<!– Class –> This class represents the column information specific to a DBF column.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSourceColumn *ThinkGeo.MapSuite.WindowsPhoneCore.DbfColumn
DbfColumn | String, DbfColumnType, Int32, Int32 | This method is the constructor for the DbfColumn. |
DbfColumn | This method is the constructor for the DbfColumn. |
ToString | Object(overriden) |
ColumnName | String | This property returns the name of the column in the DBF. | |
ColumnType | DbfColumnType | This property returns the type of the column in the DBF. | |
DecimalLength | Int32 | This property returns the decimal length of the column in the DBF. | |
Length | Int32 | This property returns the length of the column in the DBF. | |
MaxLength | Int32 | FeatureSourceColumn | This property returns the maximum length of the column. |
TypeName | String | FeatureSourceColumn | This property returns the type name of the column. |
This constructor is intended to be used to create the object.
| columnName | String<!– System.String –> | This parameter represents the name of the column in the DBF. |
| columnType | DbfColumnType<!– ThinkGeo.MapSuite.WindowsPhoneCore.DbfColumnType –> | This parameter represents the type of the column in the DBF. |
| length | Int32<!– System.Int32 –> | This parameter represents the length of the column in the DBF. |
| decimalLength | Int32<!– System.Int32 –> | This parameter represents the number of decimal places the column has, if it is a numeric type. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.DbfColumn –> Go Back
This is the number of decimal places the number represents. This is only applicable if the column type is numeric.
The maximum length is user defined and not in any way enforced in our default FeatureSource implementation. It is mainly for display purposes or when dealing with a known Feature Source type.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureSourceColumn –> Go Back
This property is freeform and the type name is not tied to anything. It is wise to try and use familiar type names such as string, integer, date, etc., although it may not fit every different type of FeatureSource. We suggest thar you avoid using this property unless you know the types beforehand or simply want them for display purposes.
