thinkgeo.mapsuite.webedition.overlay
ThinkGeo.MapSuite.WebEdition.Overlay
Overlay()
Initialize an instance of the Overlay class.
Overlay(String)
  • id
Overlay(String,Boolean)
  • id
  • isBaseOverlay
ToJson()
Returns a JSON string which contains the information for creating an overlay at the client side.
  • Description:A JSON string which is used to create an overlay at the client side.
3xM=(Page)
  • page
    • Type:Page
Registers a Javascript library URL string to the client HTML page.
The RegisterJavaScriptLibraryCore method allows derived classes to override and register their own Javascript library URL to the HTML page.
  • page
    • Type:Page
    • Description:The page object that is used for registering the javascript library.
RaiseTickEvent(EventArgs)
  • e
    • Type:EventArgs
OnTick(EventArgs)
Raises the Tick event of the MarkerOverlay.
  • e
    • Type:EventArgs
    • Description:An System.EventArgs object that contains the event data.
IsVisible
Gets or sets a value that indicates whether the overlay is visible on the map.
Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Opacity
Gets or sets the opacity level of the overlay.
The Opacity property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
  • Type:Single
IsVisibleInOverlaySwitcher
Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
IsBaseOverlay
Gets or sets a value that indicates whether the overlay is a base overlay.
Id
Gets the identifier for the overlay to be found.
AutoRefreshInterval
Gets or sets the time interval in which the MarkerOverlay refreshes itself.
  • Type:TimeSpan
Attribution
OverlayType
Gets a string that indicates which type the overlay is.
HasTickEvent
Indicates whether the overlay supports tick event.
3hM=
Tick Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
Event Arguments:EventArgs
thinkgeo.mapsuite.webedition.overlay.1442545744.txt.gz · Last modified: 2015/09/18 03:09 by admin
