<!– Class –> This class represents a MarkerOverlay object that dynamicly creates markers from the InMemory features.
*System.Object ThinkGeo.MapSuite.SilverlightEdition.Overlay *ThinkGeo.MapSuite.SilverlightEdition.MarkerOverlay ThinkGeo.MapSuite.SilverlightEdition.InMemoryMarkerOverlay
![]() | This is constructor of the InMemoryMarkerOverlay class. | ||
![]() | String | This is constructor of the InMemoryMarkerOverlay class. | |
![]() | String, IEnumerable<String> | This is constructor of the InMemoryMarkerOverlay class. | |
![]() | String, IEnumerable<FeatureSourceColumn> | This is constructor of the InMemoryMarkerOverlay class. |
![]() | RectangleShape, OverlayDrawType | Overlay | Zooms the overlay only to the extent that you specify. |
![]() | Object | Object | |
![]() | RectangleShape | MarkerOverlay | This method returns a collection of markers based on the extent that passed in. |
![]() | Object | ||
![]() | Object | ||
![]() | Map | Overlay | This method initializes the overlay canvas such as width, height and z-index for first time. |
![]() | Overlay | This method re-draws this overlay in current extent. | |
![]() | Double, Double | Overlay | This method returns a point shape in screen coordinates from the specified X, Y world coordinates. |
![]() | Point | Overlay | This method returns a screen point from a point shape in world coordinates. |
![]() | PointShape | Overlay | This method returns a screen point from a point shape in world coordinates. |
![]() | Object | ||
![]() | Point | Overlay | This method returns a point shape in world coordinates from a ScreenPointF structure. |
![]() | Double, Double | Overlay | This method returns a point shape in world coordinates from the specified X, Y screen coordinates. |
![]() | PointShape | Overlay | This method returns a point shape in world coordinates from a ScreenPointF structure. |
![]() | String | Overlay | |
![]() | Collection<FeatureSourceColumn> | Gets the collection of FeatureSourceColumn that is the column definition of the feature data. | |
![]() | InMemoryFeatureSource | Gets a FeatureSource object by which you can do querys to the features in the overlay. | |
![]() | String | Overlay | Gets or sets the name of an overlay which will display in the OverlaySwitcher. |
![]() | Double | Overlay | Gets or sets the opacity level of the overlay. |
![]() | FrameworkElement | Overlay | An FrameworkElement that contains the overlay. |
![]() | SplineDoubleKeyFrame | Overlay | Animates from the System.Double value of the previous key frame to its own System.Windows.Media.Animation.DoubleKeyFrame.Value using splined interpolation. |
![]() | Storyboard | Overlay | Gets the Storyboard object for panning. |
![]() | Storyboard | Overlay | Gets the Storyboard object for zooming. |
![]() | TransitionEffect | Overlay | Gets or Sets the transition effect to use when the map is panned or zoomed. |
![]() | Visibility | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
![]() | Int32 | Overlay | Get or set z-index of overlay, The value is bigger, and the order is higher. |
![]() | SplineDoubleKeyFrame | Overlay | Gets the SplineDoubleKeyFrame for zooming. |
![]() | MarkerZoomLevelSet | Gets the ZoomLevelSet object that controls the markers generation. |
![]() | Map | Overlay | Gets or sets current map information. |
![]() | ScaleTransform | Overlay | Gets the ScaleTransform object of this overlay. |
![]() | TransformGroup | Overlay | Gets the TranslateGroup object for panning and zooming. |
![]() | TranslateTransform | Overlay | Gets the TranslateTransform object of this overlay. |
![]() | DrawingAttributionOverlayEventArgs | Overlay | |
![]() | DrawnAttributionOverlayEventArgs | Overlay | |
![]() | MouseEnterMarkerOverlayEventArgs | MarkerOverlay | This event raises when the mouse enter a marker of the overlay. |
![]() | MouseLeaveMarkerOverlayEventArgs | MarkerOverlay | This event raises when the mouse leave a marker of the overlay. |
![]() | MouseLeftButtonDownMarkerOverlayEventArgs | MarkerOverlay | This event raises when the mouse left button click down on a marker of the overlay. |
![]() | MouseLeftButtonUpMarkerOverlayEventArgs | MarkerOverlay | This event raises when the mouse left button click down on a marker of the overlay. |
This is constructor of the <strong>InMemoryMarkerOverlay</strong> class.
