thinkgeo.mapsuite.mvcedition.geokeyedcollection_1
ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection<T>
Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
    • System.Collections.ObjectModel.Collection<T>
      • System.Collections.ObjectModel.KeyedCollection<String,T>
        • ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection<T>
GeoKeyedCollection`1()
  • Initializes a new instance of the GeoKeyedCollection class.
ToJson()
  • Returns a JSON string that contains information about all of the items in the collection.
  • Description:A string that contains information about all of the items in the collection.
FromJson(String)
  • Load this object from a json string.
  • jsonString
    • Description:a json string
Contains(String)
  • key
Remove(String)
  • key
Add(T)
  • item
    • Type:T
Clear()
CopyTo(T[],Int32)
  • array
    • Type:T[]
  • index
Contains(T)
  • item
    • Type:T
GetEnumerator()
  • Type:IEnumerator<T>
IndexOf(T)
  • item
    • Type:T
Insert(Int32,T)
  • index
  • item
    • Type:T
Remove(T)
  • item
    • Type:T
RemoveAt(Int32)
  • index
GetKeyForItem(T)
  • item
    • Type:T
ChangeItemKey(T,String)
  • item
    • Type:T
  • newKey
ClearItems()
InsertItem(Int32,T)
  • index
  • item
    • Type:T
RemoveItem(Int32)
  • index
SetItem(Int32,T)
  • index
  • item
    • Type:T
Comparer
  • Type:IEqualityComparer<String>
Item
  • Type:T
Count
Item
  • Type:T
Dictionary
  • Type:IDictionary<String,T>
Items
  • Type:IList<T>
thinkgeo.mapsuite.mvcedition.geokeyedcollection_1.txt · Last modified: 2017/03/16 21:59 (external edit)
