
Protected MethodIsDisjointedCore BaseShape BaseShape This method returns if the current shape and the targetShape have no points in common.
Protected MethodIsTopologicallyEqualCore BaseShape BaseShape This method returns if the current shape and the targetShape are topologically equal.
Protected MethodIsWithinCore BaseShape BaseShape This method returns if the current shape lies within the interior of the targetShape.
Protected MethodLoadFromWellKnownDataCore String BaseShape This method hydrates the current shape with its data from well-known text.
Protected MethodLoadFromWellKnownDataCore Byte[] BaseShape This method hydrates the current shape with its data from well-known binary.
Protected MethodOverlapsCore BaseShape BaseShape This method returns if the current shape and the targetShape share some but not all points in common.
Protected MethodRegisterCore PointShape, PointShape, DistanceUnit, GeographyUnit BaseShape This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
Protected MethodRotateCore PointShape, Single BaseShape This method rotates a shape a number of degrees based on a pivot point.
Protected MethodScaleDownCore Double This method decreases the size of the LineShape by the percentage given in the percentage parameter.
Protected MethodScaleToCore Double BaseShape This method increases or decreases the size of the shape by the specified scale factor given in the parameter.
Protected MethodScaleUpCore Double This method increases the size of the LineShape by the percentage given in the percentage parameter.
Protected MethodSimplifyCore Double, SimplificationType Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
Protected MethodTouchesCore BaseShape BaseShape This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points.
Protected MethodTranslateByDegreeCore Double, Double, GeographyUnit, DistanceUnit BaseShape This method moves a base shape from one location to another based on a distance and a direction in degrees.
Protected MethodTranslateByOffsetCore Double, Double, GeographyUnit, DistanceUnit BaseShape This method moves a base shape from one location to another based on an X and Y offset distance.
Protected MethodUnionCore IEnumerable<LineBaseShape> The protected virtual method used by “Union” that you can overwrite to implement your own logic.
Protected MethodValidateCore ShapeValidationMode BaseShape This method returns a ShapeValidationResult based on a series of tests.
Public PropertyCanRotate Boolean BaseShape This property specifies whether the shape can be rotated.
Public PropertyId String BaseShape The id of the shape.
Public PropertyTag Object BaseShape The tag of the shape.
LineBaseShape()
This constructor simply calls the base constructor.
Name Type Description
Go Back
Buffer(Double, Int32, GeographyUnit, DistanceUnit)
This method computes the area containing all of the points within a given distance from this shape. In this case, you will be using the rounded RoundedBufferCapStyle. The distance unit is determined by the distanceUnit argument.
Return Type Description
MultipolygonShape<!– ThinkGeo.MapSuite.Core.MultipolygonShape –> The return type is a MultiPolygonShape that represents all of the points within a given distance from the shape.
distance Double<!– System.Double –> The distance is the number of units to buffer the current shape. The distance unit will be the one specified in the distanceUnit parameter.
quadrantSegments Int32<!– System.Int32 –> The quadrant segments are the number of points in each quarter circle. A good default is 8, but if you want smoother edges you can increase this number. The valid range for this number is from 3 to 100.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This is the geographic unit of the shape you are performing the operation on.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This is the distance unit you would like to use as the distance. For example, if you select miles as your distanceUnit, then the distance will be calculated in miles for the operation.
<!– ThinkGeo.MapSuite.Core.BaseShape –> Go Back
Buffer(Double, GeographyUnit, DistanceUnit)
This method computes the area containing all of the points within a given distance from this shape. In this case, you will be using the rounded RoundedBufferCapStyle and the default 8 quadrant segments. The distance unit is determined by the distanceUnit argument.
Buffer(Double, Int32, BufferCapType, GeographyUnit, DistanceUnit)
bufferCapType BufferCapType<!– ThinkGeo.MapSuite.Core.BufferCapType –> The bufferCapType determines how the caps of the buffered object look. They range from rounded to squared off.
CloneDeep()
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method returns a complete copy of the shape without any references in common.
Contains(BaseShape)
Boolean<!– System.Boolean –> This method returns if the targetShape lies within the interior of the current shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The shape you wish to compare the current one to.
