thinkgeo.mapsuite.windowsphonecore.inmemoryfeaturelayer
ThinkGeo.MapSuite.WindowsPhoneCore.InMemoryFeatureLayer
<!– Class –> This layer is backed by memory and is typically used for temporary features.
This layer is backed by memory and is typically used for temporary features. You can use the MapShapes layer for user-drawn InternalFeatures, InternalFeatures that come from an external device such as a GPS unit, or any InternalFeatures that are not saved to disk or a database.
Public MethodInMemoryFeatureLayer This is a constructor for the class.
Public MethodInMemoryFeatureLayer IEnumerable<FeatureSourceColumn>, IEnumerable<Feature> This is a constructor for the class.
Public MethodInMemoryFeatureLayer IEnumerable<FeatureSourceColumn>, IEnumerable<BaseShape> This is a constructor for the class.
Public MethodBuildIndex This method build a spatial index for a passed group of featurs which increases access speed.
Public MethodClose Layer This method closes the Layer and releases any resources it was using.
Public MethodDraw GeoCanvas, Collection<SimpleCandidate> Layer This method draws the Layer.
Public MethodGetBoundingBox Layer This method returns the bounding box of the Layer.
Public MethodGetColumns This method returns the columns of data for the InternalFeatures in this Layer.
Public MethodGetType Object
Public MethodOpen Layer This method opens the Layer so that it is initialized and ready to use.
Public MethodToString Object
Protected MethodCloseCore Layer(overriden)
Protected MethodDrawCore GeoCanvas, Collection<SimpleCandidate> Layer(overriden)
Protected MethodDrawException GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodDrawExceptionCore GeoCanvas, Exception Layer This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException.
Protected MethodGetBoundingBoxCore Layer(overriden)
Protected MethodOnDrawingFeatures DrawingFeaturesEventArgs FeatureLayer This method raises the DrawingFeatures event.
Protected MethodOnDrawingProgressChanged DrawingProgressChangedEventArgs Layer
Protected MethodOnDrawingWrappingFeatures DrawingWrappingFeaturesFeatureLayerEventArgs FeatureLayer
Protected MethodOpenCore Layer(overriden) This method opens the Layer so that it is initialized and ready to use.
Protected MethodSetupTools FeatureLayer This method sets up the EditTools and QueryTools objects.
Protected MethodSetupToolsCore FeatureLayer This method sets up the EditTools and QueryTools objects.
Public PropertyColumns Collection<FeatureSourceColumn> This property gets the columns of data for the InternalFeatures in this Layer.
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer Gets or sets the DrawExcpetionMode when exception happens.
Public PropertyDrawingMarginPercentage Double FeatureLayer This property gets and sets the extra drawing margin as a percentage around the map that draw to ensure that labeling is correct.
Public PropertyDrawingTime TimeSpan Layer This property gets the last drawing time for the layer.
Public PropertyEditTools EditTools FeatureLayer This property gets the EditTools that allow you to easily edit InternalFeatures in the Feature Layer.
Public PropertyFeatureIdsToExclude Collection<String> FeatureLayer A collection of strings representing record id of features not to get in the Layer.
Public PropertyFeatureSource FeatureSource FeatureLayer This property gets the FeatureSource for the FeatureLayer.
Public PropertyHasBoundingBox Boolean Layer(overriden) This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In InMemoryFeatureLayer, we override this API and mark it as true.
Public PropertyInternalFeatures GeoCollection<Feature> This property gets the dictionary that holds your InternalFeatures.
Public PropertyIsOpen Boolean Layer This property returns true if the Layer is open and false if it is not.
Public PropertyIsVisible Boolean Layer This property gets and set the visible state of the layer.
Public PropertyName String Layer This property gets and sets the name for the layer.
Public PropertyQueryTools QueryTools FeatureLayer This property gets the QueryTools that allow you to easily query Features from the Feature Layer.
Public PropertyWrappingExtent RectangleShape FeatureLayer
Public PropertyWrappingMode WrappingMode FeatureLayer Thie property gets or sets whether allow wrap date line.
Public PropertyZoomLevelSet ZoomLevelSet FeatureLayer This property gets and sets the ZoomLevelSet, which contains the specific zoom levels for the FeatureLayer.
Protected PropertyIsOpenCore Boolean Layer(overriden)
InMemoryFeatureLayer()
Overloads
This is the default constructor. If you use this constructor, then you need to specify the FeatureSource column manually.
