thinkgeo.mapsuite.windowsphonecore.shapefilefeaturelayer
Table of Contents
ThinkGeo.MapSuite.WindowsPhoneCore.ShapeFileFeatureLayer
<!– Class –> This class represents a Layer backed by a Shape File.
Public MethodShapeFileFeatureLayer This is a constructor for the class.
Public MethodShapeFileFeatureLayer String This is a constructor for the class.
Public MethodShapeFileFeatureLayer String, ShapeFileReadWriteMode This is a constructor for the class.
Public MethodShapeFileFeatureLayer String, String This is a constructor for the class.
Public MethodShapeFileFeatureLayer String, String, ShapeFileReadWriteMode This is a constructor for the class.
Public MethodShapeFileFeatureLayer String, String, ShapeFileReadWriteMode, Encoding This is a constructor for the class.
Public MethodStatic MemberBuildIndexFile IEnumerable<Feature>, String, BuildIndexMode This method builds a spatial index for the specified group of features.
Public MethodStatic MemberBuildIndexFile IEnumerable<Feature>, String, Projection This method builds a spatial index for the specified group of features and target projection.
Public MethodStatic MemberBuildIndexFile IEnumerable<Feature>, String This method builds a spatial index for the specified group of features.
Public MethodStatic MemberBuildIndexFile String, String, Projection, String, String, BuildIndexMode This method builds a spatial index only for those features that satisfy a regular expression, based on a passed-in projection.
Public MethodStatic MemberBuildIndexFile String, String, String, String, BuildIndexMode This method builds a spatial index only for those features that satisfy a regular expression.
Public MethodStatic MemberBuildIndexFile IEnumerable<Feature>, String, Projection, BuildIndexMode This method builds a spatial index for the specified group of features.
Public MethodStatic MemberBuildIndexFile String, BuildIndexMode This method builds a spatial index for the layer.
Public MethodStatic MemberBuildIndexFile String, String, Projection, String, String, BuildIndexMode, Encoding This method builds a spatial index only for those features that satisfy a regular expression, based on a passed-in projection.
Public MethodStatic MemberBuildIndexFile String This method builds a spatial index for the layer.
Public MethodStatic MemberBuildIndexFile String, String, BuildIndexMode This method build a spatial index for the shape file which increases accessspeed.
Public MethodStatic MemberBuildRecordIdColumn String, String, BuildRecordIdMode, Int32 Static API used to build RecordId from the specified starting Id number.
Public MethodStatic MemberBuildRecordIdColumn String, String, BuildRecordIdMode, Int32, Encoding Static API used to build RecordId from the specified starting Id number.
Public MethodStatic MemberBuildRecordIdColumn String, String, BuildRecordIdMode Static API used to build RecordId. The Id will start from 0.
Public MethodStatic MemberCloneShapeFileStructure String, String, OverwriteMode, Encoding Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it.
Public MethodStatic MemberCloneShapeFileStructure String, String Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it.
Public MethodStatic MemberCloneShapeFileStructure String, String, OverwriteMode Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodStatic MemberCreateShapeFile ShapeFileType, String, IEnumerable<DbfColumn>, Encoding, OverwriteMode Static API to create a new Shape File.
Public MethodStatic MemberCreateShapeFile ShapeFileType, String, IEnumerable<DbfColumn> Static API to create a new Shape File.
Public MethodStatic MemberCreateShapeFile ShapeFileType, String, IEnumerable<DbfColumn>, Encoding Static API to create a new Shape File.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetDataFromDbf String
Public MethodGetDataFromDbf String, String
Public MethodGetDataFromDbf String, IEnumerable<String>
Public MethodGetDataFromDbf IEnumerable<String>, String
Public MethodGetDataFromDbf IEnumerable<String>, IEnumerable<String>
Public MethodGetShapeFileType Get the Shape File type for the Shape File FeatureSource.
Public MethodGetType Object
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodStatic MemberRebuild String This method rebuilds the SHP, SHX, DBF, IDX and IDS files for the given shape file.