Contains(Feature)
Boolean<!– System.Boolean –> This method returns if the targetFeature lies within the interior of the current shape.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The targetFeature that contains a shape you wish to compare the current one to.
ConvexHull()
This method is useful when you want to create a perimeter around the shape. For example if you had a MultiPolygon which represented buildings in a campus you could easily get the convex hull of the buildings and determine the perimeter of all of the buildings together. This also works with MultiPoint shapes where each point may represent a certain type of person you are doing statistics on. With convex hull you can get an idea of the regions those points are located in.
As this is a concrete public method that wraps a Core method we reserve the right to add events and other logic to pre or post process data returned by the Core version of the method. In this way we leave our framework open on our end but also allow you the developer to extend our logic to your needs. If you have questions about this please contact support as we would be happy to work with you on extending our framework.
RingShape<!– ThinkGeo.MapSuite.Core.RingShape –> This method returns a RingShape defined as the smallest convex ring that contains all the points in the shape.
<!– ThinkGeo.MapSuite.Core.LineBaseShape –> Go Back
CreateShapeFromGeoJson(String)
<!– static –>
geoJson String<!– System.String –>
CreateShapeFromWellKnownData(String)
<!– static –> This method creates a BaseShape from a string of well-known text.
This method creates a BaseShape from a string of well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
LINESTRING(4 5,10 50,25 80)
POLYGON1)
MULTIPOINT(3.7 9.7,4.9 11.6)
MULTILINESTRING2)
MULTIPOLYGON3),4))
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The return type is a higher level shape constructed from the well-known text you passed into the method. Though the object is a higher level shape, such as a PolygonShape or MultiPointShape, you will need to cast it to that shape in order to use its unique properties.
wellKnownText String<!– System.String –> A string representing the geometry in well-known text format.
CreateShapeFromWellKnownData(Byte[])
<!– static –> This method creates a BaseShape from a string of well-known binary.
This method creates a BaseShape from a string of well-known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well-known text as well.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The return type is a higher level shape constructed from the well-known binary you passed into the method. Though the object is a higher level shape, such as a PolygonShape or MultiPointShape, you will need to cast it to that shape in order to use its unique properties.
wellKnownBinary Byte[]<!– System.Bytethinkgeo.mapsuite.core.linebaseshape –> An array of bytes representing the geometry in well-known binary format.
Crosses(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature share some but not all interior points.
Crosses(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape share some but not all interior points.
GetAccurateLength(Int32, DistanceUnit, DistanceCalculationMode)
shapeSrid Int32<!– System.Int32 –>
returningUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –>
distanceCalculationMode DistanceCalculationMode<!– ThinkGeo.MapSuite.Core.DistanceCalculationMode –>
GetAccurateLength(String, DistanceUnit, DistanceCalculationMode)
shapeProj4ProjectionParameters String<!– System.String –>
GetBoundingBox()
The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry.
Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects.
If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area.
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> The RectangleShape returned is the smallest RectangleShape that can encompass the entire geometry.
GetCenterPoint()
This method returns the center point of the current shape's bounding box. It is important to note that this is the center point of the bounding box. There are numerous ways to calculate the “center” of a geometry, such as its weighted center, etc. You can find other centers by examining the various methods of the shape itself.
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> A PointShape representing the center point of the current shape's bounding box.
GetClosestPointTo(BaseShape, GeographyUnit)
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> A PointShape representing the closest point of the current shape to the targetShape.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The shape you are trying to find the closest point to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> The geographic unit of the shape you are trying to find the closet point to.
GetClosestPointTo(Feature, GeographyUnit)
This method returns the point of the current shape that is closest to the target feature. It is often the case that the point returned is not a point of the object itself. An example would be a line with two points that are far apart from each other. If you set the targetFeature to be a point midway between the points but a short distance away from the line, the method would return a point that is on the line but not either of the two points that make up the line.
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> A PointShape representing the closest point of the current shape to the targetFeature.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The feature you are trying to find the closest point to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> The geographic unit of the feature you are trying to find the closet point to.
GetCrossing(BaseShape)
MultipointShape<!– ThinkGeo.MapSuite.Core.MultipointShape –> This method returns the crossing points between the current shape and the passed-in target shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The target shape you wish to get crossing points with.