Name Type Description
Go Back
InMemoryFeatureLayer(IEnumerable<FeatureSourceColumn>, IEnumerable<Feature>)
Overloads
This constructor allows you to provide the FeatureSource columns and features for the layer.
featureSourceColumns IEnumerable<FeatureSourceColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSourceColumn} –> This parameter is the FeatureSourceColumn in this class that you want to use.
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter represents the features in this class that you want to use.
Go Back
InMemoryFeatureLayer(IEnumerable<FeatureSourceColumn>, IEnumerable<BaseShape>)
Overloads
This constructor allows you to provide the FeatureSource columns and shapes for the layer.
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> This parameter represents the shapes in this class that you want to use.
Go Back
BuildIndex()
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.InMemoryFeatureLayer –> Go Back
Close()
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer –> Go Back
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> This method returns the bounding box of the Layer.
GetColumns()
You should set the column names for the data that the InternalFeatures will hold. For example, if you have some features that represent road signs, then one column you may want to add is “Sign Type”. Then, for every Feature you add to the layer, you need to add the “Sign Type” and a value to the InternalFeatures' ColumnValues dictionary. If you provide this information, then you can use things like ValueStyles, Labeling, etc. based on the columns you have defined.
Collection<FeatureSourceColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSourceColumn} –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
Open()
String<!– System.String –>
CloseCore()
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Layer(overriden) –> Go Back
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
DrawException(GeoCanvas, Exception)
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> The target canvas to draw the layer.
e Exception<!– System.Exception –> The exception thrown when layer.Draw().
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
<list type=“bullet”> <item>You can call this method from a derived class to enable it to raise the event. This may be useful if you plan to extend the FeatureLayer and you need access to the event.
This event is meant to allow you to add or remove the features to be drawn.</item> </list>
e DrawingFeaturesEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingFeaturesEventArgs –> This parameter represents the event arguments for the event.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureLayer –> Go Back
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingProgressChangedEventArgs –>
e DrawingWrappingFeaturesFeatureLayerEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingWrappingFeaturesFeatureLayerEventArgs –>
OpenCore()
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
SetupTools()
This method is the concrete wrapper for the abstract method SetupToolsCore. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
SetupToolsCore()
This method is the concrete wrapper for the abstract method SetupTools. The SetupTools method allows you to create the QueryTool, EditTools and other tools you may need on your object. We created this method so that if you want to extend one of the tool classes, you can override the SetupToolsCore and create any class you want.
Columns
Return Type
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingExceptionMode –>
This extra margin that we draw exists so that labels match up if they are partially cut off.
Return Type
Double<!– System.Double –>
DrawingTime
Return Type
TimeSpan<!– System.TimeSpan –>
EditTools
The EditTools are supplied as an easily accessible wrapper for the editing methods of the FeatureSource.
Return Type
EditTools<!– ThinkGeo.MapSuite.WindowsPhoneCore.EditTools –>
FeatureIdsToExclude
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
FeatureSource
The FeatureSource is the provider of data to the FeatureLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the FeatureLayer, in the constructor you set the FeatureSource you want to use.
Return Type
FeatureSource<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSource –>
HasBoundingBox
Return Type
InternalFeatures
The dictionary is a quick way to access your InternalFeatures. You can easily add, remove or edit features in this dictionary and they instantly take effect in the layer. You can always use the EditTools to do the same thing, but this is a shortcut, as the data is backed in memory so it is very pliable.
Return Type
GeoCollection<Feature><!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCollection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –>
IsOpen
Return Type
IsVisible
Return Type
Return Type
QueryTools
This property gets the QueryTools that allow you to easily query Features from the Feature Layer. The QueryTools are supplied as an easily accessible wrapper for the query methods of the FeatureSource.
Return Type
QueryTools<!– ThinkGeo.MapSuite.WindowsPhoneCore.QueryTools –>
WrappingExtent
Return Type
WrappingMode
Return Type
WrappingMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.WrappingMode –>
ZoomLevelSet
The ZoomLevelSet is a class that contains all of the ZoomLevels for the FeatureLayer. Each ZoomLevel contains the styles that are used to determine how to draw the InternalFeatures.
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.WindowsPhoneCore.ZoomLevelSet –>
IsOpenCore
Return Type
DrawingFeatures
This event is raised when features are about to be drawn in the layer.
This event is raised when features are about to be drawn in the layer. In the event arguments, there is a collection of features to be drawn. You can easily add or remove items from this collection so that extra items will draw or not draw.
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
NOTOC WindowsPhoneMapSuiteCore ThinkGeo.MapSuite.WindowsPhoneCore UpdateDocumentation
thinkgeo.mapsuite.windowsphonecore.inmemoryfeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