Public MethodStatic MemberSaveToProjection String, String, Projection, OverwriteMode This API provide a easy way to project features in a shape file into another projection and save it to shape file.
Public MethodToString Object
Public MethodUpdateDbfData String, IEnumerable<String>, IEnumerable<String>
Public MethodUpdateDbfData String, String, String
Public MethodValidate This method checks all features in a shapefile is supported by Mapsuite or not.
Protected MethodCloseCore Layer(overriden)
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden)
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden)
Protected MethodOnDrawingFeatures DrawingFeaturesEventArgs FeatureLayer This method raises the DrawingFeatures event.
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawingWrappingFeatures DrawingWrappingFeaturesFeatureLayerEventArgs FeatureLayer
Protected MethodOpenCore Layer(overriden)
Protected MethodSetupTools FeatureLayer This method sets up the EditTools and QueryTools objects.
Protected MethodSetupToolsCore FeatureLayer This method sets up the EditTools and QueryTools objects.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingMarginPercentage Double FeatureLayer This property gets and sets the extra drawing margin as a percentage around the map that draw to ensure that labeling is correct.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyEditTools EditTools FeatureLayer This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer.
Public PropertyEncoding Encoding This property gets and sets the encoding information for the DBF.
Public PropertyFeatureIdsToExclude Collection<String> FeatureLayer A collection of strings representing record id of features not to get in the Layer.
Public PropertyFeatureSource FeatureSource FeatureLayer This property gets the FeatureSource for the FeatureLayer.
Public PropertyHasBoundingBox Boolean Layer(overriden) This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In ShapeFileFeatureLayer, we override this API and mark it as true.
Public PropertyIndexPathFileName String This property returns the path and filename of the index file you want to represent.
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyMaxRecordsToDraw Int32
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyQueryTools QueryTools FeatureLayer This property gets the QueryTools that allow you to easily query Features from the Feature Layer.
Public PropertyReadWriteMode ShapeFileReadWriteMode
Public PropertyRequireIndex Boolean This property gets and sets whether an index is required when reading data. The default value is true.
Public PropertyShapePathFileName String This property returns the path and filename of the Shape File you want to represent.
Public PropertyUsingSpatialIndex Boolean This property gets whether the Shape File FeatureSource has an index or not.
Public PropertyWrappingExtent RectangleShape FeatureLayer
Public PropertyWrappingMode WrappingMode FeatureLayer Thie property gets or sets whether allow wrap date line.
Public PropertyZoomLevelSet ZoomLevelSet FeatureLayer This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer.
Protected PropertyIsOpenCore Boolean Layer(overriden)
Public EventDrawingFeatures DrawingFeaturesEventArgs FeatureLayer This event is raised when features are about to be drawn in the layer.
Public EventDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Public EventDrawingWrappingFeatures DrawingWrappingFeaturesFeatureLayerEventArgs FeatureLayer
Public EventStreamLoading StreamLoadingEventArgs This event allows you to pass in your own stream to represent the files.
ShapeFileFeatureLayer()
Overloads
This is the default constructor. If you use this constructor, then you should set the required methods manually.
Name Type Description
Go Back
ShapeFileFeatureLayer(String)
Overloads
This constructor allows you to provide a path and filename to a shape file.
shapePathFilename String<!– System.String –> This parameter is the Shape File path and filename.
Go Back
ShapeFileFeatureLayer(String, ShapeFileReadWriteMode)
Overloads
This constructor allows you to provide a path and filename to a Shape File and the read/write mode for the files.
readWriteMode ShapeFileReadWriteMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeFileReadWriteMode –> This parameter specifies whether the file will be opened in read-only or read/write mode.
Go Back
ShapeFileFeatureLayer(String, String)
Overloads
This constructor allows you to provide a path and filename to a Shape File and its spatial index file.
indexPathFilename String<!– System.String –> This parameter is the index file path and filename.
Go Back
ShapeFileFeatureLayer(String, String, ShapeFileReadWriteMode)
Overloads
This constructor allows you to provide a path and filename to a Shape File, its index file, and to specify the read/write mode for the files.
