thinkgeo.mapsuite.windowsphonecore.featurelayer
ThinkGeo.MapSuite.WindowsPhoneCore.FeatureLayer
<!– Class –> This class represents a layer that is comprised of feature data.
This abstract class is the basis for all feature-based layers in the system. Its methods and properties deal with feature data manipulation. Some of the classes that currently inherit from this are ShapeFileFeatureLayer, OracleFeatureLayer and so on.
When creating your own FeatureLayer, you need only to set a FeatureSource and create a useful constructor; the class will take care of the rest. There are no required abstract members. It may be helpful for you to add additional properties specific to your FeatureSource.
Protected MethodFeatureLayer This is a constructor for this class.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetType Object
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodToString Object
Protected MethodCloseCore Layer(overriden) This method closes the FeatureSource and releases any resources it was using.
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden) This method will draw the FeatureLayer source based on the parameters provided.
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden) This method returns the bounding box of the FeatureLayer.
Protected MethodOnDrawingFeatures DrawingFeaturesEventArgs This method raises the DrawingFeatures event.
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawingWrappingFeatures DrawingWrappingFeaturesFeatureLayerEventArgs
Protected MethodOpenCore Layer(overriden) This method opens the FeatureLayer so that it is initialized and ready to use.
Protected MethodSetupTools This method sets up the EditTools and QueryTools objects.
Protected MethodSetupToolsCore This method sets up the EditTools and QueryTools objects.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingMarginPercentage Double This property gets and sets the extra drawing margin as a percentage around the map that draw to ensure that labeling is correct.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyEditTools EditTools This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer.
Public PropertyFeatureIdsToExclude Collection<String> A collection of strings representing record id of features not to get in the Layer.
Public PropertyFeatureSource FeatureSource This property gets the FeatureSource for the FeatureLayer.
Public PropertyHasBoundingBox Boolean Layer This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyQueryTools QueryTools This property gets the QueryTools that allow you to easily query Features from the Feature Layer.
Public PropertyWrappingExtent RectangleShape
Public PropertyWrappingMode WrappingMode Thie property gets or sets whether allow wrap date line.
Public PropertyZoomLevelSet ZoomLevelSet This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer.
Protected PropertyIsOpenCore Boolean Layer(overriden) This property returns true if the FeatureLayer is open and false if it is not.
Public EventDrawingFeatures DrawingFeaturesEventArgs This event is raised when features are about to be drawn in the layer.
Public EventDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Public EventDrawingWrappingFeatures DrawingWrappingFeaturesFeatureLayerEventArgs
FeatureLayer()
Name Type Description
Go Back
Close()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer –> Go Back
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns the bounding box of the Layer.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Open()
String<!– System.String –>
CloseCore()
This protected virtual method is called from the concrete public method Close. The close method plays an important role in the life cycle of the FeatureLayer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called.
If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed FeatureLayer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer(overriden) –> Go Back
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
The DrawCore will be called when the layer is being drawn. It will check if the InternalFeatures are within the extent and whether it is within a defined zoom level. If these parameters are met, then it will apply the styles of the proper zoom level to the InternalFeatures for drawing. Lastly, it will draw InternalFeatures on the GeoImage or native image passed in to the method.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the GeoCanvas used to Draw the layer.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> This parameter is not used for ImageLayers.
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
This method is called from the concrete public method GetBoundingBox. It returns the bounding box of the FeatureLayer.
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns the bounding box of the FeatureLayer.
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
e DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingFeaturesEventArgs –> This parameter represents the event arguments for the event.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureLayer –> Go Back
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingProgressChangedEventArgs –>
e DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingWrappingFeaturesFeatureLayerEventArgs –>
OpenCore()
This abstract method is called from the concrete public method Open. The Open method plays an important role, as it is responsible for initializing the FeatureLayer. Most methods on the FeatureLayer will throw an exception if the state of the FeatureLayer is not opened. When the map draws each FeatureLayer, it will open the layer as one of its first steps, then after it is finished drawing with that FeatureLayer it will close it. In this way we are sure to release all resources used by the FeatureLayer.
SetupTools()
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
SetupToolsCore()
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingExceptionMode –>
This extra margin that we draw exists so that labels match up if they are partially cut off.
Return Type
Double<!– System.Double –>
DrawingTime
Return Type
TimeSpan<!– System.TimeSpan –>
EditTools
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
Return Type
EditTools<!– ThinkGeo.MapSuite.WindowsPhoneCore.EditTools –>
FeatureIdsToExclude
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
FeatureSource
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
Return Type
FeatureSource<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSource –>
HasBoundingBox
The default value is false.
Return Type
IsOpen
Return Type
IsVisible
Return Type
Return Type
QueryTools
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
Return Type
QueryTools<!– ThinkGeo.MapSuite.WindowsPhoneCore.QueryTools –>
WrappingExtent
Return Type
WrappingMode
Return Type
WrappingMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.WrappingMode –>
ZoomLevelSet
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.WindowsPhoneCore.ZoomLevelSet –>
IsOpenCore
Various methods on the FeatureLayer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the FeatureLayer Open method. The method will raise an exception if the current FeatureLayer is already open.
Return Type
DrawingFeatures
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
NOTOC WindowsPhoneMapSuiteCore ThinkGeo.MapSuite.WindowsPhoneCore UpdateDocumentation
thinkgeo.mapsuite.windowsphonecore.featurelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