GetDistanceTo(Feature, GeographyUnit, DistanceUnit)
In this method we compute the closest distance between a shape and a feature. The returned unit will be in the unit of distance specified.
Double<!– System.Double –> The return type is the distance between this shape and the targetFeature in the GeographyUnit of the shape.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The feature you are trying to find the distance to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the unit of the shape which is contained in the targetFeature you are getting the distance to.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This parameter is the unit of the distance you want the return value to be in.
GetDistanceTo(BaseShape, GeographyUnit, DistanceUnit)
In this method we compute the closest distance between the two shapes. The returned unit will be in the unit of distance specified.
Double<!– System.Double –> The return type is the distance between this shape and the targetShape in the GeographyUnit of the shape.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The shape you are trying to find the distance to.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the unit of the shape you are getting the distance to.
GetFeature()
Feature<!– ThinkGeo.MapSuite.Core.Feature –> The feature with the same Id and BaseShape as the current BaseShape, and with empty columnValues in it.
GetFeature(IDictionary<String, String>)
Feature<!– ThinkGeo.MapSuite.Core.Feature –> The feature with the same Id and BaseShape as the current BaseShape and with empty columnValues in it, substituted with the passed-in columnValues.
columnValues IDictionary<String,String><!– System.Collections.Generic.IDictionary{System.String,System.String} –> The columnValues will be passed into returning feature.
GetGeoJson()
GetIntersection(Feature)
MultilineShape<!– ThinkGeo.MapSuite.Core.MultilineShape –>
targetShape AreaBaseShape<!– ThinkGeo.MapSuite.Core.AreaBaseShape –>
GetLength(GeographyUnit, DistanceUnit)
Overloads
This overload returns the length in the unit of your choice, based on the returningUnit parameter specified.
This is a useful method when you want to know the total length of a line-based shape. If the shape is a MultiLineShape, then the length is the sum of all of its lines.
Double<!– System.Double –> This overload returns the length in the unit of your choice, based on the returningUnit parameter specified.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This is the GeographyUnit of the shape you are performing the operation on.
returningUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This is the distance unit you would like to use as the return value. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
GetShortestLineTo(BaseShape, GeographyUnit)
This method returns a LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This effect is similar to what you might see on an international flight when the displayed flight path is curved.
MultilineShape<!– ThinkGeo.MapSuite.Core.MultilineShape –> A LineShape representing the shortest distance between the shape you're calling the method on and the targetShape.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> The geographic unit of the Shape you are trying to find the distance to.
GetShortestLineTo(Feature, GeographyUnit)
This method returns a MultiLineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This is effect is similar to what you might see on an international flight when the displayed flight path is curved.
Overriding:
Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
MultilineShape<!– ThinkGeo.MapSuite.Core.MultilineShape –> A MultiLineShape representing the shortest distance between the shape you're calling the method on and the targetFeature.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> The geographic unit of the feature you are trying to find the distance to.
Type<!– System.Type –>
This method returns a byte array that represents the shape in well-known binary. Well-known binary allows you to describe geometries as a binary array. Well-known binary is useful when you want to save a geometry in an efficient format using as little space as possible. An alternative to well-known binary is well-known text, which is a textual representation of a geometry object. We have methods that work with well known text as well.
Byte[]<!– System.Bytethinkgeo.mapsuite.core.linebaseshape –> This method returns a byte array that represents the shape in well-known binary.
byteOrder WkbByteOrder<!– ThinkGeo.MapSuite.Core.WkbByteOrder –> This parameter is the byte order used to encode the well-known binary.
GetWellKnownBinary()
GetWellKnownBinary(RingOrder, WkbByteOrder)
outerRingOrder RingOrder<!– ThinkGeo.MapSuite.Core.RingOrder –>
GetWellKnownBinary(RingOrder)
GetWellKnownText()
This method returns a string that represents the shape in well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
POLYGON5)
MULTILINESTRING6)
MULTIPOLYGON7),8))
String<!– System.String –> This method returns a string that represents the shape in well-known text.