Go Back
ShapeFileFeatureLayer(String, String, ShapeFileReadWriteMode, Encoding)
Overloads
This constructor allows you to provide a path and filename to a Shape File, the index file, and to specify the read/write mode and the encoding for the files.
encoding Encoding<!– System.Text.Encoding –> This parameter specifies the encoding of the data.
Go Back
BuildIndexFile(IEnumerable<Feature>, String, BuildIndexMode)
<!– static –> This method builds a spatial index for the specified group of features.
Overloads
This overload allows you to pass in a group of features and specify the index filename to use. You can also pass in a Shape File and specify whether to rebuild an index file if it already exists.
Return Type Description
Void<!– System.Void –>
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter specifies the features for which to build the index.
indexPathFilename String<!– System.String –> This parameter determines the target index path filename.
buildIndexMode BuildIndexMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.BuildIndexMode –> This parameter determines whether an index file will be rebuilt if it already exists.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeFileFeatureLayer –> Go Back
BuildIndexFile(IEnumerable<Feature>, String, Projection)
<!– static –> This method builds a spatial index for the specified group of features and target projection.
Overloads
This overload allows you to pass in a group of features and specify a target projection and the index filename to use.
indexPathFilename String<!– System.String –> This parameter specifies the target index path and filename.
projection Projection<!– ThinkGeo.MapSuite.WindowsPhoneCore.Projection –> This parameter specifies the projection to build index against those features.
BuildIndexFile(IEnumerable<Feature>, String)
Overloads
BuildIndexFile(String, String, Projection, String, String, BuildIndexMode)
<!– static –> This method builds a spatial index only for those features that satisfy a regular expression, based on a passed-in projection.
Overloads
This overload allows you to pass in a Shape File and only build an index for those features that satisfy the regularExpression parameter.
This overload allows you to pass in a Shape File and specify the index filename to use.
shapePathFilename String<!– System.String –> This parameter specifies the Shape File for which to build the index.
projection Projection<!– ThinkGeo.MapSuite.WindowsPhoneCore.Projection –> This parameter determines the projection that will be used to build the index against those features that satisfy the regular expression.
columnName String<!– System.String –> This parameter determines the column name whose values will be tested against the regular expression.
regularExpression String<!– System.String –> This parameter represents the regular expression to test against each feature for inclusion in the index.
BuildIndexFile(String, String, String, String, BuildIndexMode)
<!– static –> This method builds a spatial index only for those features that satisfy a regular expression.
Overloads
BuildIndexFile(IEnumerable<Feature>, String, Projection, BuildIndexMode)
Overloads
This overload allows you to pass in a group of features and specify a target projection and the index filename to use. You can also pass in a Shape File and specify whether to rebuild an index file if it already exists.
projection Projection<!– ThinkGeo.MapSuite.WindowsPhoneCore.Projection –> This parameter determines the Projection to build index against those features.
BuildIndexFile(String, BuildIndexMode)
<!– static –> This method builds a spatial index for the layer.
Overloads
This overload allows you to pass in the Shape File and determines if we rebuild an index file that already exists.
pathFilename String<!– System.String –> This parameter is the matching pattern that defines which Shape Files to include.
rebuildExistingIndexMode BuildIndexMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.BuildIndexMode –> This parameter determines whether an index file will be rebuilt if it already exists.
BuildIndexFile(String, String, Projection, String, String, BuildIndexMode, Encoding)
Overloads
encoding Encoding<!– System.Text.Encoding –> This parameter specifies the encoding information used in the source DBF file.
BuildIndexFile(String)
Overloads
This overload allows you to pass in the Shape filename.
This overload allows you to pass in the Shape File.
pathFilename String<!– System.String –> The path and filename to the Shape File.
BuildIndexFile(String, String, BuildIndexMode)
<!– static –> This method build a spatial index for the shape file which increases accessspeed.
