thinkgeo.mapsuite.windowsphonecore.drawingwrappingfeaturesfeaturelayereventargs
ThinkGeo.MapSuite.WindowsPhoneCore.DrawingWrappingFeaturesFeatureLayerEventArgs
<!– Class –> This is the event arguments class for the DrawingFeatures event of the FeatureLayer.
This is the event arguments class for the DrawingFeatures event of the FeatureLayer. You can use the FeaturesToDraw property to add and remove features to draw before the FeatureLayer actually draws them.
Public MethodDrawingWrappingFeaturesFeatureLayerEventArgs This is a constructor for the class.
Public MethodDrawingWrappingFeaturesFeatureLayerEventArgs Collection<Feature> This is a constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyFeaturesToDraw Collection<Feature> This property gets the collection of InternalFeatures that will draw.
DrawingWrappingFeaturesFeatureLayerEventArgs()
Overloads
Name Type Description
Go Back
DrawingWrappingFeaturesFeatureLayerEventArgs(Collection<Feature>)
featuresToDraw Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter represents the faatures that will be drawn.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
FeaturesToDraw
This property gets the collection of InternalFeatures that will draw. You can add, remove or edit items in this collection and they will be considered for drawing in the FeatureLayer.
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingWrappingFeaturesFeatureLayerEventArgs –> Go Back
thinkgeo.mapsuite.windowsphonecore.drawingwrappingfeaturesfeaturelayereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