GetWellKnownText(RingOrder)
This method returns a stringthat represents the shape in well-known text. Well-known text allows you to describe geometries as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometries.
POINT(5 17)
POLYGON9)
MULTILINESTRING10)
MULTIPOLYGON11),12))
Overriding:
GetWellKnownType()
WellKnownType<!– ThinkGeo.MapSuite.Core.WellKnownType –> This method returns the well-known type for the shape.
Intersects(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape have at least one point in common.
Intersects(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature have at least one point in common.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The targetFeature you wish to compare the current one to.
IsDisjointed(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape have no points in common. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
IsDisjointed(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature have no points in common. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The feature you wish to compare the current one to.
IsTopologicallyEqual(Feature)
Topologically equal means that the shapes are essentially the same. For example, let's say you have a line with two points, point A and point B. You also have another line that is made up of point A, point B and point C. Point A of line one shares the same vertex as point A of line two, and point B of line one shares the same vertex as point C of line two. They are both straight lines, so point B of line two would lie on the first line. Essentially the two lines are the same, with line 2 having just one extra point. Topologically they are the same line, so this method would return true.
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature are topologically equal.
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape are topologically equal.
IsWithin(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape lies within the interior of the targetFeature.
IsWithin(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape lies within the interior of the targetShape.
LoadFromWellKnownData(String)
Void<!– System.Void –>
wellKnownText String<!– System.String –> This parameter is the well-known text you will use to hydrate your object.
LoadFromWellKnownData(Byte[])
wellKnownBinary Byte[]<!– System.Bytethinkgeo.mapsuite.core.linebaseshape –> This parameter is the well-known binary used to populate the shape.
Overlaps(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape share some but not all points in common.
Overlaps(Feature)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetFeature share some but not all points in common.
Register(PointShape, PointShape, DistanceUnit, GeographyUnit)
Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.
A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.
Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
fromPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the anchor PointShape in the coordinate of origin.
toPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the anchor PointShape in the coordinate of destination.
fromUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This parameter is the DistanceUnit of the coordinate of origin.
toUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This parameter is the GeographyUnit of the coordinate of destination.
Register(Feature, Feature, DistanceUnit, GeographyUnit)
fromPoint Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the anchor PointFeature in the coordinate of origin.
toPoint Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the anchor PointFeature in the coordinate of destination.
Rotate(BaseShape, PointShape, Single)
<!– static –> This method returns a shape rotated by a number of degrees based on a pivot point.
This method returns a shape rotated by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape you can achieve in-place rotation. By moving the pivot point outside of the center of the shape you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method returns a shape rotated by a number of degrees based on a pivot point.
sourceBaseShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This parameter is the basis for the rotation.
pivotPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> The pivotPoint represents the center of rotation.
degreeAngle Single<!– System.Single –> The number of degrees of rotation required, from 0 to 360.
Rotate(PointShape, Single)
Rotate(Feature, PointShape, Single)
<!– static –> This method returns a feature rotated by a number of degrees based on a pivot point.
This method returns a feature rotated by a number of degrees based on a pivot point. By placing the pivot point in the center of the feature you can achieve in-place rotation. By moving the pivot point outside of the center of the feature you can translate the feature in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the basis for the rotation.
ScaleDown(LineBaseShape, Double)
<!– static –> This method returns a new shape that is decreases by the percentage given in the percentage parameter.
This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster as you apply the operation multiple times. There is also a ScaleUp method that will enlarge the shape as well.
LineBaseShape<!– ThinkGeo.MapSuite.Core.LineBaseShape –> a scaled down line type shape.
sourceLineBaseShape LineBaseShape<!– ThinkGeo.MapSuite.Core.LineBaseShape –> This parameter is the basis for the scale up up but is not modified.
percentage Double<!– System.Double –> This is the percentage by which to decrease the shape�s size.
ScaleDown(Feature, Double)
<!– static –> This method returns a new feature that is decreases by the percentage given in the percentage parameter.
This method is useful when you would like to decrease the size of the feature. Note that a larger percentage will scale the shape down faster as you apply the operation multiple times. There is also a ScaleUp method that will enlarge the shape as well.
