thinkgeo.mapsuite.windowsphonecore.featuresourcecolumn
ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSourceColumn
<!– Class –> This class represents a column contained within a FeatureSource.
A FeatureSource is typically represented by a number of InternalFeatures and their column data. This column represents the characteristics of that data.
Public MethodFeatureSourceColumn This is the constructor to create a FeatureSourceColumn.
Public MethodFeatureSourceColumn String This is the constructor to create a FeatureSourceColumn.
Public MethodFeatureSourceColumn String, String, Int32 This is the constructor to create a FeatureSourceColumn.
Public MethodGetType Object
Public MethodToString Object(overriden) Returns column name of FeatureSourceColumn
Public PropertyColumnName String This property returns the name of the column.
Public PropertyMaxLength Int32 This property returns the maximum length of the column.
Public PropertyTypeName String This property returns the type name of the column.
FeatureSourceColumn()
Overloads
This overload creates a FeatureSourceColumn that is empty.
This constructor is the default, but should not be used.
Name Type Description
Go Back
FeatureSourceColumn(String)
Overloads
This overload creates a FeatureSourceColumn by specifying the column's name only.
This is the constructor that should be used.
columnName String<!– System.String –> This parameter represents the name of the column.
Go Back
FeatureSourceColumn(String, String, Int32)
Overloads
This overload creates a FeatureSourceColumn by specifying the column's name, type and max length.
typeName String<!– System.String –> This parameter represents the type name of the column.
maxLength Int32<!– System.Int32 –> This parameter represents the maximum length of the column.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Type<!– System.Type –>
String<!– System.String –> Returns column name of FeatureSourceColumn
Void<!– System.Void –>
ColumnName
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSourceColumn –> Go Back
MaxLength
The maximum length is user defined and not in any way enforced in our default FeatureSource implementation. It is mainly for display purposes or when dealing with a known Feature Source type.
Return Type
TypeName
This property is freeform and the type name is not tied to anything. It is wise to try and use familiar type names such as string, integer, date, etc., although it may not fit every different type of FeatureSource. We suggest thar you avoid using this property unless you know the types beforehand or simply want them for display purposes.
Return Type
thinkgeo.mapsuite.windowsphonecore.featuresourcecolumn.txt · Last modified: 2017/03/16 21:59 (external edit)
