<!– Class –> Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class.
*System.Object **ThinkGeo.MapSuite.WebEdition.MapTools
MapTools | Initialize an instance of the MapTools class. |
ToJson | Returns a JSON string that contains all of the map tools settings. | ||
AnimationPanMapTool | AnimationPanMapTool | Gets an AnimationPanMapTool object for setting. | |
KeyboardMapTool | KeyboardMapTool | Gets a KeyboardMapTool object for setting. | |
LoadingImage | LoadingImageMapTool | Gets a LoadingImageMapTool object for setting | |
Logo | LogoMapTool | Gets a LogoMapTool object for setting | |
MeasureMapTool | MeasureMapTool | Gets an MeasureMapTool object for setting. | |
MiniMap | MiniMapMapTool | Gets a MiniMapMapTool object for setting. | |
MouseCoordinate | MouseCoordinateMapTool | Gets a MouseCoordinateMapTool object for setting. | |
MouseMapTool | MouseMapTool | Gets a MouseMapTool object for setting. | |
OverlaySwitcher | OverlaySwitcherMapTool | Gets an OverlaySwitcherMapTool object for setting. | |
PanZoom | PanZoomMapTool | Gets a PanZoomMapTool object for setting. | |
PanZoomBar | PanZoomBarMapTool | Gets a PanZoomBarMapTool object for setting. | |
ScaleLine | ScaleLineMapTool | Gets a ScaleLineMapTool object for setting. | |
TouchMapTool | TouchMapTool |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MapTools.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MapTools.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetType.28.29</a>
This method is used to generate the JSON string for all of the map controls. The JSON string will be sent to the client side to create corresponding client-side map controls.
| String<!– System.String –> | A JSON string that represents the settings for all of the map tools. |
<!– ThinkGeo.MapSuite.WebEdition.MapTools –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#AnimationPanMapTool” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#AnimationPanMapTool</a>
| AnimationPanMapTool<!– ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#KeyboardMapTool” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#KeyboardMapTool</a>
| KeyboardMapTool<!– ThinkGeo.MapSuite.WebEdition.KeyboardMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#LoadingImage” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#LoadingImage</a>
| LoadingImageMapTool<!– ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Logo” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Logo</a>
| LogoMapTool<!– ThinkGeo.MapSuite.WebEdition.LogoMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MeasureMapTool” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MeasureMapTool</a>
| MeasureMapTool<!– ThinkGeo.MapSuite.WebEdition.MeasureMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MiniMap” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MiniMap</a>
| MiniMapMapTool<!– ThinkGeo.MapSuite.WebEdition.MiniMapMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseCoordinate” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseCoordinate</a>
| MouseCoordinateMapTool<!– ThinkGeo.MapSuite.WebEdition.MouseCoordinateMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseMapTool” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseMapTool</a>
| MouseMapTool<!– ThinkGeo.MapSuite.WebEdition.MouseMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#OverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#OverlaySwitcher</a>
| OverlaySwitcherMapTool<!– ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoom” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoom</a>
| PanZoomMapTool<!– ThinkGeo.MapSuite.WebEdition.PanZoomMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoomBar” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoomBar</a>
| PanZoomBarMapTool<!– ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ScaleLine” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ScaleLine</a>
| ScaleLineMapTool<!– ThinkGeo.MapSuite.WebEdition.ScaleLineMapTool –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#TouchMapTool” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#TouchMapTool</a>
| TouchMapTool<!– ThinkGeo.MapSuite.WebEdition.TouchMapTool –> |