Feature<!– ThinkGeo.MapSuite.Core.Feature –> a scaled down line type feature.
sourceLine Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the basis for the scale up up but is not modified.
ScaleDown(Double)
ScaleTo(Double)
Void<!– System.Void –> This method is useful when you would like to increase or decrease the size of the shape.
scale Double<!– System.Double –> Pepresents a value which scaleFactor to
ScaleTo(BaseShape, Double)
<!– static –> This method increases or decreases the size of the shape by the specified scale factor given in the parameter.
It will call the instanced method ScaleTo internally.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method is useful when you would like to increase or decrease the size of the shape.
baseShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> Represents a shape which you want to resize
scale Double<!– System.Double –> Pepresents a value which scaleFactor to.
ScaleUp(LineBaseShape, Double)
<!– static –> This method returns a new shape that is increased by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster as you apply the operation multiple times. There is also a ScaleDown method that will shrink the shape as well.
LineBaseShape<!– ThinkGeo.MapSuite.Core.LineBaseShape –> a scaled line type shape.
sourceShape LineBaseShape<!– ThinkGeo.MapSuite.Core.LineBaseShape –> This parameter is the basis for the scale up up but is not modified.
percentage Double<!– System.Double –> This is the percentage by which to increase the shape�s size.
ScaleUp(Feature, Double)
<!– static –> This method returns a new feature that is increased by the percentage given in the percentage parameter.
This method is useful when you would like to increase the size of the feature. Note that a larger percentage will scale the shape up faster as you apply the operation multiple times. There is also a ScaleDown method that will shrink the shape as well.
Feature<!– ThinkGeo.MapSuite.Core.Feature –> a scaled line type feature.
ScaleUp(Double)
Simplify(LineBaseShape, Double, SimplificationType)
<!– static –> Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
MultilineShape<!– ThinkGeo.MapSuite.Core.MultilineShape –> Simplify the LineBaseShape to MultilineShape depends on distance tolerance and different SimplificationType.
targetShape LineBaseShape<!– ThinkGeo.MapSuite.Core.LineBaseShape –> target shape which will be simplified.
tolerance Double<!– System.Double –> distance tolerance
simplificationType SimplificationType<!– ThinkGeo.MapSuite.Core.SimplificationType –> Specifies which algorthm will be use to simplify.
Simplify(GeographyUnit, Double, DistanceUnit, SimplificationType)
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> the geography unit of the target shape
toleranceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> the distance unit of tolerance
Simplify(Double, SimplificationType)
Simplify(LineBaseShape, GeographyUnit, Double, DistanceUnit, SimplificationType)
targetShapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> the geography unit of the target shape
Touches(Feature)
Boolean<!– System.Boolean –> This method returns of the current shape and the targetFeature have at least one boundary point in common, but no interior points.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> The targetFeature which contains a shape that you wish to compare the current one to.
Touches(BaseShape)
Boolean<!– System.Boolean –> This method returns if the current shape and the targetShape have at least one boundary point in common, but no interior points.
TranslateByDegree(Feature, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
This method returns a feature repositioned from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this feature a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
If you pass a distance of 0, then the operation is ignored.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method returns a feature repositioned from one location to another, based on a distance and a direction in degrees.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the basis of the move.
distance Double<!– System.Double –> The distance is the number of units to move the shape using the angle specified. The distance unit will be the DistanceUnit specified in the distanceUnit parameter. The distance must be greater than or equal to 0.
angleInDegrees Double<!– System.Double –> A number between 0 and 360 degrees that represents the direction you wish to move the feature, with 0 being up.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This is the distance unit you would like to use as the measure for the move. For example, if you select miles as your distance unit, then the distance will be calculated in miles.
TranslateByDegree(BaseShape, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
This method returns a shape repositioned from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this shape a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method returns a shape repositioned from one location to another based on a distance and a direction in degrees.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This parameter is the basis of the move.
distance Double<!– System.Double –> The distance is the number of units to move the shape using the angle specified. The distance unit will be the one specified in the distanceUnit parameter. The distance must be greater than or equal to 0.
angleInDegrees Double<!– System.Double –> A number between 0 and 360 degrees that represents the direction you wish to move the shape, with 0 being up.