Overloads
This overload builds an index file with the same name as the shape file with only the extension being different. You can also specify if you want to rebuild an existing index file.
shapePathFilename String<!– System.String –> This parameter is the shape file name and path that you want to build an index for.
indexPathFilename String<!– System.String –> This parameter specifies the index file name.
buildIndexMode BuildIndexMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.BuildIndexMode –> This parameter determines what will happen if there is an existing index file.
BuildRecordIdColumn(String, String, BuildRecordIdMode, Int32)
<!– static –> Static API used to build RecordId from the specified starting Id number.
shapeFilename String<!– System.String –> The name of the target ShapeFile on which to base the newly built RecordId.
fieldname String<!– System.String –> The field name for the RecordId.
rebuildNeeded BuildRecordIdMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.BuildRecordIdMode –> The RecordId build mode.
startNumber Int32<!– System.Int32 –> The starting Id number of the RecordId.
BuildRecordIdColumn(String, String, BuildRecordIdMode, Int32, Encoding)
encoding Encoding<!– System.Text.Encoding –> This parameter specifies the encoding information in the DBF.
BuildRecordIdColumn(String, String, BuildRecordIdMode)
<!– static –> Static API used to build RecordId. The Id will start from 0.
CloneShapeFileStructure(String, String, OverwriteMode, Encoding)
<!– static –> Clone the structure from the source ShapeFile to the target ShapeFile. After cloning the structure, the target ShapeFile will have the same type and the same DBF columns as the source ShapeFile, but without any records in it.
An exception will be thown when the target ShapeFile does not exist and the overwrite mode is set to DoNotOverwrite.
sourceShapePathFilename String<!– System.String –> The source Shape File to be cloned.
targetShapePathFilename String<!– System.String –> The target Shape File, which will have the same structure as the source Shape File after cloning operation is complete.
overwriteMode OverwriteMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.OverwriteMode –> This parameter specifies the overwrite mode when the target ShapeFile already exists.
encoding Encoding<!– System.Text.Encoding –> This parameter specifies the encoding information in the source Shape File.
CloneShapeFileStructure(String, String)
CloneShapeFileStructure(String, String, OverwriteMode)
Close()
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer –> Go Back
CreateShapeFile(ShapeFileType, String, IEnumerable<DbfColumn>, Encoding, OverwriteMode)
<!– static –> Static API to create a new Shape File.
An exception will be thown when the target Shape File does not exist while the overwrite mode is set to DoNotOverwrite.
shapeType ShapeFileType<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeFileType –> This parameter specifies the the Shape File type for the target Shape File.
pathFilename String<!– System.String –> This parameter specifies the Shape filename for the target Shape File.
databaseColumns IEnumerable<DbfColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.DbfColumn} –> This parameter specifies the DBF column information for the target Shape File.
encoding Encoding<!– System.Text.Encoding –> This parameter specifies the DBF encoding infromation for the target Shape File.
overwriteMode OverwriteMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.OverwriteMode –> This parameter specifies the override mode when the target Shape File exists.
CreateShapeFile(ShapeFileType, String, IEnumerable<DbfColumn>)
CreateShapeFile(ShapeFileType, String, IEnumerable<DbfColumn>, Encoding)
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns the bounding box of the Layer.
GetDataFromDbf(String)
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –>
id String<!– System.String –>
GetDataFromDbf(String, String)
GetDataFromDbf(String, IEnumerable<String>)
returningColumnNames IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –>
GetDataFromDbf(IEnumerable<String>, String)
Collection<Dictionary<String,String»<!– System.Collections.ObjectModel.Collection{System.Collections.Generic.Dictionary{System.String,System.String}} –>
ids IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –>
GetDataFromDbf(IEnumerable<String>)
GetDataFromDbf(IEnumerable<String>, IEnumerable<String>)
GetShapeFileType()
ShapeFileType<!– ThinkGeo.MapSuite.WindowsPhoneCore.ShapeFileType –> The ShapeFileType for the ShapeFile FeatureSource.
Type<!– System.Type –>
Open()
Rebuild(String)
<!– static –> This method rebuilds the SHP, SHX, DBF, IDX and IDS files for the given shape file.
