<!– Class –> Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class defines how a feature will be marked based on its scale. Inside of the ZoomLevelSet there are a number of marker zoomlevels. We will determine which MarkerZoomLevel to use based on which one has the Scale property closest to the current scale. The matching one will define the styles that will be used to mark the features on the map.
*System.Object **ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel
MarkerZoomLevel | Initialize a new instance of the MarkerZoomLevel class. |
GetMarkers | IEnumerable<Feature> | Returns a collection of markers to which the styles will be applied when the current zoomlevel falls into the ranges defined. | |
GetRequiredColumnNames | |||
GetContextMenusCore | Gets a collection of context menus that are associated with the MarkerZoomLevel. | ||
ApplyUntilZoomLevel | ApplyUntilZoomLevel | Gets or sets the zoomlevel to which the styles will be applied. | |
CustomMarkerStyle | MarkerStyle | Gets or sets a style that can be any type of MarkerStyle. | |
DefaultMarkerStyle | PointMarkerStyle | Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined. |
This is the default constructor. If you use this constructor, you should set the require properties on the class manually.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetHashCode.28.29</a>
| Collection<Marker><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WebEdition.Marker} –> |
| features | IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | A collection of markers to which the styles will be applied when the current zoomlevel falls into the ranges defined. |
<!– ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetRequiredColumnNames.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetRequiredColumnNames.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetContextMenusCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#GetContextMenusCore.28.29</a>
| GeoKeyedCollection<ContextMenu><!– ThinkGeo.MapSuite.WebEdition.GeoKeyedCollection{ThinkGeo.MapSuite.WebEdition.ContextMenu} –> | A collection of context menus that are associated with the MarkerZoomLevel. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#ApplyUntilZoomLevel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#ApplyUntilZoomLevel</a>
| ApplyUntilZoomLevel<!– ThinkGeo.MapSuite.Core.ApplyUntilZoomLevel –> |
The CustomMarkerStyle has a higher priority than the DefaultMarkerStyle. When you define both styles, the CustomMarkerStyle will be applied. The CustomMarkerStyle can be any kind of MarkerStyle while the DefaultMarkerStyle cannot.
| MarkerStyle<!– ThinkGeo.MapSuite.WebEdition.MarkerStyle –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#DefaultMarkerStyle” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MarkerZoomLevel#DefaultMarkerStyle</a>
| PointMarkerStyle<!– ThinkGeo.MapSuite.WebEdition.PointMarkerStyle –> |