Name | Type | Description |
name | String<!– System.String –> | A String value indicating the name of this overlay. |
featureColumnNames | IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> | A string collection indicating the column names of this overlay. |
featureColumns | IEnumerable<FeatureSourceColumn><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.SilverlightCore.FeatureSourceColumn} –> | A FeatureSourceColumn collection indicating the feature source column of this overlay. |
The overlay will be panned to the center and zoomlevel of the extent that you specify.
Return Type | Description |
Void<!– System.Void –> |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | The new world extent of the map. |
overlayDrawType | OverlayDrawType<!– ThinkGeo.MapSuite.SilverlightEdition.OverlayDrawType –> | The enum value indecating that the map draws features or not. |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay –> Go Back
The <strong>GetDrawingMarkersCore</strong> method creates the makrers based on the current zoomlevel, the specified extent and the special logic of the MarkerOverlay. The returned markers object will be serialized and sent to the client to create client markers.
Collection<Marker><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.SilverlightEdition.Marker} –> | A collection of Marker objects that will be serialized to the client. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> | The extent that include the markers. |
<!– ThinkGeo.MapSuite.SilverlightEdition.MarkerOverlay –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
currentMap | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | Current map information. |
This method converts X, Y world coordinates to a point in screen coordinates.
PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A screen point in pixels. |
worldX | Double<!– System.Double –> | The X world coordinate. |
worldY | Double<!– System.Double –> | The Y world coordinate. |
This method converts the coordinates of a point shape to a point in screen coordinates.
worldCoordinate | Point<!– System.Windows.Point –> | A point in world coordinates. |
worldCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A point shape in world coordinates. |
This method converts a screen point to a point in world coordinates.
screenCoordinate | Point<!– System.Windows.Point –> | The point (in screen coordinates) to convert to world coordinates. |
This method converts X, Y screen coordinates to a point shape in world coodinates.
screenX | Double<!– System.Double –> | The X-value in pixels referenced to the screen origin. |
screenY | Double<!– System.Double –> | The Y-value in pixels referenced to the screen origin. |
screenCoordinate | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | The point (in screen coordinates) to convert to world coordinates. |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.SilverlightCore.GeoCanvas –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.Overlay(overriden) –> Go Back
Returns a collection of markers based on the extent and zoomlevel that passed in.
<!– ThinkGeo.MapSuite.SilverlightEdition.MarkerOverlay(overriden) –> Go Back
args | DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawingAttributionOverlayEventArgs –> |
args | DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.DrawnAttributionOverlayEventArgs –> |
This method raised when the mouse enter a marker of the overlay.
e | MouseEnterMarkerOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MouseEnterMarkerOverlayEventArgs –> | An event argument indicating the mouse position on the map. |
This method raises when the mouse leave a marker of the overlay.
e | MouseLeaveMarkerOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MouseLeaveMarkerOverlayEventArgs –> | An event argument indicating the mouse position on the map. |
This method raises when the mouse down on a marker of the overlay.
e | MouseLeftButtonDownMarkerOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MouseLeftButtonDownMarkerOverlayEventArgs –> | An event argument indicating the mouse position on the map. |
This method raises when the mouse up a marker of the overlay.
e | MouseLeftButtonUpMarkerOverlayEventArgs<!– ThinkGeo.MapSuite.SilverlightEdition.MouseLeftButtonUpMarkerOverlayEventArgs –> | An event argument indicating the mouse position on the map. |
This method raised when Panning animation plays completed.
This method raised when zooming animation plays completed.
Return Type |
Return Type |
Collection<FeatureSourceColumn><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.SilverlightCore.FeatureSourceColumn} –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.InMemoryMarkerOverlay –> Go Back
Return Type |
InMemoryFeatureSource<!– ThinkGeo.MapSuite.SilverlightCore.InMemoryFeatureSource –> |
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent(1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type |
Return Type |
FrameworkElement<!– System.Windows.FrameworkElement –> |
Return Type |
SplineDoubleKeyFrame<!– System.Windows.Media.Animation.SplineDoubleKeyFrame –> |
Return Type |
Return Type |
Storyboard<!– System.Windows.Media.Animation.Storyboard –> |
Return Type |
Return Type |
TransitionEffect<!– ThinkGeo.MapSuite.SilverlightEdition.TransitionEffect –> |
Return Type |
Visibility<!– System.Windows.Visibility –> |
Return Type |
Return Type |
Return Type |
Return Type |
MarkerZoomLevelSet<!– ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevelSet –> |
Return Type |
Return Type |
ScaleTransform<!– System.Windows.Media.ScaleTransform –> |
Return Type |
TransformGroup<!– System.Windows.Media.TransformGroup –> |
Return Type |
TranslateTransform<!– System.Windows.Media.TranslateTransform –> |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