TranslateByDegree(Double, Double, GeographyUnit, DistanceUnit)
This method moves a base shape from one location to another based on angleInDegrees and distance parameter. With this overload, it is important to note that the distance is based on the supplied distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with a distanceUnit of miles, you're going to move this shape a number of miles based on the distance value and the angleInDegrees. In this way, you can easily move a shape in decimal degrees five miles to the north.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This is the DistanceUnit you would like to use as the measure of the translate. For example if you select miles as your distanceUnit then the distance will be calculated in miles.
TranslateByDegree(Double, Double)
TranslateByOffset(Feature, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a feature repositioned from one location to another based on an X and Y offset distance.
This method returns a feature repositioned from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
Feature<!– ThinkGeo.MapSuite.Core.Feature –> This method returns a feature repositioned from one location to another based on an X and Y offset distance.
targetFeature Feature<!– ThinkGeo.MapSuite.Core.Feature –> This parameter is the basis of the moved feature.
xOffsetDistance Double<!– System.Double –> This is the number of horizontal units of movement in the distance unit specified in the distanceUnit parameter.
yOffsetDistance Double<!– System.Double –> This is the number of horizontal units of movement in the distance unit specified in the distanceUnit parameter.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> This is the distance unit you would like to use as the measure for the move. For example, if you select miles as your distance unit, then the xOffsetDistance and yOffsetDistance will be calculated in miles.
TranslateByOffset(BaseShape, Double, Double, GeographyUnit, DistanceUnit)
<!– static –> This method returns a shape repositioned from one location to another based on an X and Y offset distance.
This method returns a shape repositioned from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This method returns a shape repositioned from one location to another based on an X and Y offset distance.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> This parameter is the basis of the moved shape.
yOffsetDistance Double<!– System.Double –> This is the number of vertical units of movement in the distance unit specified in the distanceUnit parameter.
TranslateByOffset(Double, Double, GeographyUnit, DistanceUnit)
This method moves a base shape from one location to another based on an X and Y offset distance. With this overload, it is important to note that the X and Y offset units are based on the distanceUnit parameter. For example, if your shape is in decimal degrees and you call this method with an X offset of 1 and a Y offset of 1, you're going to move this shape one unit of the distanceUnit in the horizontal direction and one unit of the distanceUnit in the vertical direction. In this way, you can easily move a shape in decimal degrees five miles on the X axis and 3 miles on the Y axis.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> This is the geographic unit of the base shape you are performing the operation on.
TranslateByOffset(Double, Double)
Union(IEnumerable<Feature>)
<!– static –>
targetFeatures IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –>
Union(LineBaseShape)
MultilineShape<!– ThinkGeo.MapSuite.Core.MultilineShape –> A set combining the points of this LineBaseShape and the points of input LineBaseShape.
targetShape LineBaseShape<!– ThinkGeo.MapSuite.Core.LineBaseShape –> The target LineBasheShape with which to compute the union
Union(IEnumerable<LineBaseShape>)
<!– static –> Calculates a new geometry that contains all the points in this LineBaseShape and input LineBaseShape set.
MultilineShape<!– ThinkGeo.MapSuite.Core.MultilineShape –> A set combining the points of this LineBaseShape and the points of input LineBaseShape set.
lineBaseShapes IEnumerable<LineBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.LineBaseShape} –>
Union(Feature)
Validate(ShapeValidationMode)
ShapeValidationResult<!– ThinkGeo.MapSuite.Core.ShapeValidationResult –> This method returns a ShapeValidationResult based on a series of tests.
validationMode ShapeValidationMode<!– ThinkGeo.MapSuite.Core.ShapeValidationMode –> This parameter determines whether the test is simple or advanced. In some cases, the advanced tests can take some time. The simple test is designed to always be fast.
BufferCore(Double, Int32, BufferCapType, GeographyUnit, DistanceUnit)
Overriding:
quadrantSegments Int32<!– System.Int32 –> The number of quadrantSegments used in the buffer logic.
bufferCapType BufferCapType<!– ThinkGeo.MapSuite.Core.BufferCapType –> The bufferCapType used in the buffer logic.
