<!– Class –> Represents a FeatureOverlay whose features can be added or edited at the client side.
You can change the EditFeatureOverlay to different modes by setting the <strong>TrackMode</strong> property. In these modes, you can draw or edit features at the client side. After postback, these client features are converted and entered into its <strong>Features</strong> collection automatically. The <strong>EditSettings</strong> property controls how you can edit the features – whether or not you can drag, resize, reshape, or rotate them.You cannot create a concrete EditFeatureOverlay by yourself. You can only use Map.EditOverlay to access it.
*System.Object ThinkGeo.MapSuite.WebEdition.Overlay *ThinkGeo.MapSuite.WebEdition.FeatureOverlay ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay
MemberwiseClone | Object | ||
OnTick | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
RegisterJavaScriptLibraryCore | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
Attribution | String | Overlay | |
AutoRefreshInterval | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
Columns | Collection<FeatureSourceColumn> | FeatureOverlay | Gets a collection of FeatureSourceColumns, which specifies the column names of the feature data. |
EditSettings | EditSettings | Gets an EditSettings object that controls how you can edit the shapes. | |
EditTools | EditTools | FeatureOverlay | Gets the EditTools that allow you to easily edit features in the FeatureOverlay. |
FeatureSource | InMemoryFeatureSource | FeatureOverlay | Gets the FeatureSource of the FeatureOverlay. |
Features | GeoCollection<Feature> | FeatureOverlay | Gets a collection of features that will be serialized to the client for drawing and editing. |
Id | String | Overlay | Gets the identifier for the overlay to be found. |
IsBaseOverlay | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
IsVisible | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
IsVisibleInOverlaySwitcher | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
Name | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
Opacity | Single | Overlay | Gets or sets the opacity level of the overlay. |
QueryTools | QueryTools | FeatureOverlay | Gets the QueryTools that allow you to easily query features from the FeatureOverlay. |
Style | FeatureOverlayStyle | FeatureOverlay | Gets or sets a FeatureOverlayStyle object, which determines how the features are drawn at the client side. |
TrackMode | TrackMode | Gets a mode of EditFeatureOverlay. |
HasTickEvent | Boolean | Overlay | Indicates whether the overlay supports tick event. |
OverlayType | String | Overlay(overriden) |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#GetType.28.29</a>
Returns a JSON string which contains the information for creating an overlay at the client side.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#ToJson.28.29</a>
| String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#OnTick.28EventArgs.29</a>
| e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
| page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Attribution</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#AutoRefreshInterval</a>
| TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Columns” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Columns</a>
| Collection<FeatureSourceColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.FeatureSourceColumn} –> |
<!– ThinkGeo.MapSuite.WebEdition.FeatureOverlay –> Go Back
The <strong>EditSettings</strong> object contains four options: <strong>IsDraggable</strong>, <strong>IsReshapable</strong>, <strong>IsRotatable</strong>, <strong>IsResizable</strong>. By default, all of them are set to true. This means you can drag, reshape, rotate and resize shapes when you are in edit mode. If you set any of these options to false, you prohibit that functionality.
| EditSettings<!– ThinkGeo.MapSuite.WebEdition.EditSettings –> |
<!– ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#EditTools” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#EditTools</a>
| EditTools<!– ThinkGeo.MapSuite.Core.EditTools –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#FeatureSource” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#FeatureSource</a>
| InMemoryFeatureSource<!– ThinkGeo.MapSuite.Core.InMemoryFeatureSource –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Features” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Features</a>
| GeoCollection<Feature><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Feature} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Id</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsBaseOverlay</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsVisible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#IsVisibleInOverlaySwitcher</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Name</a>
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#QueryTools” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#QueryTools</a>
| QueryTools<!– ThinkGeo.MapSuite.Core.QueryTools –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Style” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#Style</a>
| FeatureOverlayStyle<!– ThinkGeo.MapSuite.WebEdition.FeatureOverlayStyle –> |
The default mode is TrackMode.None, which means you cannot draw or edit features at the client side. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you can then add points, lines or polygons to the FeatureOverlay. Setting the mode to TrackMode.Edit, you can edit the shapes at the client side.
| TrackMode<!– ThinkGeo.MapSuite.WebEdition.TrackMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#HasTickEvent</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.EditFeatureOverlay#OverlayType</a>
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
| Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