This method rebuilds the SHP, SHX, DBF, IDX and IDS files for the given shape file. When we do editing we have optimized the updates so that we do not need to rebuild the entire shape file. This leads to the shape file being out of order which may cause it not to open in other tools. One optimization is if you update a record instead of rebuilding a new shape file we mark the old record as null and add the edited record at the end of the shape file. This greatly increases the speed of committing shape file changes but will over time unorder the shape file. In addition we do a delete the DBF file will simply mark the record deleted and not compact the space. Rebuilding the shape file will correctly order the SPX and SHX along with compacting the DBF file and rebuild any index with the same any of the shape file if it exists.
Note that if you have build custom index files where the name of the index differs from that of the shape file you will need to rebuild those manually using the BuildIndex methods.
shapePathFilename String<!– System.String –> This parameter is the shape file you want to rebuild.
SaveToProjection(String, String, Projection, OverwriteMode)
<!– static –> This API provide a easy way to project features in a shape file into another projection and save it to shape file.
sourceShapeFile String<!– System.String –> This parameter specifies the source shape file to be projected.
targetShapeFile String<!– System.String –> This parameter specifies the target shape file to be saved for the projected features.
projection Projection<!– ThinkGeo.MapSuite.WindowsPhoneCore.Projection –> This parameter is the projection to project the source shape file to target shape file. The source Shape file should be in the FromProjection of the Projection prameter, and the targetShapeFile will be in the ToProjection of the Projection.
overwriteMode OverwriteMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.OverwriteMode –> This parameter specifies the override mode when the target shape file exists.
UpdateDbfData(String, IEnumerable<String>, IEnumerable<String>)
values IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –>
UpdateDbfData(String, String, String)
decimalDegreesValue String<!– System.String –>
Validate()
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> A dictionary which contains all the unsupported features. The key is the Indexs which failed to pass the check, the value contains the reason for its failure.
CloseCore()
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer(overriden) –> Go Back
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
e DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingFeaturesEventArgs –> This parameter represents the event arguments for the event.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureLayer –> Go Back
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingProgressChangedEventArgs –>
e DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingWrappingFeaturesFeatureLayerEventArgs –>
OpenCore()
SetupTools()
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
SetupToolsCore()
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingExceptionMode –>
This extra margin that we draw exists so that labels match up if they are partially cut off.
Return Type
Double<!– System.Double –>
DrawingTime
Return Type
TimeSpan<!– System.TimeSpan –>
EditTools
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
Return Type
EditTools<!– ThinkGeo.MapSuite.WindowsPhoneCore.EditTools –>
Encoding
Return Type
FeatureIdsToExclude
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
FeatureSource
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
Return Type
FeatureSource<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSource –>
HasBoundingBox
Return Type
IndexPathFileName
Return Type
IsOpen
Return Type
IsVisible
Return Type
MaxRecordsToDraw
Return Type
Return Type
QueryTools
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
Return Type
QueryTools<!– ThinkGeo.MapSuite.WindowsPhoneCore.QueryTools –>
ReadWriteMode
Return Type
RequireIndex
Return Type
ShapePathFileName
Return Type
UsingSpatialIndex
Return Type
WrappingExtent
Return Type
WrappingMode
Return Type
WrappingMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.WrappingMode –>
ZoomLevelSet
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.WindowsPhoneCore.ZoomLevelSet –>
IsOpenCore
Return Type
DrawingFeatures
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
StreamLoading
If you choose you can pass in your own stream to represent the file. The stream can come from a variety of places such as isolated storage, a compressed file, and encrypted stream. When the Image is finished with the stream it will dispose of it so be sure to keep this in mind when passing the stream in. If you do not pass in a alternate stream the class will attempt to load the file from the file system using the PathFileName property.
Event Arguments
Event Arguments
StreamLoadingEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.StreamLoadingEventArgs –>
NOTOC WindowsPhoneMapSuiteCore ThinkGeo.MapSuite.WindowsPhoneCore UpdateDocumentation
thinkgeo.mapsuite.windowsphonecore.shapefilefeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