CloneDeepCore()
When you override this method, you need to ensure that there are no references in common between the original and copy.
ContainsCore(BaseShape)
Overriding:
ConvexHullCore()
This method is useful when you want to create a perimeter around the shape. For example, if you had a MultiPolygon that represented buildings on a campus, you could easily get the convex hull of the buildings and determine the perimeter of all of the buildings together. This also works with MultiPoint shapes, where each point may represent a certain type of person you are doing statistics on. With convex hull, you can get an idea of the regions those points are located in.
CrossesCore(BaseShape)
Overriding:
GetAccurateLengthCore(String, DistanceUnit, DistanceCalculationMode)
GetBoundingBoxCore()
Overriding:
GetCenterPointCore()
Overriding:
GetClosestPointToCore(BaseShape, GeographyUnit)
Overriding:
GetCrossingCore(BaseShape)
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> The target shape you wish to get crossing with.
GetDistanceToCore(BaseShape, GeographyUnit, DistanceUnit)
Double<!– System.Double –> The return type is the distance between this shape and the targetShape in the GeographyUnit of the shape. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> the geographic unit of the targetShape.
distanceUnit DistanceUnit<!– ThinkGeo.MapSuite.Core.DistanceUnit –> The returning distance unit.
GetGeoJsonCore()
GetLengthCore(GeographyUnit, DistanceUnit)
Overloads
Overriding:
GetShortestLineToCore(BaseShape, GeographyUnit)
This method returns a LineShape representing the shortest distance between the shape you're calling the method on and the targetShape. In some instances, based on the GeographicType or Projection, the line may not be straight. This is effect is similar to what you might see on an international flight when the displayed flight path is curved.
Overriding:
shapeUnit GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> The geographic unit of the shape you are trying to find the distance to.
GetWellKnownBinaryCore(RingOrder, WkbByteOrder)
Overriding:
byteOrder WkbByteOrder<!– ThinkGeo.MapSuite.Core.WkbByteOrder –> This parameter specifies if the byte order is big- or little-endian.
GetWellKnownTypeCore()
IntersectsCore(BaseShape)
Overriding:
IsDisjointedCore(BaseShape)
Overriding:
Overriding:
IsWithinCore(BaseShape)
Overriding:
OverlapsCore(BaseShape)
Overriding:
RegisterCore(PointShape, PointShape, DistanceUnit, GeographyUnit)
Overriding:
RotateCore(PointShape, Single)
This method rotates a shape by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape you can achieve in-place rotation. By moving the pivot point outside of the center of the shape you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
Overriding:
ScaleDownCore(Double)
Overriding:
ScaleToCore(Double)
This protected virtual method is called from the concrete public method ScaleTo. It does not take into account any transaction activity, as this is the responsibility of the concrete public method ScaleTo. This way, as a developer, if you choose to override this method you do not have to consider transactions at all.
ScaleUpCore(Double)
Overriding:
SimplifyCore(Double, SimplificationType)
TouchesCore(BaseShape)
Overriding:
TranslateByDegreeCore(Double, Double, GeographyUnit, DistanceUnit)
If you pass a distance of 0 then the operation is ignored.
Overriding:
TranslateByOffsetCore(Double, Double, GeographyUnit, DistanceUnit)
Overriding:
UnionCore(IEnumerable<LineBaseShape>)
lineBaseShapes IEnumerable<LineBaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.LineBaseShape} –> The target LineBasheShape set with which to compute the union
Overriding:
CanRotate
If this property returns false and you attempt to call the rotate method, it will throw a NotImplementedException.
Return Type
Id
Return Type
Tag
Return Type
1) , 5) , 9) 2 2,6 2,6 6,2 6,2 2),(3 3,4 3,4 4,3 4,3 3
2) , 6) , 10) 4 5,11 51,21 26),(-4 -7,-9 -7,-14 -3
3) , 7) , 11) (2 2,6 2,6 6,2 6,2 2),(3 3,4 3,4 4,3 4,3 3
4) , 8) , 12) 4 4,7 3,7 5,4 4
thinkgeo.mapsuite.core.linebaseshape.1440040129.txt.gz · Last modified: 2015/09/17 10:34 (external edit)
